Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Jul 28, 2022 at 7:46 PM
    #1481
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I had a suspension shop order and do the install. Here's what came taped to the leaf's they removed for option 2...
    TacoZmtn likes this.
  2. Jul 28, 2022 at 7:55 PM
    #1482
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    Cool, thanks. Also aside from the new ubolt kit, assuming I cant reuse my stock ones off a 2022? Thats all i would need for install? Im using 5160's with these and was wondering if I could benefit from new bump stops? I read a little bit in this thread about the ubolt flip kit... what are the benefits of those? thx again
  3. Jul 28, 2022 at 7:58 PM
    #1483
    TacoZmtn
    Im thinking the bolts might be taped in there still, as I havent taken the packaging off. I only noticed the extra brackets. Like the freakybone said, maybe they'll come later. I forgot to order the ubolt kit and dont have my rear shocks yet so they can for sure wait.
  4. Jul 28, 2022 at 8:09 PM
    #1484
    OffroadToy
    I'd get new u bolts... they're 8" and at option 2 i cut around a 1/2" off them. I went with new bump stops and extended brake lines... have extended travel front/rear shocks.
    Made this bracket to secure the brake cable... you might be able to reuse the oem one.
  5. Jul 28, 2022 at 8:34 PM
    #1485
    TacoZmtn
    Just notice between the pics you said you made the bracket. Looks good!
  6. Jul 28, 2022 at 10:49 PM
    #1486
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    Is that clip and clip bolt supposed to be used for adding the extra leaf for option 2&3? I have the exact same parts left over from my option 1 install.
    BurntToast likes this.
  7. Jul 29, 2022 at 5:07 AM
    #1487
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    I’m about 1,000 miles into my suspension overhaul. Fox 2.5’s, new oe lca, JD Fab uca, Icon Rxt leafs and superbumps. Overall happy with how everything turned out, no more squeaks and creaks. But, I have no weight in the bed and the Rxt’s on option 1 are pretty harsh…worse than oe w/ single aal. Do these break in at all and soften up? I’ve read so many reviews on how great they ride so I’m a little disappointed
  8. Jul 29, 2022 at 5:47 AM
    #1488
    OffroadToy
    Might want to call to verify bump stop fit but i'd say they more than likely will. I've got a SnugTop with around 50lbs of gear. At option 2 (mines a 2nd gen) it raised the back around 2 1/4"... 7 months later it's settled to around 2". My center hub to fender is now 24"... front is 22".
  9. Jul 29, 2022 at 5:52 AM
    #1489
    OffroadToy
    The extra parts (brackets/ center pins/plates) are for option 3.
    Option 1 and 2 use the same hardware (leaf pack total doesn't change) You need to change out the hardware at option 3 (thicker leaf pack now.)
    edit: not exactly sure where the plates get installed... i assume with the hole in them they have something to do with the center pin??
    71tattooguy likes this.
  10. Jul 31, 2022 at 12:46 AM
    #1490
    fullsend604
    The 2 metal plates go on top of the extra leaf when going up to option #3 then the 1st and 2nd leaf go on top of it. What I'm trying to figure out is which of the 3 clips are replaced when doing so? I'm assuming it's the one in the middle since that one holds the most leaf springs.
    Yours looks real good, how much weight do you have in the bed? I'm on opt #1 and about to go #3 due to increase bed weight up to about 400lb.
    6112 up front at max height, 5160 in the rear with option #1 but keep in mind I have about 250lb bed weight in this photo. Will update with new photo once I go option #3 since I'll be throwing on a RTT + DiadmondBack HD cover on it soon, I will have around 400-450 lb bed weight then.
    71tattooguy and AStinkyBumb like this.
  11. Aug 2, 2022 at 10:34 PM
    #1491
    TacoZmtn
    Upon install I had the passenger side not torquing down to spec on the upper shackle bolt. The driver side went just fine. Not sure what the issue is and noticed the bolt sticks out past the nut about a 1/4 inch past the nut on the pass side. Would not torque and I should've stoped tightening right away... Both sides measured the same after a 10 mile drive. Almost 2" lift. Getting the 5160's tomorrow from UPS... My trucks not my dd and was planning on checking out the issue tomorrow since its my day off... wondering if maybe there wasn't the metal bushing leaf installed from factory on the rxt pack? or not sure what I could've done wrong. So after about 20 miles while parking it tonight I notices the pass side was lower, measured and yup its about 2" lower then the driver side. Could it be the 4130's? I did haul ass over some speed bumps and it made a loud clunk while on the packs maiden voyage around town. But the shock looks fine... No odd sounds over big dips or slow over speed bump either... Anyone have any ideas of what it could be?
    pass side
    driver side
    pass side
    driver side
  12. Aug 6, 2022 at 6:04 AM
    #1492
    Tucker-Taco
    Tucker-Taco Well-Known Member
    Tucker
    North Carolina
    2017 Tacoma SR5 4WD
    Just installed option 3 yesterday, super easy job until you have to wrestle them into place lol. Has anyone got any input on how much these settle initially? I've got 2.5 inches of lift up front and about 400lbs static weight in the rear without camping gear. Thought option 3 would be a no-brainer but holy rake... the rear is up there.
  13. Aug 6, 2022 at 1:41 PM
    #1493
    OffroadToy
    On option 3 you change out the aft most clip...
    https://www.youtube.com/watch?v=sG5ePJAKGlw
    fullsend604[QUOTED] likes this.
  14. Aug 9, 2022 at 6:48 PM
    #1494
    TacoZmtn
    1B47CE85-4E02-4107-9222-A0672CED20CE.jpg So after installing my 5160s with my leaf pack at option one my passenger side is still about a quarter inch lower. Also the upper Shacklebolt Protrudes a half inch and won’t torque down… I talked to Icon and they said they had no clue what it can be and they were baffled but I sent them some pics and waiting to hear back… also the passenger side feels a little bit more squishy when driving around turns. I’m about to Exchange the leaf pack… Has anyone heard of or gotten a bad leaf pack before?
    B92AE742-E89F-4F08-85FF-C795B05410D0.jpg BAAEA615-9AE8-4F90-8B4C-E8C46AC22C8B.jpg
  15. Aug 11, 2022 at 11:39 AM
    #1495
    Tucker-Taco
    Tucker
    North Carolina
    2017 Tacoma SR5 4WD
    I don't have any advice to offer other than that I just installed my leafs last week and had no problems at all and can confirm something is not normal with yours.
    TacoZmtn[QUOTED] and 71tattooguy like this.
  16. Aug 11, 2022 at 3:41 PM
    #1496
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I just got mine installed. Option 2. Lifted 3" from where it was with the original springs but probably closer to 2" over stock given the old leaf springs were sagging a bit. Amazing how much different it looks/rides. I went with 5100/5125 (longer 5100) as well. Rides really nice on my trip home. I'll have a chance for a more thorough test ride soon.
    71tattooguy and elmontemike like this.
  17. Aug 11, 2022 at 4:09 PM
    #1497
    TacoZmtn
    Yeah idk, my only guess is that they installed a smaller sleeve, the one that goes on the bottom in the upper bushing... I just requested an exchange from shock surplus and let em know thats what it looks like. It kinda does from the pic... havent heard back from icon after they asked me to send them the pics...
  18. Aug 11, 2022 at 5:11 PM
    #1498
    Tucker-Taco
    Tucker
    North Carolina
    2017 Tacoma SR5 4WD
    Stage 3 nice and settled, only about 300lbs of weight in this pic. I installed them by myself in a day, and I'm not smart :anonymous: Just made an 800-mile road trip pulling a full (small) enclosed trailer and the rig fully loaded with all my gear... It barely budged under all that weight. Definitely curious to see if they remain that way as they age.
  19. Aug 13, 2022 at 7:50 AM
    #1499
    MallCrawlerTacoma
    MallCrawlerTacoma Member
    2019 Tacoma
    Option 2. Very slight rake.
  20. Aug 13, 2022 at 12:29 PM
    #1500
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Here's mine with option 2 and 5100s on notch 5. Maybe not the best pic for the front :p
