Icon Extended Travel
Discussion in 'Suspension' started by SAIRS, Dec 9, 2011.
  1. Dec 9, 2011 at 6:44 PM
    SAIRS
    SAIRS [OP] Well-Known Member
    Kelly
    Utah
    Super White 2012 Double Cab LB TRD SPORT
    Icon Extended Travel Stage 1, Total Chaos UCA's, Dakkar leaf pack, Beefed DCLB Sliders with extended kickout and custom BSP, Beefed Custom exo-rear tube bumper, Toyota bed mat, tailgate theft mod. Front mudflaps removed, Access LE soft tonneau cover, Weathertech digital floor mat, Weathertech window deflectors, Weathertech license plate frames. future plans = diamond plate tailgate mod, Venture Shield, TRD supercharger...the dream goes on and on....
    I havent had any luck coming across the right thread or comments on this...so I will start a new thread.
    On this Icon Stage 1 lift kit from Toytec, you have the option of the 5-8635 Extended Travel coilover. You need aftermarket UCA's and it gives you the two inch add a leaf or the tsb add a leaf option as well.
    My question is what is the advantage of the Extended Travel option? Also what is the difference between Long Travel kits that seem to cost around $10 grand as compared to this price?
  2. Dec 9, 2011 at 6:50 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    $10 grand! WOW are you looking at custom kits? Camburg and TC are just under 3k for the kits then add 1200 for the shocks.
    Which kits are you looking at that are 10k?
  3. Dec 9, 2011 at 6:58 PM
    kcbmx
    kcbmx doing my thing.
    Marco
    Bakersfield CaLiFoRnIa
    2tr-fe 4wd
    spit cup, weathertech floor mats, riffle rack, and bilsteins.
    Extended travel coilovers help use up the articulation that comes with a uniball uca. Stock travel is about 6-7", uca's +coilovers 8-9" and uca's + ext. travel coilovers 10-11".
  4. Dec 9, 2011 at 7:22 PM
    SAIRS
    Kelly
    Utah
    I wasnt looking at LT kits, but I saw a thread a while back where they were talking those numbers. I never looked back at that point. I guess I misunderstood that.
  5. Dec 9, 2011 at 7:24 PM
    SAIRS
    Kelly
    Utah
    So what are some of these long travel kits covering then?
  6. Dec 9, 2011 at 10:53 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    For front and rear LT, 10 grand aint to far off. And that's not including maintenance costs.
    SUMMIT556 likes this.
  7. Dec 9, 2011 at 11:03 PM
    kcbmx
    Marco
    2tr-fe 4wd
    13-15 depending on the kit. Bottomline is that LT is badass and i wish i could afford it lol.
  8. Jan 4, 2012 at 10:07 AM
    docjake
    docjake Well-Known Member
    Fredericksburg VA
    I am running into the same question when looking at the ICON kits, I previously ran the non reservoir Icons on my last truck and when looking at upgrading the current truck I see the extended versions as an option. Does this not increase the binding on the CV when drooped, or are you not able to run these on the 4WD versions at all? Thank you for the help.
  9. Jan 4, 2012 at 12:39 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    extended travel gives you an extra 7/8" of down travel...
