Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Feb 28, 2022 at 6:48 PM
    #1081
    COToycoma
    COToycoma Active Member
    2007 DBL Cab TRD 4x4 => 2018 DBL Cab TRD 4x4
    Front leveling spacers, 17" wheels, work in progress for Overlanding, towing and off-roading
    Received my RTX leaf pack after I long wait (although not as long as origianlly thought) have Fox shock that I am going with front (C/Os) and adj 2.0 performqnce in tht rear. I will olny get about 2.25 inch lift in front. I was going to go option 2 on leaf packs as I will have a little weight (~110 lbs) in th rear and we tow a small ~1800 lbs tear drop trailer. Tryig to find best balance of off road capability and some/little load carying.
    However, the back end lifted the same as front ~2.25 inces migt be a bit too much. Thoughts?
  2. Feb 28, 2022 at 8:06 PM
    #1082
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The main reason i went with option 2 was the weight of the canopy/bed mat/ and 100-150 lbs of gear. In winter i load up 200 lbs of sandbags and in the summer i tow a 15' fishing boat. Also, i've read here that the leafs at option 1 go flat fairly quick with weight.
    71tattooguy likes this.
  3. Feb 28, 2022 at 8:10 PM
    #1083
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Exactly why I’m going option 2 as well. While loaded with camp gear I still want rake. :thumbsup:
  4. Mar 1, 2022 at 5:53 AM
    #1084
    veedo
    veedo Well-Known Member
    Anyone know who has these in stock right now?
  5. Mar 1, 2022 at 5:56 AM
    #1085
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The backorders run pretty deep right now... I would expect to see in-stock notifications from us here at Hotshot Offroad late this month. We have a backlog of orders to take care of first, but if my math is correct we should have a few sets left. That said, Icon has been missing promise dates pretty regularly so I won't hold my breath!
  6. Mar 1, 2022 at 5:56 AM
    #1086
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Where you located? ;)
  7. Mar 1, 2022 at 6:04 AM
    #1087
    veedo
    Michigan
  8. Mar 1, 2022 at 6:30 AM
    #1088
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :cheers:
    :rasta:
    memario1214[QUOTED] likes this.
  9. Mar 1, 2022 at 6:45 AM
    #1089
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    There are some available on eBay right now
  10. Mar 10, 2022 at 7:49 AM
    #1090
    veedo
    Could anyone with a 16+ double cab short bed with rxts on option one tell me what their hub to fender measurement is? Just trying to figure out what to expect as far as lift, and how bad my factory springs are sacked out. Thanks.
  11. Mar 10, 2022 at 8:21 AM
    #1091
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    I’m running kings ext and rxt stage 3 with about 450 lbs load (canopy, decked drawer and gear). I have a slight rake but sit perfectly imo, because if I throw more gear in or add a tent, I will be fine.
  12. Mar 12, 2022 at 3:59 PM
    #1092
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Just got these in…how does one differentiate front versus rear of the springs?
  13. Mar 15, 2022 at 10:58 PM
    #1093
    71tattooguy
    Dino
    Petaluma , Ca (707)
    You get your answer?
  14. Mar 15, 2022 at 11:05 PM
    #1094
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
  15. Mar 16, 2022 at 2:50 AM
    #1095
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yep, someone had posted it above and also the next post after yours. Easiest way was how someone else said it, two brackets to the front.
    71tattooguy[QUOTED] likes this.
  16. Mar 16, 2022 at 4:58 AM
    #1096
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :thumbsup:
  17. Mar 16, 2022 at 7:03 AM
    #1097
    71tattooguy
    Dino
    Petaluma , Ca (707)
    just set these up for option #2 install tomorrow. Will report back numbers. DCLB
  18. Mar 16, 2022 at 12:48 PM
    #1098
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Anyone have ground to fender and hub to fender measurements for DCLB just curious. Also in 32’s current ground to fender with aal 38 1/4 roughly
    4xThad and DavesTaco68 like this.
  19. Mar 16, 2022 at 12:55 PM
    #1099
    GOROAM
    19 TRDOR
    Crawling Malls
    I feel like several people in here are nuking the RXT installation. Instead of trying to determine how much lift you will get based on measurements from another rig, why don’t you follow the chart from Icon that breaks down specifically what stage you should run based on weight?
  20. Mar 16, 2022 at 1:01 PM
    #1100
    71tattooguy
    Dino
    Petaluma , Ca (707)
    I am just curious!! :evil:
    DavesTaco68 likes this.
