Icon RXT leaf-springs pack rebuild.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Jan 8, 2020.
  1. Jan 11, 2020 at 9:10 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same goes to you, if u need help.
  2. Jan 12, 2020 at 12:30 PM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Thanks guys, will keep in mind. Also call me if you need help.
    Skydvrr likes this.
  3. Jan 12, 2020 at 2:34 PM
    t2ch
    t2ch Well-Known Member
    Travis
    Va.
    2015 TRD OR
    I looked at my RXT leaf pack today. They have shims between each leaf except the bottom two. Optional leaf has the holes drilled for plastic pads and there are 4 plastic pads included (two per leaf).
    Looks like changes have been made over time with the leaf packs. I received mine just before Christmas.
    I would love to hear from someone who has installed on a 2nd gen and could give me measurements. I'm stuck between stage one and two. I tow a tandem axle trailer with two 4 wheelers very occasionally (I have a 3/4 ton).
  4. Jan 12, 2020 at 8:11 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Post a picture of the middle of the pack and also of the rear of the pack (the end without the double loop)
  5. Jan 13, 2020 at 5:07 AM
    t2ch
    Travis
    Va.
    2015 TRD OR
    Is this how your packs were delivered? I may have miss read your OP. I thought you said they didn't come with spacers but you clearly said you didn't install them. Which leads one to believe they came not installed in the pack?
  6. Jan 13, 2020 at 5:14 AM
    slang
    slang Well-Known Member
    Very nice and excellent write up!
  7. Jan 13, 2020 at 6:13 AM
    Dacon
    Danny
    Gilbert, Arizona.
    Your RXT pack is the same like mine, nothing changed.
    The end of the 2nd leaf still has no hole for plastic pad and is a lot of friction there. That is the place I drilled and added a pad to eliminate friction along the length of the leaf. Also the spacer plated are still "garbage" with rough edges and holes. I ordered my spacers from cut to size.
    https://www.cut2sizemetals.com/resource-center/faq/
    .jpg
    CaptainBart45 likes this.
  8. Jan 13, 2020 at 12:04 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Excellent work
  9. Jan 13, 2020 at 12:26 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Nice rebuild. Looks very professional too.
    I’ve never seen brass used in between the leafs like that before. Since it’s a softer metal, are you at all concerned about those plates in the center flattening or thinning out a bit over time and causing your U-bolts to constantly become loose?
  10. Jan 13, 2020 at 5:20 PM
    t2ch
    Travis
    Va.
    2015 TRD OR
    Agreed, I saw the hole missing after I pulled the shrink wrap off.
    I will install the plastic pad before I install the pack to keep the squeaking to a minimum. I'll go with the steel spacers for now and see how they hold up.
  11. Jan 13, 2020 at 5:23 PM
    t2ch
    Travis
    Va.
    2015 TRD OR
    Brass is softer but hardens the more it is "worked". If you reload for rifles this is a common issue as the brass hardens and become difficult to resize. RIfle bras is also put under incredible pressure which the leaf pack will never see.
    Im interested to see how brass holds up. My guess is pretty good.
    Big tall dave[QUOTED] likes this.
  12. Jul 1, 2020 at 6:58 PM
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    why were they not made this way from the factory? i know leaf springs are notorious for squeaking
    i got squeaks, i may go the same route, replace a the inserts and pads... pisses me off after spending money and time installing these only to find out you need to spend more money and time to fix them, come on ICON. also the pads had no grease on them, found this out when i installed option 2.
    mine were missing one of the plastic pads for option 3. after waiting on hold with icon i got fed up and ordered them on Amazon, came next day, though not needed right now.
    not happy with my icon rxt.
    TACO5AU5 likes this.
  13. Jul 1, 2020 at 7:27 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Wow.
    That is clean, thorough, and impressive
    cdex8357 likes this.
  14. Jul 1, 2020 at 8:16 PM
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I got leaf liner sandwiched between all leaves. For the smallest and 2nd largest (both have no plastic spacers or holes for them), the liner goes from tip to tip. The leaves with plastic spacers go from spacer to spacer. I used the included metal spacers. They definitely are rough. I also sprayed one side of the leaves and both sides of the spacers with a graphite aerosol spray before putting the liners on.
    One pack has been done like this and I've compressed it by putting weight on it. No squeaks so far but I'm obviously not putting the same forces as the truck will. The second will be reassembled tomorrow.
    I'm hoping the liners solve the problems you had with direct contact and friction. I sprayed both sides of the leaves with some rustoleum to hopefully prevent or at least mitigate rusting. Do you think it'd still be worth it to get the better spacers? If so, what dimensions and thickness did you go with? I read this thread months ago and messed around with their configurator and wasn't sure.
    Excellent write up. Very thorough and pictures are great.
  15. Mar 2, 2022 at 6:54 PM
    #35
    B.Richards
    B.Richards Well-Known Member
    Brett
    Redlands, California
    2016 Toyota Tacoma DC LB 4x4, White, Black Leather Interior, Tech Pack.
    5100's w/Dobinsons Springs Front 2 inch rear. 285/70/17 BFG KO2 Tires. Snugtop Hi-Liner Cap w/ Frontrunner Cross Bars and Cab Roof Rack
    This is one amazing right up. Might need to put some more work into mine.
    I am in need of the stage one leaf spring clamps the RXT springs come with already installed. Therefore, if anyone changed their leaf’s to stage two or three and can send me your stage one clamps you took off I will gladly pay you for them. I really appreciate any help!
  16. Aug 17, 2022 at 12:28 AM
    #36
    Yodastacotruck
    Yodastacotruck Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    796097F1-FCF8-4C01-BB78-CD9A52380BF0.jpg Great read I’m not sure if this post is dead but I need help I think I assembled these wrong and already installed them on the truck, any help would be much appreciated I contacted icon sent them an email but they never got back to me as of yet
  17. Aug 17, 2022 at 12:46 AM
    #37
    Yodastacotruck
    Stock
    I’m confused I couldn’t figure out why only one leaf is missing a diamond cut on one end
  18. Aug 17, 2022 at 7:04 AM
    #38
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Not sure what’s going on in pic with the leafs left out :notsure:
    skeletron likes this.
  19. Aug 17, 2022 at 10:48 AM
    #39
    Yodastacotruck
    Stock
    i put both packs together but when I was done I noticed I had a short leaf leftover and a long leaf leftover one from each pack now I’m confused as to where they even go or if I assembled it correctly thanks for checking it out
    71tattooguy[QUOTED] likes this.
  20. Aug 17, 2022 at 10:53 AM
    #40
    71tattooguy
    Dino
    Petaluma , Ca (707)
    https://images.iconfigurators.app/pdf/I51101_REVB_7100.pdf
    Here you go bro! :thumbsup:
