Icon rxt leaf pack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackohio, Aug 12, 2017.
  1. Oct 11, 2022 at 6:24 PM
    #1561
    grizz_wi
    grizz_wi Well-Known Member
    Green Bay, WI
    2022 Lunar Rock AC 6MT
    Do they come with the longer u bolts or do I need to order them separately?
  2. Oct 11, 2022 at 6:33 PM
    #1562
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    That's a lot of weight for option 1... maybe a shock issue or flattened out leafs?
  3. Oct 11, 2022 at 6:41 PM
    #1563
    Saltlife027
    Saltlife027 Well-Known Member
    Ny
    2017 Quicksand Taco
    Depends where you buy them. Mine came with the ubolts but some sites sell them separately
  4. Oct 11, 2022 at 8:13 PM
    #1564
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    So I jumped the gun a little. After unpacking and seeing a 2in difference, I panicked. I drove to work and home today and it seems to have settled/stretched out. With less than a 1/4 tank, the drivers side was 1/2 inch lower than passenger. I may just swap them and see if one spring is a little stiffer than the other.
  5. Oct 11, 2022 at 8:48 PM
    #1565
    OffroadToy
    The 1/2" difference is normal... look up "taco lean"
  6. Oct 11, 2022 at 9:12 PM
    #1566
    GeoTaco
    Freeda Feltcher
    Denverish
    Car seats
    Yeah, I’m aware of the lean. I just filled up and will measure again in the am. I had OMEs on my 09 and they came with a + and - so I thought maybe these had the same/similar thing. I’ll probably switch them and see if one has a slightly higher spring rate.
  7. Oct 20, 2022 at 1:40 PM
    #1567
    cartter469
    cartter469 A College kid who went broke for a truck
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    Do you guys include U bolts? If so any way to edit some orders and switch the Ubolts to include a Flip kit and take away from the price as if including normal Icon U bolts? Kinda silly to have 2 sets of u bolts
  8. Oct 20, 2022 at 2:00 PM
    #1568
    grizz_wi
    Green Bay, WI
    They do not include u bolts so you can get your flip kit instead, give them a call super friendly and answered my questions!
    cartter469[QUOTED] likes this.
  9. Nov 20, 2022 at 1:13 PM
    #1569
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Anyone run the rxt stage 2 with 5100s? Wondering if i need the extended shock or not i have a mid rise topper and about an extra 150-200lbs of gear in the bed at all times
  10. Nov 20, 2022 at 1:15 PM
    #1570
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I'm going to recommend you step up to something like a Bilstein 5125 which is an extended length 5100 to be able to capture that additional travel, but it will work. You just won't have much down travel since you're going to be lifting that rear end up.
  11. Nov 20, 2022 at 1:50 PM
    #1571
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Thanks was also looking at the 5125's i am not a hardcore wheeler the extended 5100s have too much travel for me
  12. Nov 20, 2022 at 1:56 PM
    #1572
    memario1214
    Colton
    Missoula, MT
    You don't need to be a hardcore wheeler to make use of a proper-length shock. Having your suspension max out on small dips or speed bumps is kind of annoying. And if you're pulling another couple of inches of height out of them at rest that doesn't leave much in the way of downtravel on 5100s. That said, you can always just run them and see if you find that you're finding the ends of your travel day-to-day. Swapping out rear shocks is generally an easy proposition, and you aren't going to ruin them in the interim.
  13. Nov 20, 2022 at 4:22 PM
    #1573
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Thanks for the insight on the 5125s just need to shorten the bushing sleeve for them to fit? As for the extended 5100s I guess limiting factory would more likely be the leafs or hitting the bump stop on opposite side? They just seem extremely long to me
  14. Nov 20, 2022 at 4:26 PM
    #1574
    memario1214
    Colton
    Missoula, MT
    Correct. Your limits are generally the bumpstop going up and the maximum droop of the leaf pack or the extended shock length going down.
    Nyrob[QUOTED] likes this.
  15. Nov 29, 2022 at 11:00 AM
    #1575
    TacoHungry
    TacoHungry Well-Known Member
    CO
    '22 AG DCSB TRD Off Road
    I ordered a set of RXT leaf packs from shock surplus and didn’t notice until I had already installed one that the other was missing half of a bushing.. I contacted shock surplus about a new bushing and they’re looking at it but haven’t given me any update.
    Looking around online it seems like Icon doesn’t even sell a replacement bushing, will I need to exchange the entire leaf?
  16. Nov 30, 2022 at 4:10 AM
    #1576
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    I would assume if the reseller doesn't have anything you could reach out to Icon and they would be able to get you bushings.
  17. Nov 30, 2022 at 7:39 AM
    #1577
    TacoHungry
    CO
    Shock Surplus let me know that they could send me a bushing but that it might take a while and suggested reaching out to ICON. So I sent ICON a note and I’m waiting to hear back
  18. Nov 30, 2022 at 8:53 AM
    #1578
    HankHeel
    HankHeel Active Member
    Philadelphia
    2021 TRDORDCLB
    Any cons to running on setting 3 without load most of the time in the bed? I occasionally haul motorcycles and equipment, looking for the max possible lift.
    71tattooguy likes this.
  19. Nov 30, 2022 at 9:00 AM
    #1579
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Nope! IMO I’m on option 3 with maybe 100lbs in the back when not camping ride is great no complaints here
    Tucker-Taco and redsloth like this.
  20. Nov 30, 2022 at 11:30 AM
    #1580
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    I am on option 2 with 100-150lbs static weight in the bed but I have riderite air bags for when I need to get heavy. Its a great combo to keep my daily ride softer, wheeling softer, but also able to carry some weight when I want to.
