ICON Question
Discussion in 'ICON Vehicle Dynamics' started by chosenfew22, Dec 26, 2014.
  1. Dec 26, 2014 at 4:20 PM
    chosenfew22
    chosenfew22 [OP] Well-Known Member
    War Pig
    Fayetteville, NC
    2014 TRD Off Road
    WeatherTech Floor Mats, Avid Rock Sliders, ICON Extended Travel Remote Reservoir Coil-over Shock Kit with CDCV, 1.5" Lift Rear Add a Leaf Kit, ICON 2.5 OMEGA Series Bypass Rear Remote Reservoir Shocks, Tacoma Bed Mat, RockyBike Mount, Cargo Net, Shorty Antenna, 17" XD Revolvers, BFG AT 285/70/17, Hilift Jack, 20 & 5% Tint, Blacked out badges, Derped Rear Bumper and Grill
    Hi. I just recently bought the Icon Stage 7T kit for my '14 taco. Originally, I kept the fronts set to the factory setting, but my 285/70/17s around 17x9 (-12offset) rims were rubbing the fender and frame (cab mount?) slightly. Then it settled and it got unbearable. So I got an alignment and rubbing was considerably less but rubbed a lot in reverse. I grabbed my spanner wrench and cranked it up until there was only like 4 full revolutions left or threads showing underneath where you crank w/ the wrench. I'm not even close to rubbing right now. *I'm also running a plate bumper and winch.
    1) Is lifting it that high going to negatively effect the quality of the suspension?
    2) Will the coil overs settle again and drop the height of my truck?
  2. Dec 26, 2014 at 4:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like a lot of preload in the springs. Check your height. its not uncommon to have to cut the cab mount to gain clearance for the tires.
  3. Dec 27, 2014 at 12:49 AM
    Biznitch15
    Biznitch15 Well-Known Member
    José
    Los Angeles/San Diego
    13 DCLB TRD Sport
    None Yet
    I'm in the same boat. Gonna install stage 5 this weekend and I got the same wheel setup as you. I heard there was gonna be some rubbing. but from your experience, sounds like it's more than expected. I didn't want to Cab mount chop, but I think I'll have to at this point.
  4. Dec 27, 2014 at 6:03 AM
    chosenfew22
    War Pig
    Fayetteville, NC
    2014 TRD Off Road
    I was thinking it's a lot of preload too. I raised the truck up about 1" in the front from where it was previously, no rubbing even in reverse in full lock. It sits slightly higher than the back though which I wanted to avoid, but I'd rather have that than rubbing.
    You might have to, everyones truck sees different results. Keep me updated.
  5. Dec 27, 2014 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRC, Icon has 700# springs available, so you might want to consider getting those. The stock springs are designed for lift, and maybe a bumper. With a heavy bumper, and winch, you might need the heavier springs.
  6. Jul 30, 2016 at 7:05 PM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    I will be getting stage 4 icons front and rear resi with total chaos upper control arms.. I will be running aal 1.5 rear leaf Springs. Be mind travel icons. My question is what are these icons made for. I do a lot of trails and city driving good way to go.
