Icon RXT Leaf Pack Install (stage 3)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Beakerman, Nov 8, 2021.
  1. Aug 28, 2022 at 12:35 AM
    #61
    Danieldee
    Danieldee Well-Known Member
    Daniel
    2015 Tacoma TRD
    What option did you end up going with? 2?
  2. Nov 26, 2022 at 2:05 PM
    #62
    Nemesis-dsl
    Nemesis-dsl Well-Known Member
    21 Trd Sport.
    @71tattooguy thanks for this. I just got the RXT leaf pack and figuring out what stage to go with. I’m also ordering 6112/5160 as well. What setting on your 6112? 2” max setting?
    71tattooguy[QUOTED] likes this.
  3. Nov 27, 2022 at 8:11 PM
    #63
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Yes I’m at 2” of lift with the 6112’s love the set up. You will love the leaf pack
    Nemesis-dsl[QUOTED] likes this.
  4. Nov 27, 2022 at 8:17 PM
    #64
    Nemesis-dsl
    21 Trd Sport.
    So would you say you are at 23" in height from center of hub to fender in front and 25" in the rear?
    And to confirm you are on the highest setting on the 6112 and Stage 2 on RXT. Your ride isnt a bit stiff? I heard 6112 compressing the springs to the 2" setting will make daily driving over little bumps a bit rough.
  5. Nov 27, 2022 at 8:21 PM
    #65
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I’ll have to measure again. I recently changed to option 3. I like to maintain rake when loaded. Option 2 was great but I plan on adding a few things so I bumped it up. As far as the 6112’s. Ride quality is very subjective. For me I love my set up. Wouldn’t changed a thing. I’m running 255’s pizza cutter , I run about 34psi my commute is super short I’m stoked no complaints.
  6. Feb 8, 2023 at 12:20 AM
    #66
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    Would option 3 be too stiff for daily driving if I only have under 200 pounds in the bed? I am mostly wanting option 3 for the extra inch of lift since I want to maintain some rake with 3" lift up front when loaded. Currently on option 1 but my front is slightly higher than the rear so I'm thinking maybe jump straight to option 3 because the bed sags more when loaded. The bed does get loaded up to 400+ pounds on the weekends (5 mountain bikes + gear and tools) however I just hope option 3 won't be too stiff driving around town without much load. I guess if I want the springs stiffer for weekend bike shuttling I will have to suffer during the week when it's not loaded. :notsure:
  7. Feb 8, 2023 at 12:32 AM
    #67
    Danieldee
    Daniel
    2015 Tacoma TRD
    For me I don’t think so. I’m on stage 3 with a constant 180/190 lbs.
  8. Feb 8, 2023 at 5:39 AM
    #68
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Option 3 won’t be stiff at all. 3 inches up front I’d be worried about cv angles
    fullsend604[QUOTED] likes this.
  9. Feb 8, 2023 at 10:38 PM
    #69
    fullsend604
    Glad to hear, sounds like stage 3 will be the choice for me!
    Not too concerned about CV, they'll go when they go it's a wear and tear part as I've had to replace them on both of my previous Tacomas. I will be replacing with RCV Ultimate IFS CV axles, way stronger than stock and lifetime warranty.
    https://www.rcvperformance.com/ulti...14-4-runner-03-present-tacoma-05-present.html
    Here's how they currently sit with 3 inches up front (6112's max setting with 1/2" spacer).
