ICON Lift Results
Discussion in 'ICON Vehicle Dynamics' started by Ndrorder, Jan 19, 2015.
  1. Mar 7, 2015 at 5:28 PM
    sixspeedlife
    sixspeedlife Well-Known Member
    Braden
    MB, Canada
    05 TRD OFFROAD Six speed
    Leveled, BHLM, Black mesh grill, black skid plate
    Am I correct in assuming you can only get the CDC valve on the any of the remote resi models?
  2. Mar 7, 2015 at 8:11 PM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    Not exactly, I believe that you can get the remote resi with cdc installed on non resi extended travel coilover.
  3. Mar 7, 2015 at 8:22 PM
    sixspeedlife
    Braden
    MB, Canada
    So I could add the remote resi at a later point?
  4. Mar 7, 2015 at 9:12 PM
    2012SilverSport
    Guam
    Yes, a lot of people do that when they send their CO's in for rebuild
  5. Mar 8, 2015 at 5:54 PM
    rsj78
    rsj78 Well-Known Member
    Scott
    Virginia
    2012 Tacoma TRD Sport 4WD
    Bilstein 6112's, Icon progressive AAL, Specialty Products Upper Control Arms, TRD Catback, Alpine head unit, Husky Liners mats, AVS in-channel visors, Husky Liner Mud Guards, Bullaculla Trailer harness Relocate Bracket, TRD shift knob
    How often are you supposed to rebuild the CO's?
  6. Mar 8, 2015 at 8:04 PM
    Hanswdeuce
    Hanswdeuce Well-Known Member
    CA
    Silver Sk 16 TRD Off Road 4X4
    Wheels: Bronze SCS Stealth 6 Tires: Falcon Wildpeaks Suspension: King 3.0, Icon RXT leaf pack set at 2 Waiting on RSI Smart Cap EVO
    I think it is every 40 to 45 thousand miles.
  7. Mar 9, 2015 at 2:52 PM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    All depends on how hard you use them. Mileage means nothing.
    sierra141 likes this.
  8. Mar 9, 2015 at 3:16 PM
    rsj78
    Scott
    Virginia
    How do you like the ride of the Icons? Trying to decide between them or waiting for Bilstein 6112.:confused:
  9. Mar 9, 2015 at 3:19 PM
    Hanswdeuce
    CA
    I love them. Night and day over stock.
  10. Mar 9, 2015 at 3:22 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And can we go over 2" of exposed thread? If not, why did you give us so much to work with?
  11. Mar 10, 2015 at 5:35 PM
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    We use the bodies for other things beyond these coil overs. The issue is if you go past you are at risk of binding the coil at full bump.
  12. Mar 10, 2015 at 8:40 PM
    ThomasMore66
    Well, that's too bad, but I can live with that answer. Too bad the guys at Toyota of Dallas (largest TDR seller in the US) didn't know that. I really like being tall. My wife hates it, but I like it.
  13. Mar 10, 2015 at 9:03 PM
    icon_rep
    Riverside, CA
    You can push the limits but this way you understand what you're up against in your consideration to do so!
  14. Mar 10, 2015 at 9:05 PM
    ThomasMore66
    I'll drop back down to 2". At least now I have a real answer. Is this true with the diff drop? It might ride a little better. I blamed some of that on my E rated Toyos.
  15. Mar 11, 2015 at 2:25 AM
    #35
    rsj78
    Scott
    Virginia
    2012SilverSport, How much lift did you add in the front/rear? Looks good!
  16. Mar 11, 2015 at 6:43 AM
    #36
    ThomasMore66
    You know, it would be handy if you would include those words in the instructions. There has been a lot of discussion on here about CV joints, axle angles, etc., and I've never heard coil-bind.
    Also, does every 1/2" of thread = 1" of lift? That's a common statement on here too. Not sure if those things really go together.
    Is there a chart out there for spring performance as a function of compression? I seem to remember that the standard Icon springs are rated at 650#, but it would be nice to see a comparison of the 650/700 graphically to see how the performance differs.
    How much additional weight can the 650's handle? If I load up with a 130# steel bumper and a 80# front skid, should I go with the 700's?
  17. Mar 18, 2015 at 8:59 PM
    #37
    2012SilverSport
    Guam
    Been out of town sorry took so long. I am just under 3" lift front 2 1/4 rear with 3 degree shim measured from fender to center hub for consistency.
  18. Mar 20, 2015 at 1:36 PM
    #38
    NDNCAR
    NDNCAR Member
    Calgary, Alberta
    2011 tacoma TRD sport short box
    1.25" spacers, Icon stage 3 , Billet UCA
    Im waiting on my stage 3 with the Billet uca, should be ready to drive this evening. hoping for a big diff from stock ride, and an improvment on the OME kit i had on my jeep. will post pis later. 2011 dcsb
  19. Mar 21, 2015 at 7:51 AM
    #39
    2012SilverSport
    Guam
    It is a huge difference from the stock ride, I am extremely happy with mine! congrats on the lift and welcome to TW. looking forward to the pics.
  20. Mar 27, 2015 at 11:37 AM
    #40
    ThomasMore66
    So I'm dropping my Icons back down to 2" since I had my correspondence with the Icon Rep.
