Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. May 14, 2022 at 7:46 AM
    #1301
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I had a bit of squeaking about 5k in. It eventually went away and that are sneaky quiet.
    I used a needle tip on a grease gun to get oil between the six rubber bushings and the mounts. I think that helped once it worked it's way in and around?
    3dpilot and dcarcagno like this.
  2. May 14, 2022 at 7:53 AM
    #1302
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Anyone running option 1 or 2 that would be willing to sell me your extra hardware n stuff to go to option 3? Don't need the leafs.
    Thanks
  3. May 14, 2022 at 9:44 AM
    #1303
    dcarcagno
    dcarcagno Well-Known Member
    Seattle, WA
    2021 TRD Sport MGM
    I didn’t grease in between the leafs. Just the bushings.
  4. May 14, 2022 at 9:53 AM
    #1304
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    71tattooguy likes this.
  5. May 14, 2022 at 10:23 AM
    #1305
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Are these what you’re looking for? If so, I have mine that I’ll probably never use
  6. May 14, 2022 at 10:32 AM
    #1306
    boostedka
    James
    NM
    Forgot the pic:
  7. May 14, 2022 at 10:40 AM
    #1307
    AllTacosFloat
    Boston ish
    Pm inbound
    boostedka[QUOTED] likes this.
  8. May 14, 2022 at 10:44 AM
    #1308
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Option 3 might come in handy if the leafs ever sag or you add weight to the truck...
  9. May 14, 2022 at 10:53 AM
    #1309
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    What are these? I didn't get these, just the two leafs, but haven't had them installed yet?
  10. May 14, 2022 at 2:06 PM
    #1310
    memario1214
    Colton
    Missoula, MT
    You should have had parts bags wrapped around one end of each of the leaf packs. Were they not on either of them?
  11. May 14, 2022 at 2:27 PM
    #1311
    BattleKat
    San Diego
    OK just unwrapped one and yes it is there and I can feel the other one under the wrap on the second leaf.
  12. May 14, 2022 at 3:06 PM
    #1312
    TheSortaHawaiian
    TheSortaHawaiian Well-Known Member
    21 Lunar Rock TRD Pro
    I had someone tell me a few weeks ago that the icon rxt's somehow are more prone to rusting than an OME leaf pack. True or false? I'd assume their basically the same materials and both are painted....so not sure how one rusts more than the other. Skeptical me says it was to try to sell me some OME packs even though I told them I already have the icons...even after mentioning I'm going to wollwax them they still went with "rust"
  13. May 14, 2022 at 5:20 PM
    #1313
    itz so salty
    itz so salty Well-Known Member
    '21 DSCB OR 4X4
    My shit's squeaking like a mofo and I've barely had them on for any period of time.
  14. May 14, 2022 at 5:43 PM
    #1314
    AllTacosFloat
    Boston ish
  15. May 14, 2022 at 8:15 PM
    #1315
    OffroadToy
    RXT Option 2. After 5 months of having the weight of a SnugTop canopy and 200lbs of sandbags I removed the sand today and the leafs didn't appear to settle much. So far i haven't heard any squeaks. I had a very slight shudder at take off... dropped the carrier bearing about a 1/8" and it completely went away.
    update: just had the boat hooked up (250lb tongue weight) and the truck didn't move... at all! :woot:
    3dpilot, 71tattooguy and Eaux8Taceaux like this.
  16. May 14, 2022 at 10:19 PM
    #1316
    Jadamjr
    Jadamjr Well-Known Member
    Jonathon
    Phoenix,AZ
    2017 DCLB TRD OR
    Hey man do you happen to be in Phoenix?
  17. May 15, 2022 at 12:39 PM
    #1317
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    West of Phoenix. Sold the pack though. What's up?
  18. May 15, 2022 at 12:47 PM
    #1318
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Just cleaned my extra leaves in preparation for option switching. With the weight I have in the back, option 1 packs are nearly flat and there's less than an inch to the bumpstops. If unloaded option 3 is 2.625", and 600lb option 3 is 1.875", I figure 200lbs at option 3 would be a good middle ground to still retain some lift once the pack settles again.
    Could I expect the ride to be noticeably harsh at this configuration? I think I'm willing to take a bit of a hit in ride quality (as in don't need it super plush) if it means I don't have to tear these packs apart again.
    bruv likes this.
  19. May 17, 2022 at 7:29 AM
    #1319
    Browner
    Browner Well-Known Member
    Shawn
    Central Iowa
    2020 TRD OR
    Prinsu Rack, CBI Sliders, UpTop Truss Rack, Softtopper, TRD OEM 2" Lift, SCS Rims, Wildpeak tires, OVS RTT and 270 Awning, Off-Grid Engineering Dual Battery tray, Red-arc BCDC, Switch Pros Controller, cheap Amazon lights.
    How about Extended Brake Lines? Are they needed if going to option 3? And any recommendation on brands?
  20. May 17, 2022 at 7:37 AM
    #1320
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Yes definitely
