Icon lift setting question 2 or 3"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DiveNSurf, Jul 1, 2015.
  1. Jul 1, 2015 at 7:54 AM
    DiveNSurf
    DiveNSurf [OP] Member
    2011 White Tacoma LB 4x4
    Hey, I'm new to the forums so hopefully I can ask on this thread. I just bought the Icon 0-3.5" lift extended travel coilover kit w/remote reservoir with TCO 96504 ARM PAIR and 2X ICON 56503R rear shocks. Should I set the front to 2" or can I set it to the full 3" without it being too stiff?
    11' Toyota Tacoma double cab long bed 4x4
  2. Jul 1, 2015 at 7:56 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    The more preload you add the stiffer it will be. Its your choice. Is hieght or ride more important to you? if you wanna fit 33's you should at least go 2.5 to avoid rubbing
    DiveNSurf[OP] likes this.
  3. Jul 1, 2015 at 8:08 AM
    DiveNSurf
    Yeah I bought BFG A/T TA KO2's in a 32.7 size so basically a 33".
    Going to be traveling a lot in Baja.
  4. Jul 1, 2015 at 8:09 AM
    Mademan925
    Nick
    Discovery Bay, CA
    I have my icons at 2.75 to fit my 285's. I dont have much preload because I got longer stiffer coils to compensate for the added wieght of my armor
    hossnugget and DiveNSurf[OP] like this.
  5. Jul 1, 2015 at 7:53 PM
    DiveNSurf
    Ok, So I set my lift at 2.5" with 33" KO2's and there is some rubbing with the flaps still on so I'm going to remove them and see what happens but looks good so far and have been getting compliments already. tacomawithlift1.jpg
    Kyitty likes this.
  6. Jul 5, 2015 at 4:54 AM
    Vrobledo3
    Vrobledo3 Well-Known Member
    Vern
    Fairfield, NorCal
    09 timberland TRD offroad
    Icon stage 4 lift kit Fj trail team wheels BfGoodrich TA/km2 K&N intake Black grill Black headlights
    I got 285's on mine. Rubbed a little until I set it to 2.5". I took off mudflaps also.
    thebaker likes this.
  7. Jul 5, 2015 at 8:45 AM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    3" on 33's. Had to CMC and trim. Ride is stiffer than when I was at 2" or even 2.5" but I'm good with it.
    DiveNSurf[OP] and thebaker like this.
  8. Aug 13, 2015 at 4:25 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Do you still have rubbing after you removed the mudflaps? If yes, may I know your caster setting?
    I set mine at 3" lift without mudflaps, caster at 2.7 degrees. Yet, it is rubbing during turns and backing up in the cab mount more with the BFG AT KO2 than with the BFG M/T KO2 that it replaced. :(
  9. Aug 13, 2015 at 4:47 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    :laughing: LMAO at the "I lifted it to 2.5" and have no more rubbing."
    You still rub, suspension travel didn't change.
