Icon rxt or Deaver U402 leaf springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jetboy818, Nov 29, 2018.
  1. May 11, 2019 at 1:55 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    I like mine! Also paired with Kings. I'm about to redo the rear setup though... Should be able to keep the leaf pack though
  2. May 11, 2019 at 2:10 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    What are you going to ?
  3. May 11, 2019 at 2:34 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    Shock relocation, Archive Hammer Hangers, and King 2.5x14 shocks. I have the EXTs w/ adjusters but you don't gain any travel. Great ride though
    SR-71A likes this.
  4. May 11, 2019 at 2:54 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Sounds badass. I'd like to see that when you're done
    Alesimo[QUOTED] likes this.
  5. May 14, 2019 at 10:22 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    How much constant weight do you run in your truck? Im about 200 lbs and trying to deiced between option 1 and 2. Im not really looking for much (if any) lift because I like the level rake, but obviously want to be able to travel rough roads with several hundred pounds in the back
  6. May 14, 2019 at 10:49 AM
    jrcuevasv
    jrcuevasv Well-Known Member
    2018 TRD Off-Road
    ICON rxt option 2 works well for me. Solid on road, takes well the bumps off road at ~40 mphs. I have them paired with adjustable extended kings so I can play around with the settings a little bit.
    Just towed with it recently and it didn't sag too bad, factory leafs would sag with just a big cooler and some camping gear.
  7. May 14, 2019 at 11:41 AM
    kylerocker10
    kylerocker10 Well-Known Member
    Washington
    2016 TRDOR DCSB MT QS SOLD
    BFG KO2's 265/75r16 32" OPT7 light bar mounted behind grill Softopper Canopy (black) Total Chaos UCA Fox 2.5 rr DSC Coilovers Fox 2.0 rr rear shocks w/adjuster Icon rxt leaf springs config 2 Weathertech stone/bug deflector CBI hidden winch mount Smittybilt x2o 10k synthetic winch
    I would definitely try option 2, I have about 200 lbs constant weight with sliders, hilift, maxtrax, etc and they ride great. Lift is 1” to 1.5”, sags another 1/2” to 1” when loaded with camping gear. Option 1 would be less lift but probably too soft with added weight.
    wi_taco and SR-71A[QUOTED] like this.
  8. May 14, 2019 at 2:59 PM
    rag9836
    rag9836 Well-Known Member
    Robert
    Riverside, CA
    14 Pre Runner SR5 TRD
    Bilstein 6112 & 5160's, SPC UCAs, TRD Pro grill, Cali Raised ditch lights, Pro Runner Cab Roof Rack, Demello Stealth Rock Sliders, SS brakes lines, Power Stop brake kit
    So Deavers J66, U402 Stage 1, RXT’s or Dakar’s if you are not running a load? Which is smoothest?
  9. May 14, 2019 at 5:38 PM
    kylerocker10
    Washington
    probably RXT in config 1, definitely not Dakars, those are the only two I have personal experience with.
  10. May 14, 2019 at 5:58 PM
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    Honestly if 200lbs is all you’ll ever have then you’re fine on option 1. I loaded the bed with 15 bags of wet mulch two weeks ago (500lbs or so) when i had it on option 1.. it sagged to factory height or maybe lower.. ultimately i went to option 2 even though i drive empty most of the time i do load up with 800lbs of coolers, ice and fishing gear from time to time. Option 2 handles the weight better but is noticeably firmer (but still smooth) empty. Hope that helps
  11. May 14, 2019 at 6:18 PM
    SR-71A
    Zack
    Southern Maine
    It does yeah. Id say Im running about 200 lbs constant now that I have the rack and RTT, plus all the recovery gear that lives in the truck full time. But I definitely add another 100 - 200 lbs of extra shit when camping
  12. May 14, 2019 at 6:21 PM
    Hookedup
    SOFLO
    Can’t compare but i can say RXT option 1 is very smooth on option 1 unloaded..
  13. May 14, 2019 at 6:31 PM
    Ethan22
    Ethan22 Well-Known Member
    Ethan
    SoCal
    2017 TRD-OR 4x4
    I run deaver u402’s in a stage one on some fox 2.5’s. And I have to say they ride like butter, I carry about 100lbs in the bed and and extra 200lbs with HC, tire + cans and they hold great. I tried the leafs out before installing HC and they weren’t too stiff but did have noticeable more rake.
  14. May 14, 2019 at 6:37 PM
    kylerocker10
    Washington
    How much lift did you end up with in the rear with the extra 200-300 lbs? How is the ride when more weight is added? I have RXT in config 2 now and spring rate seems fine but I would like more lift to allow for more bump travel. Do you think these springs would be a good option for a normal load of ~250 lbs and up to 500 lbs when camping etc?
  15. May 14, 2019 at 6:48 PM
    #35
    Ethan22
    Ethan
    SoCal
    2017 TRD-OR 4x4
    I ended up getting around 2” of lift with about 300lbs back there at all times. I’ve probably put a max of 400lbs back there overall and the leafs handle just as they did with no weight. Ive noticed that the more weight I toss back there they seem to be a lil more plush and less bouncy. But keep in mind with a swingout and all that weight back there behind the axle it’s always a lil bouncier than it would be without. And I think the 200-300lb constant load on these leafs is when they’re at their prime. And up to 500lb will work too, I haven’t noticed these things sag at all. I know they make an additional leaf to increase the weight capacity but couldn’t see myself needing it even with 400lbs back there, they ride plush overall
  16. May 14, 2019 at 6:56 PM
    #36
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    My RXTs have started getting pretty squeaky after 5ish months. I need to figure out how to fix that.
  17. May 14, 2019 at 6:57 PM
    #37
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    wi_taco likes this.
  18. May 14, 2019 at 7:02 PM
    #38
    Hookedup
    SOFLO
    Yikes!!! :confused: mine are quiet..
  19. May 14, 2019 at 7:10 PM
    #39
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    which do you guys think would provide the most droop?
    I now there are other factors at play, but if we are solely talking about leafs, which would be the best to droop?
    Im currently on Dakar's medium but wouldn't mind upgrading.
  20. May 14, 2019 at 7:17 PM
    #40
    Hookedup
    SOFLO
    Not sure if one pack would allow any more droop than the other. Correct me if I’m wrong but, I think the limiting down travel factor would ultimately be the shock.
