Icon Resi Rear shock install
Discussion in 'Technical Chat' started by chris4x4, Mar 26, 2011.
  1. Mar 26, 2011 at 2:47 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Thought I'd throw together a little "How-to" for the rear Resi shock install. Many people think that because you have to drill a mounting hole in your frame, that its not an easy DIY. Truth is, it can be done in less than an hour.
    First, Jack the rear of the truck up, and place a jack stand on the driver and passenger frame rails, about 6" in front of the front leaf spring hanger.
    Then, Remove the rear wheels, and lower the rear axel, until the truck is resting on the jack stands. Leave the jack under the rear axel, as you will use it to raise and lower as needed to install the new shocks.
    With the rear wheels off, you then remove your old shocks.
    Useing the supplied 19mm hardware, install the upper shock mount, then the lower shock mount. My camera guy didnt take pics of that step, but its the reverse of removing the shocks you just took off.
    Then, Hold the resi against the frame where its going to be mounted, while keeping a little slack in the hose. Hold the mounting braket up to get an idea where its going to mount.
    Let the resi down, and hold the mounting bracket in place, and mark the center of the hole to be drilled.
    In the case of the Icons, Use an 11/32 drill bit, and drill 1 hole for the braket bolt.
    Using the supplied 14mm self tapping bolt, bolt the braket to the frame.
    Dont fully toque the bolt, and place the supplied hose clamps in their respected positions. Once the hose clamps are in place, torque the bolt down. There is no torqe setting in the instructions, but I torqued to 30 ft-lbs.
    Place the resi in the braket assembly, aligning the recessed portions of the resi with the hose clamps. Using an 8mm socks, tighten down the hose clamps until the resi is snug.
    repete for the other side. Then, throw the wheels back on, remove the jack stands, lower the truck, and enjoy!
  2. Mar 26, 2011 at 2:50 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    jealous
  3. Mar 26, 2011 at 2:53 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    How close is that hose to the bump stop bracket?
  4. Mar 26, 2011 at 2:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A little coomparo of the Bilstien 5100's to the Icon's
  5. Mar 26, 2011 at 2:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    About 1/2" to 3/4"
  6. Mar 26, 2011 at 2:57 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Good to know
  7. Mar 26, 2011 at 2:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is quite a bit of movement in the hose, so there wont be any issues with getting too close, or rubbing. Also, the hose has an anti wear nylon sleave to add protection.
  8. Mar 26, 2011 at 3:03 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    On my setup there's plenty of clearance if you want it. Granted, I have the older 2.0s, whereas these appear to be new 2.5s IVD just came out with.
    Anyway, nice write-up Chris. I think a lot of people underestimate how easy this install is.
    Only thing I did different on mine was forgo the self-tapping bolts in favor of a nut-bolt combo because I felt it was more secure.
    EDIT: NM, those look like Chris's tires...
  9. Mar 26, 2011 at 3:05 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That's 4x4 rig.
  10. Mar 26, 2011 at 3:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought about going with an Nut/bolt instead, but for the sake of the write up, I wanted to use all the parts included. And Correct. Those are the 2.5's.
  11. Mar 26, 2011 at 4:27 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
  12. Mar 26, 2011 at 4:36 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Do You notice a difference between the ride of the 2 shocks?
  13. Mar 26, 2011 at 4:57 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Man those look sick. (Also jealous)
  14. Mar 26, 2011 at 5:07 PM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Thanks for the writeup. I will be installing these in the next few weeks.
  15. Mar 26, 2011 at 5:10 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    *axle
  16. Mar 26, 2011 at 5:10 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Chris...your truck looks bad ass man!
  17. Mar 26, 2011 at 5:15 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    nice :thumbsup:
  18. Mar 26, 2011 at 5:27 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    hows the ride feel on those icons chris?
  19. Mar 26, 2011 at 5:50 PM
    jandrews
    Not Chris, but my feedback with the 2.0s is that ride is improved, but without swapping out to a different leaf pack, things only change so much.
  20. Mar 26, 2011 at 6:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I actually havent had a chance to take it out yet :eek:. Im hoping either Monday, or Tuesday.
