ICON Group Buy from Metal-tech 4x4 - Huge discount before factory price increase!
Discussion in 'Group Buys' started by helocat, Feb 11, 2011.
Thread Status:
Not open for further replies.
  1. Feb 17, 2011 at 1:11 PM
    #81
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Quote from Icon
    These coil-over’s are meant to be installed with an aftermarket uniball upper control arm kit to ensure the proper amount of wheel travel and to prevent premature ball joint wear.
    http://www.iconvehicledynamics.com/...-Remote-Reservoir-Front-Coil%2dover-Shock-Kit
  2. Feb 17, 2011 at 1:16 PM
    #82
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I called LT direct at 503-822-1111
  3. Feb 17, 2011 at 1:20 PM
    #83
    ARC
    ARC Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    Anybody have any idea on the angles a unibal UCA can handle?
  4. Feb 17, 2011 at 1:27 PM
    #84
    lembowski
    Rolando, CA
    Jeeper Creeper
    Just call Icon, they designed the Coilover they should be able to tell you the specs the UCA need to be.
  5. Feb 17, 2011 at 2:23 PM
    #85
    ARC
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    Don't have a phone:cool:
  6. Feb 17, 2011 at 2:32 PM
    #86
    lembowski
    Rolando, CA
    Jeeper Creeper
  7. Feb 17, 2011 at 3:30 PM
    #87
    Whistler_Steve
    Whistler_Steve Well-Known Member
    Stephen
    Whistler, Canada
    06 Radiant Red TRD Offroad
    Icon Ext Travel Coilovers--LR Upper Control Arms--Icon 3 Leaf AAL--OME 182 Rear Shocks--BFG KM/2 285/75/16--Replica TT TRD FJ Wheels
    Sweet keep us posted, I'm interested in this too.
  8. Feb 17, 2011 at 4:00 PM
    #88
    lembowski
    Rolando, CA
    Jeeper Creeper
    I just spoke with Icon, they don't reccomend you use the extended with the ball joint UCA's. They said that the LR will help with more movement however at full droop the ball joint still has a tendency to fail.
  9. Feb 17, 2011 at 4:11 PM
    #89
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    So in summary just shell out the money and get the Billet Upper Control Kit
  10. Feb 17, 2011 at 4:21 PM
    #90
    izquik72
    izquik72 Well-Known Member
    Northern AZ
    2002 SR5 DCSB 4x4
    shell, grey wire, turn signal relocate bumper ordered lift OME ordered
    I did the same! They took the shipping off.
    This kit comes with new U Bolts also
  11. Feb 17, 2011 at 4:25 PM
    #91
    lembowski
    Rolando, CA
    Jeeper Creeper
    Not exactly, just buy a Uni-Ball UCA, dosen't matter the brand
  12. Feb 17, 2011 at 4:47 PM
    #92
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    is it true that ext. length coilovers will work with Camburg ball joint uca's? someone posted that earlier...
  13. Feb 17, 2011 at 5:07 PM
    #93
    lembowski
    Rolando, CA
    Jeeper Creeper
    See above
    Call icon to speak to them about it, they said you could do it but they don't recommend it. I wouldn't personally risk it myself, I would spend the extra $200 bucks and buy a Uni-Ball UCA or go with the standard length coilover.
  14. Feb 17, 2011 at 6:50 PM
    #94
    lembowski
    Rolando, CA
    Jeeper Creeper
    Just ordered the Extended Travel Remote Reservoir Coilover
  15. Feb 17, 2011 at 7:58 PM
    #95
    Whistler_Steve
    Stephen
    Whistler, Canada
    Hmmm I don't know what to think now....I was kinda going for the whole thing under the assumption I could run LR's and it was comparable to doing the Toytec ULK with 2.5 Radflo's.
    Noticed this in another thread BTW. The question is who to believe, ICON or LR?? :confused:
    Originally Posted by LIGHT RACING LAB
    "ToledoFJ called us and let us know this thread was flowing. Here are a few deign points on our Upper Control Arms you all might be interested in knowing:
    • Our Upper Control Arms were designed work with a wide range of coilover shocks; from the stock Toyota units to long travel aftermarket shocks similar to the Light Racing or Icon units. This includes shocks that allow for a slight increase in droop travel.
    • The increased travel was accommodated by using a ball joint with a higher range of travel. The stock Toyota ball joint has a 77° included angle (or 38.5° off centerline). Our design allows for a 90° included angle (or 45 ° off centerline. A spherical bearing (monoball) with high angularity inserts rarely has more than a 35° included angle. The angle of the ball joint plate is optimized for this increased ball joint travel.
    • The sliding off-set ball joint that we use allows for a huge range of alignment adjustment rather than designing an arm with a static off-set and relying on the Lower Control Arm cam bolts for adjustment. This means the camber of our arm can be adjusted to the stock upper control arm geometry or it can be adjusted for proper camber in a 4” lifted vehicle. The caster can also be adjusted from stock numbers up to a 4° increase in caster for better high speed stability.
    • Using a standard ball joint (instead of a monoball) and molded rubber inner pivots (instead of urethane) gives better ride quality, better longevity, lower maintenance, and quiet operation.
    • We as a company have 30 years experience designing ball joints for aftermarket and OEM use. The design and quality of the ball joints used on these arms is top notch.
    • Our arms are coated using E-coating. This is a process where the coating is electro-statically grown on the part. This is used for many OEM suspension components and gives superior corrosion protection to zinc plating, paint, or powdercoating."
  16. Feb 17, 2011 at 8:05 PM
    #96
    lembowski
    Rolando, CA
    Jeeper Creeper
    I dunno, that is your choice. I just tend to follow directions, engineers don't design things and make recommendations for the fun of it.
  17. Feb 17, 2011 at 8:09 PM
    #97
    jandrews
    '09 FourDubDee TRD OR
    Meh, rather have the stronger uniball UCAs anyway.
  18. Feb 17, 2011 at 8:23 PM
    #98
    Whistler_Steve
    Stephen
    Whistler, Canada
    That's my whole point....which engineers am I supposed to trust? The ones that designed the coil-overs saying the Control Arms won't work? Or the ones that designed the Upper Control arms saying they designed them to work with Icons.
    Oh well, thanks for the heads up, I'll do a little more research before I pull the trigger on the combo
  19. Feb 17, 2011 at 8:28 PM
    #99
    lembowski
    Rolando, CA
    Jeeper Creeper
    Goodluck
    Do you offroad much? If you do you will see the benefit of the uni-ball more. If you don't offroad as much the ball joint should be fine.
  20. Feb 17, 2011 at 8:33 PM
    #100
    Tacomanator
    Clam Slammer
    Southern Cali
    damn, that is confusing. if LR says their uca's will work with Icon, then go for it. Icon probabbly prefers a uni ball type in hopes that you buy their expensive billit uca's .
Thread Status:
