Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. May 8, 2025 at 1:33 PM
    #2481
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    Mine do the same, I wash them and spray them all the time. I'm gonna try the bike tire or actual liner. The radio has been my solution that works best
  2. May 8, 2025 at 1:40 PM
    #2482
    Gord0
    Gord0 Well-Known Member
    Initially mine were making noise from two points, the brackets that wrap the sides of the leafs were rubbing and of course the bushings…
    The spring brackets are an easy fix. Stupidly I did the bike tube thing before looking more closely at the brackets. The inner tube thing was a waste of time for me.
  3. May 8, 2025 at 1:56 PM
    #2483
    Tronfunkblow
    California
    Good to know thanks!
  4. May 15, 2025 at 10:16 AM
    #2484
    Tronfunkblow
    California
    After the last trip with the rxt's I've realized additions add quickly and I'm maxing them out. Fully loaded I'm at or above the 600lbs mark, with the Topo Topper taking about 1/2 of that. We have a couple planned additions, sliders, solar and some day a rear bumper so needless to say I'm gonna need to beef it up a little. I will say even maxing them out the the rxts still handle the weight like squeaky champs.
    On daily drive mode I'm right around 24" hub to fender. Fully loaded I'm around 23.25, which is as advertised and gives me about 0.5" of rake
    Has anyone customized these by adding additional leaves to the pack? I have scrap leaves from my oem + AAL and a few extras from a franken-pack I was planning on building before the rxts. (I know this is a band aid until I can jump to Deavers and I'll say it for you "buy once, cry once.") Just curious if anyone has done it.
  5. May 25, 2025 at 7:29 PM
    #2485
    Erick villatoro
    Erick villatoro Active Member
    Erick
    2022 Army green taco TRD off road 4X4
    Could I use my fox 2.5 rear shock that only reaches 1.5 lift on the rear or would this leaf springs he too big?I’m new to lifting and i can’t seem to figure out if i can use my 1.5 rear lift with the leafs front would be 2.5 and rear 1.5
  6. May 26, 2025 at 7:11 AM
    #2486
    Erick villatoro
    Erick
    Would they also work with the 1.5 lift rear ones?
  7. May 26, 2025 at 7:15 AM
    #2487
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The leaf springs and shocks will "work" together in that the shocks will go into the position. However, available downtravel is going to be quite limited due to the shock being near full extension at rest. They can be paired up, but know that ride quality and performance is going to be impacted due to articulation being limited.
  8. May 26, 2025 at 7:17 AM
    #2488
    Erick villatoro
    Erick
    Do u know any where that wouldn’t be a problem I’m new to this whole lifting thing and I don’t really understand this part of the lift
  9. May 26, 2025 at 7:22 AM
    #2489
    memario1214
    Colton
    Missoula, MT
    I'm not sure what you mean. There's realistically 3 options here:
    1. Pair the Icon RXT with your 0-1.5" Fox shocks. You'll have limited downtravel as I had mentioned, but uptravel will not be negatively impacted.
    2. Either don't lift the rear or don't lift it so high. Staying within the range of your current Fox shocks will allow for ideal articulation values.
    3. Add the Icon RXT leaf packs, but purchase a longer shock as well in the rear that is intended for the resting ride height of your new leaf packs.
    Tronfunkblow likes this.
  10. May 26, 2025 at 7:26 AM
    #2490
    Erick villatoro
    Erick
    I meant if u know any other leaf pack that would let me lift it 1.5 inches with no issue also u mean by longer shock like one that lets me lift it up to like 3 inches? And by not to high maybe like an inch right?
  11. May 26, 2025 at 8:04 AM
    #2491
    memario1214
    Colton
    Missoula, MT
    Something like this, while not a full replacement, will bring your spring rate down a bit and bring your ride height up the 1.5" that you're looking for.
    https://hotshotoffroad.com/collecti...f-blocks/products/add-a-leaf-kit-05-23-tacoma
    Aside from that, you could always get a custom leaf pack produced, but you'll need to be prepared for a $1200-1500 price point.
    Also, just for a quick lesson that might help you understand what's going on back there. The first given here is that shocks do not provide any lift by themselves, so all we are trying to do is match their length with the amount of lift/articulation that is occurring in the rear. When it comes to rear shock selection what we are trying to do in a perfect world is nail a few metrics:
    1. Shock length is short enough to ensure that during the compression cycle the bumpstop fully compresses/stops the axle before the shock bottoms out. Too long of a shock will bottom out, and will dramatically reduce the life of the shock.
    2. Shock length is long enough to be able to make use of the droop available via the leaf pack. This is important for maintaining power delivery/control traction as the suspension cycles. Too short and the shock will stop out the available stroke of the suspension. While not "dangerous" it's just less than ideal for comfort and performance.
    All that said, you can take solace in knowing that we almost never get it "perfect". Generally, we'll err on the side of going too short on shocks to ensure that the shock will live a long life, and not experience a blowout at the seal, a bent shaft, etc. Rear Fox shocks for Tacomas run notoriously short. Their 0-1.5" lift shock is actually shorter than a standard Bilstein 5100 and even the TRD Offroad 4600s. Going all the way up to nearly 2" of lift out back with a shock that I think should be a 0" lift shock just leaves your setup in a position for very little available travel downward, and a compromised ride profile as a result.
  12. May 26, 2025 at 8:09 AM
    #2492
    Erick villatoro
    Erick
    I’ve seen that AAL but I’ve been told not to do it because it’s just not good all around that’s why I just didn’t go for it and started looking for a leaf that would fit but do u know where I could get a custom leaf made ? I just wanna see if I would do it
  13. May 26, 2025 at 8:16 AM
    #2493
    memario1214
    Colton
    Missoula, MT
    A full replacement leaf pack is always going to be the more premium option. That said, if you're unladen and have just the lift height request, there's nothing wrong with the kit I linked. Unlike AALs of past, these new kits are what's known as "mini-packs". They provide lift while bringing down the spring rate because they remove the overload spring. The AALs of days past were a single piece of metal that would go inline to your existing leaf pack with no other changes. I don't recommend them is because they provide the lift by increasing spring rate. That's no fun for ride quality.
    If you do want a custom pack, companies like Deaver or Alcan can make something like that happen.
  14. May 26, 2025 at 8:20 AM
    #2494
    Erick villatoro
    Erick
    Okay thank u ima explore the custom leaf and see if I go for it thx a lot
  15. May 26, 2025 at 8:44 AM
    #2495
    Tronfunkblow
    California
    I think another important aspect of this is what is you goal. Is it just looks or are you trying to build an offroad performance rig. If its just for looks then go with an AAL like what @memario1214 said, if you are trying to add all kinds of weight and build a performance oriented vehicle then go with a custom pack. However, if that's the goal you might want to change up the rear shocks to get you better rear set up all around. I went from 5100s and an AAL to MT64s and the icon leaf pack which isn't top end but it was enough to really notice the difference. Especially with weight added.
  16. May 26, 2025 at 8:49 AM
    #2496
    Erick villatoro
    Erick
    I want my build to be able to handle almost anything I don’t plant on carrying anything on the rear other than maybe a spare tire and maybe a recovery hook fit 33s or 35s lift I wanna do atm is 2.5 front 1.5 rear I wanna be able to off road but also daily it and plan on off road it maybe a couple times a month
  17. May 26, 2025 at 8:57 AM
    #2497
    memario1214
    Colton
    Missoula, MT
    In that case, as @Tronfunkblow has alluded to - With how you use the truck, my opinion here is that you would likely be wasting money chasing down a custom leaf pack.
  18. May 26, 2025 at 8:58 AM
    #2498
    Erick villatoro
    Erick
    Yea I decided to not get it
  19. Jun 11, 2025 at 2:39 PM
    #2499
    Tacolife5
    Tacolife5 Well-Known Member
    Durango, Colorado
    2017 TRD Off Road DCLB
    I've been on option 1 for 4 years now. It settled to be a 1 inch lift over stock with my setup. But I recently towed a 4500lb camper and the following week did a moto trip with about 1050 lbs in the bed. They now sag and are only 0.75 in above stock, measuring 22.75 in from center of hub to fender. I have a DCLB with 150lb sliders, Toyota OEM bed mat, 33 in spare tire under the truck, TRD front skid plate, and about 50 lbs of tools in my truck at all times. I was enjoying the 22in front and 23 in rear height, but since my leaf pack has begun to sag, I can't decide if option 2 will be enough and if I should just go to option 3. Ideally I don't want more than 2in of rake. 1.5in would probably be perfect. Any input from experience would be greatly appreciated!
  20. Jun 11, 2025 at 4:18 PM
    #2500
    Tronfunkblow
    California
    I don't think you'd get more than 2" of rake especially being a long bed and wouldn't be afraid of going option 2, unloaded they claim 2.25" (I assume this to mean empty bed/stock truck) and you've already got around 200lbs in the bed/on the truck. You might be slightly more than 1" but I don't think you're gonna stink bug.
    For reference on how weight changes on mine. I’m on option 3 with around 425 constant load. I also have a long bed, my rear measurement is ~24” hub to fender during daily driving. Upfront I’m around 22.5/75” for ~1.5" rake. When I’m fully loaded with 2 adults, toddler, dog, and gear I loose roughly 0.5” to 0.75" and sit pretty much level or slight squat depending on fuel/water.
    Astroghet and Tacolife5[QUOTED] like this.
