Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Jun 14, 2025 at 11:21 PM
    #2501
    Fullsendcf
    Fullsendcf Well-Known Member
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Sup guys, have read a handful of these pages but haven’t found the info I’m looking for.
    I have a 2018 OR 5ft bed with 4WP sliders (180lbs), Alucab Contour canopy (126lbs), 33in spare underneath (63lbs) , and a constant set of bins with supplies (30lbs).
    I currently have the Eibach pro truck 1.0 shocks in front and rear. I know the rear can only accommodate 0-1.5” of lift in the rear. My question is if anyone has experience with similar loads or knows if with my set up, stage 1 will compress and settle enough to be at the 1.5” range?
    (Edit) Or…. Just thinking this through after posting. If the weight I have will actually work with stage 2??? Since the canopy, spare, supplies, and sliders (assuming around 1/4 of each slider counts towards total load) would equal around 309lbs. Given it says stage 2 under 200lb load would net 1.75in lift, would 309lb load net closer to 1.5in???
  2. Jun 16, 2025 at 5:55 AM
    #2502
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    IMO with your weight option 2
  3. Jun 16, 2025 at 2:25 PM
    #2503
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Yeah def thought it through after posting and came to this conclusion. Appreciate the reply! You think my Eibachs would suffice for now since my rear weutht will probably end up netting lower that 1.75in of lift
    71tattooguy[QUOTED] likes this.
  4. Jun 16, 2025 at 2:27 PM
    #2504
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I agree with @71tattooguy that you should probably jump straight to Option 2. As for shock length - Eibach rear shocks run longer with others with the same height recommendations. You'll be fine.
    71tattooguy likes this.
  5. Jun 16, 2025 at 2:45 PM
    #2505
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    appreciate the insight! Will grab a pair and throw em on.
  6. Jun 16, 2025 at 2:51 PM
    #2506
    memario1214
    Colton
    Missoula, MT
    I read it as you already have all of the parts that you need! If you're shopping parts, tossing my hat into the ring over here at Hotshot Offroad :wave:
  7. Jun 16, 2025 at 2:56 PM
    #2507
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Your good to go
    Fullsendcf[QUOTED] likes this.
  8. Jun 16, 2025 at 3:01 PM
    #2508
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Oop yup still need to buy. Will def take a look at Hotshot!
  9. Jun 16, 2025 at 3:02 PM
    #2509
    memario1214
    Colton
    Missoula, MT
    If there's anything you are looking for, but don't see, just let me know. I am admittedly not an ace at getting everything uploaded quickly!
  10. Jun 17, 2025 at 1:09 AM
    #2510
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    next 2 questions..
    1. Started going down the rabbit hole of rear shocks and came across switching my rear shocks to the 5125, would those work for my setup even though my net lift would be closer to 1.75in instead of 2-3.5in? Or am I better off just using my Eibachs?
    2. Are extended brake lines needed/recommended here?
  11. Jun 17, 2025 at 7:31 AM
    #2511
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    + 1 on wondering if you need extended brake lines for 5125s.
  12. Jun 17, 2025 at 7:46 AM
    #2512
    71tattooguy
    Dino
    Petaluma , Ca (707)
    IMO it’s a good reassurance
    Fullsendcf likes this.
  13. Jun 17, 2025 at 9:07 AM
    #2513
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    Like @71tattooguy said it's good reassurance, extended break lines are a pretty minor upgrade to have confidence you aren't going to shred your break lines. I'm on option 3 and I haven't had the time to install mine yet. I've been ok offroad but I'm heavy and I've limited my trails because of it and its always on mind. You might as well do it. If the truck is only on pavement then I would say you could get away without it but you'll know pretty quick once installed.
    As for shocks the Eibach is 24.09 (I think) and the 5125s are 24.38 seems like minimal gains to change if they don't need replacing.
  14. Jun 17, 2025 at 9:09 AM
    #2514
    memario1214
    Colton
    Missoula, MT
    Short answer here is that the Eibachs will be OK. The Bilstein 5125 is going to be a bit longer so you're going to capture some more travel, but you're not stroked out on the Eibach at rest so it's not the end of the world either way.
    I always say to do your own droop test to confirm no matter what shock you put in there. However, our installs here have yielded the need for brake line extensions on pretty much all 5125 equipped Tacomas.
  15. Jun 17, 2025 at 9:38 AM
    #2515
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Appreciate it.
  16. Jun 17, 2025 at 2:19 PM
    #2516
    Fullsendcf
    Craig
    SF - Bay Area
    '18 Cement TRD OR
    Thanks for the insight everyone. Thinking I’ll be fine on the Eibachs since with my current setup I have constant 300lbs and will be at 400lbs when I throw my RTT tent on.
    Going to for now just get a set of leafs at option two and wheelers u bolt flip kit to pair with my Perry parts bumpstops.
    Figure it’s best to replace front and rear shocks together anyway, so once I figure out what I want to do with the front I’ll upgrade both and do the extended brake lines.
    Will post updates once everything’s on
  17. Jun 17, 2025 at 2:40 PM
    #2517
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Sounds good!!
  18. Jun 28, 2025 at 4:07 PM
    #2518
    t2006v
    t2006v Member
    Stage 3 deavers for that much stuff you are easy 700# there
  19. Jun 28, 2025 at 5:10 PM
    #2519
    t2006v
    t2006v Member
    Im going option 3 I got off road bumper with full hitch, demello sliders and bud built skids. I usually carry an extra 265/65/r16 with KM3, recovery gear w/60" high lift jack chain bags shackle blocks, rope bag and more if im going for awhile. so Im prob 300# easy. if I need to get bigger stops ill fab something up. if I need 56515R ill get some. I think I on 56503r but I cant find any detail on them that states this although they are set up like 56515Rs with a 4-5 threads up top.
  20. Jul 10, 2025 at 4:37 PM
    #2520
    Tronfunkblow
    California
    Those who've experienced their leaf pack spreading (each leaf not being inline with the other) did you remove U-bolts to straighten them out or just jack the truck up and hammer them back?
