Icon Leaf HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DontTryMe, Sep 28, 2009.
  1. Sep 28, 2009 at 5:39 PM
    DontTryMe
    DontTryMe [OP] Well-Known Member
    Atlanta,GA
    07 TRD offroad dbl cab
    Tinted Tail Lights, Fog Light mod, Black Projector Headlights, 8000k HIDs, Grill Craft Grill, Sport Hood
    Hey guys, I bought a set of coilvers and also bought the Icon progressive 3 leaf pack, which is suppose to gain me 1.5 inches of lift.
    My truck is a trd 4x4 dbl cab and already sits about 2 inches higher in the rear
    My question is with the coil overs cranked to 2.5 will the Icon leaf pack make the truck still sit higher in the rear? I want the nice level look.
    Thank in advance!
  2. Sep 28, 2009 at 5:47 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    wont the spring settle 1/2" or so as they break in? not sure if that helps.
    I'd keep some rake for loads anyway, or you'll need to adjust the headlights.
  3. Sep 28, 2009 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It will only sit about 1" higher in the rear, or so. Hardly noticable.
  4. Sep 28, 2009 at 5:53 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    first im suprised your truck is 2 inch high in back already. is it stock?
    i did the TSB which gave me 1.5 inches in the back. but when i went to install the 5100s, i remeasured it and it settled to only a inch. so with that i set my front 5100 to .85. all together it raised both the front and back about a inch.
    here is how mine looks
    in theory , it does sound like your back may still be high.
    2.5 up front / 2 + 1.5 in the back
  5. Sep 28, 2009 at 6:06 PM
    Tacoyota
    08 4wd
    Nice lookin setup Ski.
  6. Sep 28, 2009 at 6:08 PM
    skistoy
    Western New York
    thanks
  7. Sep 28, 2009 at 6:12 PM
    DontTryMe
    Atlanta,GA
    thanks for the help guys, I was suprised too. I dont have the TSB done and I bought the truck brand new so nothing has been done.
  8. Sep 28, 2009 at 6:18 PM
    skistoy
    Western New York
    check with the dealer about the TSB, it gives you a 4 pack spring.
    if interested research it here, it can be a happy story or a total nightmare trying to get them, especially on a 09.
  9. Sep 28, 2009 at 6:29 PM
    DontTryMe
    Atlanta,GA
    I didnt mean I was going to get the TSB done I was just saying I didnt have it done therefore I have no idea why its 2 inches higher in the rear. Supposedly the Icon progressive 3 pack rides real smooth
  10. Sep 28, 2009 at 7:08 PM
    DontTryMe
    Atlanta,GA
    Also would I be able to use a 3/4 inch top spacer to put on top of the toytec coilovers to help with the rake?
