Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Mar 16, 2022 at 1:03 PM
    #1101
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    i mean, is it really that difficult?
  2. Mar 16, 2022 at 1:03 PM
    #1102
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    100lbs wont even phase the RXT pack. I'd keep it at op 1. I've had a few hundred lbs back there and it barely even brought it down. Also got more lift than advertised at Option 1 (installed in November) and it's still higher than advertised.
  3. Mar 16, 2022 at 1:05 PM
    #1103
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    It’s not Thanks Homie :rasta:
  4. Mar 16, 2022 at 1:07 PM
    #1104
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    This is what I needed to hear.
    I don’t have the factory spare, but will be throwing a 34” tire/wheel back there from time to time.
    I have a Swingcase with about 30lbs of recovery gear on the passenger side.
    I have an aftermarket bumper that is about 20lbs heavier than stock.
    So maybe about 100lbs over stock occasionally, and more like 50lbs most of the time. Going option 1 to get her SMOOTH
  5. Mar 16, 2022 at 1:28 PM
    #1105
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Should be nice. I have my 285 under the truck + the OE bed pad (so + 35lbs maybe?) and still ~2.1" of lift back there when it was advertised at 1.85" without weight (which I'm not super happy about - that was already higher than I really wanted it). I have heard it takes a few months to settle but damn. It has at least finally started breaking in because it is noticeably softer than it was originally. Going to wait to see if it breaks in any more over the next few months or if I need to send my shocks back again for a second revalve. This pack flexes fantastically but feels like it rebounds way too fast. Not sure if it's the pack or shocks though - probably the shocks but still going to hold out a bit and see what happens. Only have about 900 miles + 1 wheeling trip on the setup so far as the truck isn't the daily.
    COToycoma likes this.
  6. Mar 16, 2022 at 3:21 PM
    #1106
    GOROAM
    19 TRDOR
    Crawling Malls
  7. Mar 16, 2022 at 3:24 PM
    #1107
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :bananadead:
  8. Mar 16, 2022 at 3:28 PM
    #1108
    GOROAM
    19 TRDOR
    Crawling Malls
    Isn’t that neat? Icon even specifies in inches, lift over stock measurements so you don’t need to ask joe schmo to measure his hub to fender!
  9. Mar 16, 2022 at 5:36 PM
    #1109
    71tattooguy
    Dino
    Petaluma , Ca (707)
    :oldglory:
    I’m stoked to get my leaf pack on. I ask a question and you advise nothing. Your a dick period.
    Bye
    OffroadToy likes this.
  10. Mar 16, 2022 at 5:54 PM
    #1110
    GOROAM
    19 TRDOR
    Crawling Malls
    you ask a question that has been discussed repeatedly!!! For the love of God, Icon makes this retard proof with their chart and installation instructions. How hard is it?
  11. Mar 16, 2022 at 6:25 PM
    #1111
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Don’t be a cock to others then report it. It’s getting rather old. It sure is a lot easier to just say nothing or actually contribute to the community.
    BRFab, Hook78, CAG Gonzo and 6 others like this.
  12. Mar 16, 2022 at 7:01 PM
    #1112
    veedo
    veedo Well-Known Member
    People ask because the results are all over the place. Stock trucks measure different right off the lot, so Icons numbers aren't set in stone. Just look up about 10 posts and you'll see one of many examples. I'll be installing some in the next month or so, and I'll report back with hub to fender measurements.
  13. Mar 16, 2022 at 7:19 PM
    #1113
    GOROAM
    19 TRDOR
    Crawling Malls
    well, if there are so many variables, how is someone taking a measurement of their rigs more accurate than what Icon has compiled based on all their data?
  14. Mar 16, 2022 at 7:29 PM
    #1114
    veedo
    Removing the OEM leaf variance from the equation. Finding a guy that has the same body truck, similar weight, and the rxts set at the same option. I'd think you could get pretty close, depending on if there's any variance in the icon springs.
    71tattooguy likes this.
  15. Mar 17, 2022 at 6:31 AM
    #1115
    Built4TheHunt
    Built4TheHunt Bass Fishing and Bowhunting...
    Gavin
    Downstate Illinois
    16 QS DCSB TRD OFFROAD
    I ordered a 6112/5160 Bilstein lift w an Icon 1.5 add a leaf. I have an ARE truck cap and I tow a 20ft bass boat on the weekend. The cap is heavy but the bed is rarely loaded down. I should opt for the RXT leaf pack right? From reading seems like the right move.
  16. Mar 17, 2022 at 6:40 AM
    #1116
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    I’m at about 1,500 miles on my RXTs at option 2 and have been super happy with them so far. Definitely lifted a bit more than I expected with the constant weight I have in the bed, about 330ish pounds, but it seems to have settled into a nice height.
    71tattooguy and PinStripes like this.
  17. Mar 17, 2022 at 9:11 AM
    #1117
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    I’d go with RXT leaf pack in option 2
  18. Mar 17, 2022 at 1:03 PM
    #1118
    YungSchmuck
    YungSchmuck Active Member
    SoCal
    2020 DCSB OFFROAD BILSTEIN 6112 / 5160, ICON RXT Leaf Pack, JBA UCA
    Victory 4x4 roof rack RCI rock sliders Custom Bed Bars Bilstein 6112s Bilstein 5160s JBA UCA CB Drop Kit ECGS Bushing
    Waiting on my front suspension coming next weekend. Would it be okay to install some 5160s in the rear and my icon RXT (option 2) at static bed weight of 150lbs without front lift installed for a week?
  19. Mar 17, 2022 at 1:12 PM
    #1119
    maxus
    maxus Well-Known Member
    2017 TRD OR DCSB V6 MT
    I've been looking at these as well. Between the Leer shell, Truckvault, and the flatbed trailer I pull quite a bit, I think opt. 2 is the way to go for my specific uses. Just have to suck it up and spend the money.
    Factory spring packs are pretty much flat (no arch).
  20. Mar 17, 2022 at 2:11 PM
    #1120
    GOROAM
    19 TRDOR
    Crawling Malls
    :playball:
