ICON Lift Results
Discussion in 'ICON Vehicle Dynamics' started by Ndrorder, Jan 19, 2015.
  1. May 2, 2015 at 12:56 PM
    #81
    ThomasMore66
    Dallas/Fort Worth & Durango
    I had mine cranked up to about 2.5" of thread showing. Dropped them down to where the driver's is a little over 2" and the passenger is under 2". Now I've been having some issues with my 285's.
  2. May 4, 2015 at 1:37 PM
    #82
    epard
    epard Well-Known Member
    Ethan
    Ocala, Florida
    2012 DCLB TRD Sport 4x4
    Icon Stage 3 tubular UCA's
  3. May 4, 2015 at 11:19 PM
    #83
    ThomasMore66
    And you got stuck?
  4. May 5, 2015 at 8:39 AM
    #84
    NDNCAR
    NDNCAR Member
    Calgary, Alberta
    2011 tacoma TRD sport short box
    1.25" spacers, Icon stage 3 , Billet UCA
    ]Hey just to be clear, the rear of my truck sits higeher than the front , and i have herd a lot about how much thread you can have cshowing on th front, so here is my question with a picture, can i rase my front up more ?
  5. May 5, 2015 at 8:53 AM
    #85
    ThomasMore66
    The key is that you don't really want more than 2" of thread showing. If you read back in this thread the Icon rep explained that it could cause binding on full compression. If you are running non stock UCA's, you can run more, but they don't advise it. I have one a little over 2" and one under to account for lean.
  6. May 13, 2015 at 6:15 PM
    #86
    epard
    Ethan
    Ocala, Florida
    Flexin
  7. May 17, 2015 at 4:27 PM
    #87
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Just installed one of the COs today. Unfortunatly, rust made it a huge project. I'll install the other one tomorrow. Looks like I'll set them at 2" of thread showing. How much approx lift does that give?
  8. May 17, 2015 at 5:52 PM
    #88
    ThomasMore66
  9. May 17, 2015 at 6:03 PM
    #89
    replica9000
    2019 T4R ORP
    So other than the coil binding, going over 2" of thread would be bad for the CV joints than (for us 4x4s). My stock drivers coil sagged about an inch.
  10. May 17, 2015 at 6:50 PM
    #90
    ThomasMore66
    I'm running the diff drop and I did really like the look of being taller. However, the handling did get a little skittish on some surfaces with the shocks up there. I would have the front end wash out on a really curvy roadway...I did not like that. Traction control kicked in, and left me going WTF! Happened more than once. I've gone back and accelerated hard on the same roadway and it doesn't happen now.
  11. May 20, 2015 at 12:17 PM
    #91
    replica9000
    2019 T4R ORP
    Set both coils to 1.75“ of thread showing. If my maths are correct, that's about 2.6“ of lift. Seems to ride smoother than my girls G6 does.
  12. May 20, 2015 at 3:19 PM
    #92
    ThomasMore66
    Sounds right. I think you may find that a measuring tape from the ground to the top of the fender opening will not be the same side-to-side. Taco Lean!
  13. May 20, 2015 at 3:41 PM
    #93
    replica9000
    2019 T4R ORP
    If there is lean right now, it's not noticeable like it was before. I still have Dakars to put on, which one side is supposed to compensate for that.
  14. Jun 3, 2015 at 7:35 AM
    #94
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    looks like you approx. .75" to play with
  15. Jun 14, 2015 at 9:49 PM
    #95
    southernpanic
    southernpanic Well-Known Member
    ga.
    12 trd sport 4x4 dclb
    Pelfreybuilt,icon,camburg,allpro, method,Bushwacker,nfab,fox, Crown,toyo
    icon install instructions said not to exceed 1.13" thread but that's with the heavier 700lb springs. Think they are a lil taller than standard.
  16. Jun 15, 2015 at 4:29 AM
    #96
    ThomasMore66
    I've wondered about the 700's. Could I get a bit more lift?
  17. Jun 15, 2015 at 8:28 PM
    #97
    southernpanic
    ga.
    No more lift. 700lb springs 3" max. Springs are 1" taller but you can't crank down past 1" 600lb springs are shorter but you can crank 2" for 3" of lift is my understanding. Could be wrong.
  18. Jun 16, 2015 at 3:18 AM
    #98
    ThomasMore66
    Too bad. When I first installed my Icons I had them cranked down and had over 2" showing. Icon rep explained that greater than 2" was too much preload. I liked the slightly taller look.
    Anybody run a spacer with the icons to take care of lean? I put my hi lift on the passenger side just to put more weight on that side.
  19. Jun 25, 2015 at 8:54 AM
    #99
    IsaacG
    IsaacG Well-Known Member
    New Mexico
    2015 TRD Off Road
    3" Icon Stage 2 lift 285/70/R17 BFG KO2 17" RockStar 2 Wheel
    I had my lift installed but noticed the passenger front coil over is not cranked as high as the driver side. Is this normal to have one cranked higher then the other. I've measured the distance and it seems to be the same height. Thanks in advance for the input.
    Driver Side:
    Passenger Side:
  20. Jun 25, 2015 at 9:03 AM
    #100
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    yes normal, due to the truck being heavier on one side
