Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Dec 10, 2021 at 6:09 PM
    #1041
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    3 if you’re keeping all of that in the truck 24/7, considering the bumper
    jonnytacoo[QUOTED] likes this.
  2. Dec 12, 2021 at 4:04 PM
    #1042
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just had the Icon stage 8 installed. Truck rides great... no vibes!! Went with the factory setting on the coilovers (2" of lift) and option 2 on the rxt leaf pack. With the weight of a snugtop canopy and 2 bags of sand in the back the rear is 2" higher than the front. I like the factory rake look and expecting to get close to a 1.75" rake after things get settled. Will post a few pictures when the weather gets better. Hub to fender front 22"/hub to fender rear 24".
    DavesTaco68, jonnytacoo and Boomtime like this.
  3. Dec 14, 2021 at 10:11 AM
    #1043
    jonnytacoo
    jonnytacoo Well-Known Member
    Jonny
    So Cal
    2018 TRD Off-Road 4x4
    OEM
    I may wait to install the leafs closer to when the bumper it going on.
    BUT IM GO OPTION 3
  4. Dec 18, 2021 at 11:45 PM
    #1044
    TacoGuySlo10
    TacoGuySlo10 Well-Known Member
    Tristan Torres
    san luis obispo
    2019 MGM trd off road
    Hi guys! lookin for some advice… installed my icon leaf pack a couple of weeks ago. at first no squeaks or any noise. now after about 450 miles i’m getting a creaking type of noise on passenger side. it’s not a squeak, but a creak. i’m guessing it’s coming from the shackles? i did go in the sand dunes and after that is when it started to make the noise. only makes that noise when i compress it. thanks!
  5. Dec 18, 2021 at 11:46 PM
    #1045
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    Should i spray silicone on the shackle? or just the springs?
  6. Dec 19, 2021 at 7:28 AM
    #1046
    Boomtime
    Boomtime Active Member
    2021 CGM Tacoma TRD OR
    I got a creaking sound after I went from option 3 to 2. It was on the passenger front bushing. I knew that was the spot because I went under the truck and rocked it and that's where I heard it. I loosened the bolt and sprayed the hell out of it with motorex motorcycle chain lube and with the bolt loose I bounced the truck up and down to work the lube in then I tightened it up. It still creaked but after driving a bit now I don't hear it so I'm guessing the lube worked it's way in some more.
    tonered likes this.
  7. Dec 19, 2021 at 12:58 PM
    #1047
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I used Dobinsons greasable shackle bolts for the front and rear of the packs. Stuffed em with some Amsoil grease and haven't heard a peep. Also used leaf liners in between every leaf. I don't off road much but it's always dusty where I live.
  8. Dec 20, 2021 at 3:55 AM
    #1048
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Wouldnt hurt to flex it out to release pressure on the leafs, spray it out with a pressure washer to get the sand out, then hit it with some silicone spray or get some grease between them. Would beat removing them and tearing them apart and cleaning them.
  9. Jan 4, 2022 at 10:19 AM
    #1049
    TacoGuySlo10
    Tristan Torres
    san luis obispo
    thanks for the help guys, but after close inspection and spraying them with silicone spray, i noticed that they are both on backwards… very unfortunate, have to take it back to shop to get it done again
  10. Jan 4, 2022 at 10:29 AM
    #1050
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    What?
    You might just wanna let the shop know about their mistake and swap them yourself. Not a difficult job if you have a jack and jackstands.
    AStinkyBumb likes this.
  11. Jan 7, 2022 at 9:09 AM
    #1051
    Stagger Lee
    Stagger Lee Well-Known Member
    NorCal
    2015 Tacoma TRD OR 4x4 6spd
    I’ve been researching and I’m pretty sure I’m going to go with these to replace my Icon AALs.
    I’m running Bilstein 5160s and will have these set on either 1 or 2. Do I need to get larger bump stops or add a bump stop spacer? Anyone with this set up out there upgrade theirs?
    71tattooguy likes this.
  12. Jan 7, 2022 at 9:11 AM
    #1052
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It depends on the compressed length of your shocks compared to stock. If you didn't need them for the 5160s to start with, I do not believe you will need them when swapping in the leaf packs.
    The body length of my stock Hitachis was the same as the extended travel 5125s, so I left the stock bump alone. Been flexed out many times since with no issue. Nothing high speed though that would really compress the bump from a hit.
  13. Jan 7, 2022 at 9:12 AM
    #1053
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    IMO get a UBOLT flip kit looks super clean and bump stops are much larger than stock. I went super bumps but plenty of kits out there to choose from.
  14. Jan 7, 2022 at 9:21 AM
    #1054
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Still waiting on my leaf pack :playball:
  15. Jan 7, 2022 at 9:27 AM
    #1055
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was February, right? That's coming up fast.
    :fingerscrossed:
    71tattooguy[QUOTED] likes this.
  16. Jan 7, 2022 at 9:28 AM
    #1056
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Sounds like some of you with vibes just need to try a 1pc driveshaft, Tom Woods or similar.
    Kolter45 and MGMDesertTaco like this.
  17. Jan 7, 2022 at 9:30 AM
    #1057
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Yes!!!! :)
    tonered[QUOTED] likes this.
  18. Jan 7, 2022 at 9:31 AM
    #1058
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Pretty soon, it will be summer! :laughing:
  19. Jan 7, 2022 at 9:35 AM
    #1059
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Check the torque on your u bolts.
  20. Jan 7, 2022 at 9:36 AM
    #1060
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :thumbsup:
