Icon rxt leafs. What shocks ? Length?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T@coma2020, Oct 13, 2023.
  1. Oct 13, 2023 at 8:43 AM
    T@coma2020
    T@coma2020 [OP] Member
    2020 Tacoma Sport
    I am ditching my 2” block and install icon rxt leafs (stage 2). Currently have Eibach shocks. I figure they will be short. Any suggestions on replacement shocks ? What length should I look for ?
    TacoZmtn likes this.
  2. Oct 13, 2023 at 8:55 AM
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    Once I retain another set of the included shims that I lost, i'll be movin up to stage/opt 2 from opt 1. I have the regular length 5160, not the extended. I'm just gonna run it once a move to opt 2., check the brake lines and droop/ length. Then probably say f it and have do a shock relocate and new extended 5160's if mine aren't long enough... right now with timberon** bump stops Ive almost got an inch between the bumps and frame when unloaded...
    Anyone got an extra set of rxt shims for stage 2?
  3. Oct 13, 2023 at 9:27 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    there is a huge thread on RTX setups, you will find lots of info there
  4. Oct 13, 2023 at 9:28 AM
    BeastModeSteven
    BeastModeSteven Well-Known Member
    Steven
    2020 Tacoma TRD Pro
    I am currently running Icon RXTs stage 2 for the past year and now am dealing with a horrible and embarrassing squeak
  5. Oct 13, 2023 at 9:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Leaf springs have squeaked since the 20's. 1920's that is.
    Lots of threads on various fixes, most are inexpensive and simple to do.
    71tattooguy and Chew like this.
  6. Oct 13, 2023 at 9:40 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Are you running the Eibach pro-truck sport shocks in the rear? If so, they should be suitable to handle the travel requirements of an RXT pack on Stage 2. They actually run long, and I could comfortably recommend them for a 2" lift.
    As @Clearwater Bill It's a tale as old as time, and unfortunately pretty commonplace... I know it's not ideal to have to get in there, but we have a cheap fix that works well over here. Also I have heard that motorcycle chain lube works well.
    https://www.youtube.com/watch?v=Se7g4UCbZBc
  7. Oct 13, 2023 at 9:46 AM
    T@coma2020
    2020 Tacoma Sport
    yes I am currently using the Eibach shocks. I appreciate the help.
    memario1214[QUOTED] likes this.
  8. Oct 13, 2023 at 10:32 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Unless you want to increase your travel, there is no need to use shocks that have different extended and collapsed lengths. There is more than 2” of down travel at stock ride height. I am 1-2” above stock in the rear and I still have 5” of down travel.
    Hub to fender:
    Ride height RL: 23.5”
    Full droop: RL: 28.5”
    T@coma2020[OP] likes this.
