icon question???
Discussion in 'Suspension' started by jr114, Oct 11, 2010.
  1. Oct 11, 2010 at 5:28 PM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    so i called icon today and the said that to attain 3" of lift there should be 2.5" of thread showing. so i set the driver side at 2.5 and the passenger side at 2.25. will be running them with camburg ucas. what do you guys think? too high?
  2. Oct 11, 2010 at 5:30 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    You should have just done before and after measurements to make sure for yourself.
  3. Oct 11, 2010 at 5:32 PM
    jandrews
    '09 FourDubDee TRD OR
    This.
    As far as "too high", that should largely be determined by CV angles.
    Also, according to the instructions that just came with my Icon kit, you're not supposed to exceed 2 inches of exposed thread between the shock top cap and adjuster ring.
  4. Oct 11, 2010 at 5:41 PM
    jr114
    Jon
    SoCal
    Truck
    cant measure cause im already lifted. just changing out parts.
    i know the directions say no more than 2" but thats with stock ucas. so im not sure
  5. Oct 11, 2010 at 5:42 PM
    jr114
    Jon
    SoCal
    Truck
    oh yeah im a prerunner dont have cv
  6. Oct 11, 2010 at 5:51 PM
    jandrews
    My directions do not specify with stock UCAs. They state lifting above 2.5 inches with stock UCAs is not advisable, But up to 3.5" can be gained with aftermarket UCAs.
    The way my instructions read, you shouldn't go over 2" of exposed thread EVER, but maybe they worded it weird.
    AFAIK, 3" lifts run between 38 and 39 inches from ground through the center of the wheel hub to the top of the wheel well. The better measurement is center of wheel hub to top of wheel well, because it removes tire size from the equation.
    Fair enough, but you still have to worry about your pinion angle, which is another reason not to go too high.
  7. Oct 11, 2010 at 5:58 PM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    Did you get the extended travel? I had 2" driver and 1.8" passenger, and it netted me 3.1" lift
  8. Oct 11, 2010 at 6:38 PM
    jr114
    Jon
    SoCal
    Truck
    ya i have the extended travel shocks.
    to jandrews...your right, i just re-read my little instruction sheet. it does say no more than 2". no im really confused why the guy at icon would tell me 2.5
  9. Oct 11, 2010 at 6:42 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Measure center hub to fender to see how much it is.
  10. Oct 11, 2010 at 7:39 PM
    jr114
    Jon
    SoCal
    Truck
    the shocks are not on the truck yet. guess i shouldve clarified that. i had them put in a spring compressor and adjusted the height that way. i do not have the spanner. was going to put them on today but, that 2.5" kinda made me think a few times and i thought id turn to you guys for some help and info.
  11. Oct 12, 2010 at 6:50 PM
    jr114
    Jon
    SoCal
    Truck
    well i adjusted the coilovers to 1.75 on the drivers and 1.5 on the passengers. right now on a slanted driveway, with 285/70/17s on there im sitting at just under 40" from ground to fender following the center of the wheel as best as possible. at first i thought i noticed some vibrations, but they seem to have gone away. not sure if its just do to settling or because im really feeling and looking for everything. overall stoked on the ride. much better than the procomp strut i had before.
  12. Oct 12, 2010 at 6:50 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Nice, congrats!
  13. Oct 12, 2010 at 6:52 PM
    jr114
    Jon
    SoCal
    Truck
    ya thank you guys for helping me realize that having them set at 2.5 was just plain stupid. dunno what i was thinking. thanks to you guys so far alls good:)
  14. Oct 12, 2010 at 8:48 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    I'm installing my ICONS this weekend and they say they come pre set at about 2" of lift. Both mine were factory set with 1.25" threads showing, so about 3/4" till the magical 2" threads showing mark.
    So if it is actually set for 2" of lift already with 1.25" of threads showing, the other 3/4" I could crank up to would bring them to about 3.5" of lift.
    I theorize my Revtek has settled down to about a 2.5" of lift and it's not 3" anymore, so I'm going to set them for 3" of lift. If it's too rough, I'm going to back them down to 2.5. But I'm figuring even at 3" they will be way better than the crap in there now.
    Can't wait to install this shit!
  15. Oct 13, 2010 at 9:14 PM
    jr114
    Jon
    SoCal
    Truck
    so putting the coilovers in a spring compressor was a fast and easy way to adjust the preload. but now ive noticed a few scratches on the coil itself. should i worry about them, or ignore them? should i cover em up with something? if so what?
  16. Oct 14, 2010 at 4:27 AM
    jandrews
    If it's down to bare metal, just touch up with paint to prevent rust.
  17. Oct 14, 2010 at 5:39 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    Did you try to fully compress the front and turn right or left ??? I wonder if this would rub anywhere ??.
    I have my shocks set up at the same height and planing to install a set of Revo's 285/75/16 on 4.5 bs. I all ready removed the mud flp and I have a Relentless front bumper. I am curious if I have to lift the front a little bit more , or not.
  18. Oct 14, 2010 at 5:58 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i have extended travel icons so i don't know if it's any different but i have 1 3/4" and 1.5" of thread showing, and i have 3" of lift up front
  19. Oct 14, 2010 at 8:14 AM
    jr114
    Jon
    SoCal
    Truck
    jandrews thanks. ya ill run to kragen or one of the other stores and grab a little bottle of the black touch up paint. really do not want these to rust.
  20. Oct 14, 2010 at 8:16 AM
    jr114
    Jon
    SoCal
    Truck
    i checked and i do not have any rubbing issues. theres a little trimming that youll have to do to the front plastic trim, but its not that bad.
