ICON isn't much help!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoInDenver, Aug 14, 2019.
  1. Aug 14, 2019 at 4:17 PM
    TacoInDenver
    TacoInDenver [OP] Well-Known Member
    2019 TRD Off Road (Cement)
    Nothing huge, but I want to change out the ugly ass bolts on the faux bead lock on the ICON Compression wheels I recently purchased. This bolt has a pretty funky thread pitch and rather than tell me what it is, ICON reps claim they have no idea what it is. Crappy service is enough for me to take them back and go with SCS!!
  2. Aug 14, 2019 at 4:20 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Pop one out and measure thread pitch yourself or go down to hardware store/machine shop where they have gauges..
    Regardless, a company should know their product inside and out. Probably just a bit of laziness TBH
    Riotfunk, JdevTac, GillyLink and 4 others like this.
  3. Aug 14, 2019 at 4:30 PM
    TacoInDenver
    Yeah, I did exactly that. The local hardware stores tried 5/16"x18, 20,22,24 and no good on any. Just a really weird deal!!
  4. Aug 14, 2019 at 4:37 PM
    Shellshock
    Iowa
    Take one to Fastenal. They will figure it out.
  5. Aug 14, 2019 at 4:41 PM
    TacoInDenver
    Good suggestion, thanks! If I can't get it dont, I'll take them back and go with VTX!!!
  6. Aug 14, 2019 at 4:49 PM
    Shellshock
    Iowa
    I’ve yet to find something they can’t figure out. There’s been a couple times they didn’t have it in stock but it was there the next day
    I was just there today and it took all of 5 minutes to get an exact replacement for what I had
  7. Aug 14, 2019 at 4:59 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    VTX huh? What are you trying to do with the Icons? Blackout?
  8. Aug 14, 2019 at 5:02 PM
    TacoInDenver
    The chrome hex bolts look really janky! Aside from the bolts, I love the wheels!!! I would do either a black Torx OR...have the torx glass beaded and painted Cement to match the truck!!
  9. Aug 14, 2019 at 5:07 PM
    .jake
    .jake Ex-Lion Tamer
    Pickeledpigsfeet likes this.
  10. Aug 14, 2019 at 5:17 PM
    TacoInDenver
    .jake[QUOTED] likes this.
  11. Aug 15, 2019 at 2:29 PM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    @TacoInDenver
    Here are the specs of the bolt.
    M8-1.25 x 8mm
    Not a standard size. The few cases I've dealt with the customer sourced a 10mm bolt and used a washer to prevent it from bottoming out in the wheel. I also have seen someone grind a tap to allow it to thread a few mm deeper into the lip to run a 10mm without a washer.
    tinker_troy, Taco_Craig and velillen like this.
  12. Aug 15, 2019 at 2:37 PM
    Shellshock
    Iowa
    Icon_Adrian likes this.
  13. Aug 15, 2019 at 2:45 PM
    TacoInDenver
    Called ICON AGAIN today - two times with no call back, no reply to e mail or FB post. Answer today I got when I advised that I would return the wheels if I had to deal with the ugly bolts, "Yeah, I would say you should take them and the suspension back for a refund". No worries, DONE!! Poor customer service will lose in my book EVERY time!!
    tjbajatacoma likes this.
  14. Aug 15, 2019 at 2:51 PM
    mcm808
    mcm808 Well-Known Member
    Micah
    Kane’ohe, O’ahu
    3rd gen
    This guy replied to thread pitch on the bolt
    Skydvrr, tcjacado, Taco_Craig and 2 others like this.
  15. Aug 15, 2019 at 3:01 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    If the holes are drilled deep enough you can use a bottoming tap to tap to the bottom of the hole.
    https://www.amazon.com/1-25-Bottoming-Taps-Speed-Steel/dp/B00KDN7RH8
    But you bought the wheels knowing full well what the bolts look like - if you want to change them out expect to do some leg-work to make it happen.
    Icon_Adrian[QUOTED] likes this.
  16. Aug 15, 2019 at 3:05 PM
    Shellshock
    Iowa
    ... they replied to this post 2 above yours
    Rainoffire, FishnTx and Icon_Adrian like this.
  17. Aug 15, 2019 at 3:07 PM
    Bigtrees
    Bigtrees Well-Known Member
    Oregon
    2002 Reg Cab, 2007 DCSB
    Lol @ returning your wheels and suspension because you’re being ridiculously OCD and whining about what wheel bolts look like.
    You sound like a customer service nightmare: entitled, loud, unrelenting when you don’t have an answer in 2 minutes and just plain rude.
    ruffridha9, Skydvrr, TSAVO and 3 others like this.
  18. Aug 15, 2019 at 3:08 PM
    KaizerWilhelm
    KaizerWilhelm Well-Known Member
    Will
    Seattle
    2017 TRD OR DCSB Super White
    Whole bunch of stuff in my garage
    Total side bar, but I hear Sam Kinison's voice in my head when I read this thread. Also, @Icon_Adrian replied with the proper bolt size...
    tinker_troy and Skydvrr like this.
  19. Aug 15, 2019 at 3:17 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
  20. Aug 15, 2019 at 3:18 PM
    Shellshock
    Iowa
    that was the first one I found in 5 seconds of looking.. theres others out there.
    C-Rok275[QUOTED] likes this.
