Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Jul 21, 2022 at 7:43 PM
    #1461
    MrTreehorn
    MrTreehorn 2016 TRD BUILD IN PROGRESS
    Dan
    SF East Bay
    2016 TRD OR 4x4 MGM
    King 2.5s F/R, Icon RXT Leafs, Camburg UCAs, Wheeler's Offroad Superbumps, AllPro Spindle Gussets, JDFab Double Sheer Steering, RCI Skids, Bay Area Metal Fab Shackles and Hangers, Bay Area Metal Fab Gas Tank skid, RRW RR7H Flow Formed, 34" Mickey Thompson Baja Boss A/Ts , AllPro Sliders, Snug top Camper shell, MESO Customs bits n bobs, Powerbrake BBK, SSO Hybrid Front Bumper, Baja Designs 20" Amber LB, Warn Evo 10s
    Love mine on option 3. This threads reminded me to get my extended lines installed!
    memario1214 likes this.
  2. Jul 22, 2022 at 2:20 PM
    #1462
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You definitely don't want to be reminded the hard way... :bananadead:
    elmontemike likes this.
  3. Jul 22, 2022 at 2:23 PM
    #1463
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Oof, like the first time it's at full droop and those stock lines are all that's holding your axle.
  4. Jul 22, 2022 at 2:25 PM
    #1464
    memario1214
    Colton
    Missoula, MT
    Or you decide to let 'er drop out a little quick and they're no longer attached at all.
  5. Jul 22, 2022 at 2:36 PM
    #1465
    AllTacosFloat
    Boston ish
    Haven't seen it but could tell by the strain on mine it's a real thing.
    Really, don't wait. If those lines snapped it would be a bad day even if you were already at a mechanic. On a trail...so screwed
  6. Jul 25, 2022 at 6:21 AM
    #1466
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Even +2" rear lines with hammer hangers, rear Tundra shocks, etc they get a little tight.
  7. Jul 25, 2022 at 6:35 AM
    #1467
    NACAircrew
    NACAircrew Well-Known Member
    My pronoun is Chaz
    TRD OR/4R Trail
    Raptor lights/Meso everything/Predator steps
    I ordered the yota mafia rear 24” lines. Are the fronts even worth doing?
  8. Jul 25, 2022 at 7:06 AM
    #1468
    aturk
    Tony
    Charlotte, NC
    Not usually. My stock lines were fine (even mid travel, full droop, full lock), but then I went to Powerbrake BBK. They came with stainless lines. Mine seem to be fine at the same settings, full droop and full lock, with mid travel Fox shocks. My buddy with Kings (also mid travel) needed longer lines than what Powerbrake sent. His were TIGHT at full droop and full lock.
    So basically, if you are going to upgrade front lines, get them +2 just to be safe.
  9. Jul 25, 2022 at 8:13 AM
    #1469
    memario1214
    Colton
    Missoula, MT
    Yeah we definitely were not expecting his lines to end up like that. Thankfully we were able to get a set thrown together for him in short order.
  10. Jul 25, 2022 at 9:21 AM
    #1470
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Is this the kit (or similar) that you’re running?
    https://ok4wd.com/power-brake-x1-big-brake-kit-stage-1-for-2005-toyota-tacoma
  11. Jul 25, 2022 at 9:45 AM
    #1471
    aturk
    Tony
    Charlotte, NC
    backcountryj[QUOTED] likes this.
  12. Jul 26, 2022 at 1:11 PM
    #1472
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    Do your guys's leafs squeak? Ive got 5-6k on mine and Ive got a loud squeak except I cant tell if its my bedrack or my leafs. Seems like both squeak when I shake the truck. Any squeak mitigation tips would be greatly appreciated.
    Mattynokes likes this.
  13. Jul 26, 2022 at 1:16 PM
    #1473
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    I want an answer to this too. Mine have been squeaking on and off (mostly on) for the majority of their life. Beyond me pulling them off and regressing the bearings, they squeak.
    4xThad[QUOTED] likes this.
  14. Jul 26, 2022 at 1:18 PM
    #1474
    NACAircrew
    My pronoun is Chaz
    TRD OR/4R Trail
    Yes! I think most leafs squeak. There are inserts (or similar) that you can place in between the leafs, or use a spray lube. I personally don't care, it's a truck, and if you start swapping in suspension, skids, bushings, LCA's etc., shit will squeak, creak, clunk.
  15. Jul 26, 2022 at 1:24 PM
    #1475
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    what kind of spray lube? tri-flow orrrr? like a scilicone based grease?
  16. Jul 26, 2022 at 3:10 PM
    #1476
    NACAircrew
    My pronoun is Chaz
    TRD OR/4R Trail
    not sure what’s best. I’ve used this on my teflon uniballs.
  17. Jul 26, 2022 at 3:24 PM
    #1477
    memario1214
    Colton
    Missoula, MT
    Head on down to Walmart and pick up a bicycle inner-tube. Cut it into small strips (a few inches long). Lift the truck and then use a prybar to separate the leafs. USE PLIERS to put a small strip of the bicycle tire rubber where you can see that the leafs are making contact. I ran it that way for years on my Tacoma with squeaky leafs, and it was silent for 5 years up until the day I sold it.
    Stuck in VT and 4xThad[QUOTED] like this.
  18. Jul 27, 2022 at 3:51 AM
    #1478
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Pick your brand but Silicone Spray from the auto parts store works great. I keep a can on hand (specifically the PB blaster spray silicone) and every time I wash my truck I pressure wash the leafs out to get any extra mud/dirt out between the leafs then I spray it down with silicone spray along each leaf in the pack. if you have a curb or a vehicle ramp go up on one side so the leafs extend on one side and it makes spraying easier. then reverse and do the other side. I havent had a major squeak in a while and when I do I just spray it down and it goes right away.
  19. Jul 28, 2022 at 7:21 PM
    #1479
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    I just received my rxt pack today via fedex. Are these supposed to come in a box? Mine just had the ends wrapped in plastic with no extra shims, or pin, just the extra brackets for opt 3.
  20. Jul 28, 2022 at 7:36 PM
    #1480
    LeFreakyBone
    LeFreakyBone Well-Known Member
    Santa Cruz
    2021 Off-Road Midnight Black Metallic
    Leopard print steering wheel cover
    Mine came that way too. Then a separate box with the added leaf for option 3 came a day or 2 later
    AStinkyBumb and TacoZmtn[QUOTED] like this.
