Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Aug 18, 2020 at 6:42 AM
    #581
    MGMStudioTaco
    MGMStudioTaco Member
    Trey
    Charlotte, NC
    2018 MGM Tacoma Limited 4x4
    Grande Tires W/Kings
    Bushing are squeaking on my RXT's on option 2 anyone found a solution to this?
  2. Sep 2, 2020 at 7:19 AM
    #582
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    Hello everyone
    I’m currently on option 1.
    I’m planning going on a trip in one week so trying to decide if I should go to option 2.
    I think that with the camping equipment and coolers I’m going to carry about 150-250LBs and I was wondering if the best option was to go to option #2. I wont be doing any off-Roading just your normal fire roads to get to the campsites.
    If I do need to make the change, do I have to take the leaf springs off the truck ? or can i do it with the help of the C clamp while they are still on the truck?
    thanks
  3. Sep 2, 2020 at 7:40 AM
    #583
    Shellshock
    Iowa
    You’d be fine staying on option 1.
    you might be able to do it on the truck, but I’d just take it off.
  4. Sep 2, 2020 at 9:44 AM
    #584
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    you dont have to completely remove the leaf spring. just have come C clamps, loosen the u bolts and remove those "chingaderas" at the ends. slide out the one leaf and replace it with Opt 2 spring. took me about an hour.
    probably a good time to lube them and install the leaf liners. these things are like a dogs chew toy, squeeky AF.
    chuymoreno likes this.
  5. Sep 2, 2020 at 9:47 AM
    #585
    Shellshock
    Iowa
    Mine are fairly quiet. They will get a little squeaky from time to time if they get full of dirt but usually after a wash they are fine.
    SR-71A likes this.
  6. Sep 2, 2020 at 9:51 AM
    #586
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    im in houston, the humidity and moisture is a killer.. like living in an arm pit
    Island Cruiser likes this.
  7. Sep 2, 2020 at 10:46 AM
    #587
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Lather some deodorant in between the leafs lol
    BRFab and cdex8357[QUOTED] like this.
  8. Sep 2, 2020 at 11:07 AM
    #588
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    quoted for chingaderas.
    Does it matter which leaf gets slid out and replaced?
    Also, what do I do with the C Clamps?
  9. Sep 2, 2020 at 11:11 AM
    #589
    ramonortiz55
    Ramon
    Texas
    stock
  10. Sep 2, 2020 at 11:20 AM
    #590
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I c clamped them to keep them together when I removed the center Bolt on the leaf pack.. then exchanged the leafs and aligned them up and c clammed them. Put Center bolt back and chingaderas. Jacked the axle up to the leaf and installed u bolts
    PB FAB and Island Cruiser like this.
  11. Sep 7, 2020 at 8:38 PM
    #591
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    Hey everyone! I just installed the Icon RXT leaf pack. I'm currently running option 2 with tundra fox 2.5 with dsc and I'm getting 24.75" center hub to fender. My truck is stock. This is about 2.75" of lift in the rear. I was expecting 2.25" as per Icon documentation. Is this normal?
  12. Sep 7, 2020 at 9:27 PM
    #592
    Island Cruiser
    Kauai
    Baja
    It will settle over time. I think mine on Option 1 settled about half an inch
    Tacompa[QUOTED] likes this.
  13. Sep 7, 2020 at 10:25 PM
    #593
    Tacompa
    San Jose, CA
    @Island Cruiser I think I'm going to tow my dump trailer around to help it settle.
  14. Sep 16, 2020 at 4:31 PM
    #594
    Tacompa
    San Jose, CA
  15. Sep 16, 2020 at 5:58 PM
    #595
    Island Cruiser
    Kauai
    Baja
    From center of hub to bottom of fender:
    Driver’s side: 23 3/4”
    Passenger’s side: 24 1/4”
    I wish I jotted down if I had a full tank of gas in my notes, but it was definitely at least a half tank of gas
  16. Sep 16, 2020 at 7:32 PM
    #596
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    I have used these at all 3 levels for one reason or another.
    Started with no weight on level 1. Changed to 3 when we thought we were going to get a slide in camper, which didn't work out. Settled on 2 since we have about 300-400# of bumper, winch and armor with a Rtt and gear when we can.
    They all ride nicely, almost soft and supple while over all fairly similar from the seat. The height though is not similar at all. 3 with no weight in the back is up there stink bug style.
    It's a nice set of leafs with choices.
    What more could one ask for?
    Tacompa and Nomad26 like this.
  17. Sep 17, 2020 at 11:55 PM
    #597
    Tacompa
    San Jose, CA
    @Island Cruiser thanks for sharing.
    I'm currently running option two with no extra weight (and Tundra Fox 2.5 w/ DSC). I have hub to fender measurements in the rear of 25" driver and 24.75" passenger. I still have to fine tune the front. I'm considering going to option #1. Based on your response, I should still be able to get ~2" lift in the rear on option #1. I'm so thinking if won't be as stiff.
    What are your thoughts?
  18. Sep 18, 2020 at 12:11 AM
    #598
    Tacompa
    San Jose, CA
    @BRFAb the only thing I would ask for; is that I knew exactly what I wanted and to have beforehand experience with this leaf pack. I'm new to lifted trucks. It's a learning experience and l'll have to make adjustments as I go until I am satisfied with the results.
  19. Sep 18, 2020 at 1:12 AM
    #599
    Island Cruiser
    Kauai
    Baja
    That’s good to know, I’ve always wondered what Option 2 would be like without extra weight in the back. I’d say move down to Option 1 as long as you know for sure you won’t be adding substantial weight. I have loaded some power equipment, toolbox and etc. with this option and didn’t notice much of sag. It did soften up the ride as expected. What are your measurements up front?
  20. Sep 18, 2020 at 10:04 AM
    #600
    Tacompa
    San Jose, CA
    I don't think my leaf pack has settled yet. It still much higher than I expected.
    Fronts are 23.5" driver side and 23.75" passenger side. I'm bringing that down <= 23" as soon as I get some time. I figure this is also adding to the rear height. The good news is I WFH so its not a DD. I'm starting to realize that the best ride quality will not be a 3/2 lift. I have to find the balance between max lift height and ride quality. I foolishly thought I could get both.
