Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Jun 22, 2020 at 12:28 AM
    #541
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Would like to know as well how the liners were placed.
  2. Jun 22, 2020 at 8:13 PM
    #542
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I left the round plastic spacers and brass shims in. I cut the liners just short of the plastic spacers. Probably got 0.4 in. of lift from the liners (1/16" x 7 leafs) heh.
    _gray_knight_[QUOTED] likes this.
  3. Jun 22, 2020 at 8:24 PM
    #543
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Hm ok. By leaving the plastic spacers in contact with the leaves, does that not partially defeat the purpose of the liners? Or am I misunderstanding their application as a means of full contact vs preventing debris from lodging itself between leaves?
  4. Jun 23, 2020 at 4:56 AM
    #544
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Dirt will get in regardless. However, with the liners in place, there's no contact between leafs, so no noise.
    CAG Gonzo[QUOTED] likes this.
  5. Jun 23, 2020 at 9:04 AM
    #545
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    I installed icon leafs last week. Stage 3. I have wheelers off road u bolt flip kit with super bumps. At ride height I have about an 1 3/4 inches before bump contact. Truck isn’t loaded down yet just at normal weight. Can anybody running stage 3 and super bumps check how much clearance they have?
  6. Jun 23, 2020 at 9:45 AM
    #546
    CAG Gonzo
    2018 OR DCLB BarRed
    Maybe I'm missing something, but you only have two leaves there. Stage 3 uses all leaves, I believe.
  7. Jun 23, 2020 at 9:47 AM
    #547
    PB FAB
    2017 SR DCSB 4x4 v6
    I was cycling suspension while setting up and welding new shock mounts on.
  8. Jun 23, 2020 at 10:09 AM
    #548
    CAG Gonzo
    2018 OR DCLB BarRed
    But if you don't have all the leaves on, won't that mean it's not an accurate representation of your actual end result? In the second pic, your leaf is inverted, I'm guessing because it's alone and unafraid supporting a lot of weight.
  9. Jun 23, 2020 at 2:21 PM
    #549
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I think that round spacer cylinder thing he has in there is probably supposed to represent the rest of the leaf pack. If the length of that thing is right, the end result should be the same travel-wise, it will just take a lot more force to reach that level of compression.
  10. Jun 23, 2020 at 3:41 PM
    #550
    CAG Gonzo
    2018 OR DCLB BarRed
    Yeah, that adds up. I'm still confused as to the setup.
  11. Jun 23, 2020 at 7:36 PM
    #551
    PB FAB
    2017 SR DCSB 4x4 v6
    The set up was just to test full compression of the suspension before welding on the shock tabs to the axle housing. The spacer was to simulate the full thickness of the spring pack. I don’t know of any other way to set up a leaf sprung suspension to test travel and make sure the shocks aren’t going to bottom out.
  12. Jun 23, 2020 at 9:46 PM
    #552
    CAG Gonzo
    2018 OR DCLB BarRed
    Gotcha. Only idea I have would be use the full setup and load the bed up. Pile some friends in there.
  13. Jun 24, 2020 at 4:30 PM
    #553
    CAG Gonzo
    2018 OR DCLB BarRed
    I got the liners one one of the packs. It wasn't terrible but definitely annoying trying to reassemble when the liners want to curl up. Had my wife help me when it came to the last two leaves. Was feeling pretty proud of myself when I went to compress. That thing squeaks more than...something that squeaks a lot. I noticed I had the 3rd from top leaf flipped the wrong way so that might be part of it. I'll try to correct tomorrow. But I have a feeling it's gonna still squeak. Is this something that happens until the leaves get nicely broken in? I haven't touched the other pack but compressed it and that doesn't squeak at all.
  14. Jun 24, 2020 at 11:19 PM
    #554
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    I had time today to get the truck lifted and unloaded the springs. Tried all other methods (cleaning/lubing) but suspecting installer had over torqued things while suspension was suspended. Backed off the bolts to all mounting points (front shackle, rear shackle, hanger and the top shock mount). Lowered to let things settled and give a few good bounce and retorqued everything down. 2 days now and not a peep. Not sure if this has solved things for me but we'll see.
    Chase8059 and SR-71A like this.
  15. Jun 25, 2020 at 6:52 AM
    #555
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I've been watching this thread for a few weeks, hopefully icon can start shipping out more RXTs soon so I can re do my rear setup :fingerscrossed:
  16. Jun 25, 2020 at 2:48 PM
    #556
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    Anyone run a shackle flip with their rxts? Would like another inch or 2 of lift in the rear and would appreciate some insight/ experience with that combo.
  17. Jun 25, 2020 at 6:22 PM
    #557
    RETR0spec
    RETR0spec Well-Known Member
    Sacramento, CA
    JDFab +4 LT
    I ordered my set on 5/28 and just got tracking numbers today. I called over a week ago and was told the back order is 3-4 weeks
    MtnFisher likes this.
  18. Jun 26, 2020 at 8:56 AM
    #558
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Do I have to completely remove my leaf spring to swap to option 2? Or can the install be done with leafs mounted?
    in have bamf hangers and it was a SOB to install these..
  19. Jun 26, 2020 at 9:07 AM
    #559
    Chase8059
    Chase
    ESVA
    Cool, mine was placed on 6/1 i think, hopefully not too much longer!
  20. Jul 2, 2020 at 5:44 AM
    #560
    PB FAB
    2017 SR DCSB 4x4 v6
    The icon springs ride great compared to my old set up. Stage three.
