Icon rxt or Deaver U402 leaf springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jetboy818, Nov 29, 2018.
  1. Feb 23, 2022 at 5:09 PM
    #81
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Researching my next possible mod and ended up on this thread. Trying to find someone that has run a 3 leaf add a leaf on the factory leaf with the overload, bottom, spring removed and later installed the RXT on stage 1. I find plenty of comparisons between the RXT leafs and the factory pack with 3 leaf add a leaf with overload spring on. I tried to run the 3 leaf add a leaf with the over load on and this truck rode like a pogo stick. I removed the overload spring and it was better than the factory ride. I have the Bilestein 5160's but I have been looking at the 8100's. The RXT leaf pack would seem like the place to start if I was searching for a better ride. I am not complaining about the ride right now at all, probably just looking for something to turn a wrench on.
  2. Feb 23, 2022 at 5:28 PM
    #82
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Has anyone run the option 1 and then towed heavy from time to time? I locally tow a boat with a 450 pound tongue weight. Doesn’t make my stock springs sag badly at all. Any reason I should go option 2 all the time to support the boat trailer better? Am I overthinking this? Looking to install these with 5160s soon.
    CaptainBart45 likes this.
  3. Feb 23, 2022 at 5:42 PM
    #83
    CaptainBart45
    Bart
    Work in progress...
    I maxed out the towing rating, about 6,000 pounds on the factory leafs with the 3 leaf add a leaf and over load removed. It was a long haul from Layton Utah to Blythe Ca, over hill over dale etc. It was riding low, very low by the time I got home. To my surprise, once I took the weight off it sprang back to life and has held up like a champ every since. That was about 30K miles or so ago. Mainly why I hesitate to make the change.
  4. Feb 24, 2022 at 6:28 AM
    #84
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I started at option 2 and went down to option 1 after a few months. Sits a bit lower than I would like fully loaded, but I think it is worth it the rest of the time when unloaded.
    JohnnyRoadtrip and CaptainBart45 like this.
  5. Mar 1, 2022 at 2:13 PM
    #85
    BobbyPossum
    BobbyPossum Active Member
    Dave
    Elizabeth, CO
    2017 Tacoma TRD Pro
    FOX, SSO, Prinsu, Deaver, Toyo, Demello, Icon, AFE, OE, R4T, BAMF, Redarc, National Luna, Goose Gear, RCV
    I've run the Icon Add-a-leaf on the stock pack, and moved to the Icon RXT, and am now moving to the Deaver Stage 3.
    This evolution is a result of adding more and more static load to the truck. With a topper shell, roof top tent, rear bumper with dual swing outs carrying fuel cans and a spare, I was maxing out the RXT's even at the heaviest load leaf inserted. She started to sag in the rear, and that was before I added actual gear in the bed. In hindsight, as with anything I've put on the Tacoma, one mod leads to the next and sometimes means I have to replace a previous upgrade to keep up!
    Selling my RXT's soon, if anyone is interested PM me. I'd like to sell local to the Denver area.
    thebaker and CaptainBart45 like this.
  6. Apr 13, 2022 at 2:27 PM
    #86
    itz so salty
    itz so salty Well-Known Member
    '21 DSCB OR 4X4
    I'm trying to figure out what the best route will be for me. I already wasted money with the mistake of going with the Icon 1.5 AAL and now my truck sags with just a Softopper. I'm looking for at least 1" of rake in the rear when empty (Softopper is like 25lb, it doesn't count) and no less than level when loaded up. I'm okay with giving up a little ride comfort to not sag. The RXT is appealing because of the price point and current availability, but I don't want to make another mistake and end up having to purchase the Deavers anyway.
    My setup: I have a 2" lift up front running 6112s and 5160s w/ AAL in the rear. Bed is mostly empty with just a Softopper and maybe 50lb worth of crap most days. I load up around 600lb of motorcycle and equipment about 2-3 times a month. As far as armor goes, I don't really have plans past rock sliders in the near future.
    Will the Icon RXT with option 2 suffice for my needs? Would loading it with 600lb of weight from time to time cause too much wear and tear and flatten the springs? I don't want to end up with a poopy diaper stance again when I'm unloaded. Would option 3 be overkill? Or should I just move on to Deavers now - and if so, stage 1 or 2?
    71tattooguy likes this.
  7. Apr 13, 2022 at 2:41 PM
    #87
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I have Dclb option #2 6112’s same set up as you. I have about 2” of rake with about 100 lbs of constant weight. IMO I love the rake.
    itz so salty[QUOTED] likes this.
  8. Apr 13, 2022 at 3:04 PM
    #88
    itz so salty
    '21 DSCB OR 4X4
    Thank you for your input. Sounds like RXT option 2 is the way to go.
    71tattooguy[QUOTED] likes this.
  9. Apr 13, 2022 at 3:19 PM
    #89
    71tattooguy
    Dino
    Petaluma , Ca (707)
    No problem bro. Definitely :thumbsup:
  10. May 26, 2024 at 9:09 PM
    #90
    ToyoRideBFG23
    ToyoRideBFG23 Clifford, the big red Yota Beast
    So-Cal
    2011 Toyota Tacoma OR Edition 4WD
    Front: 2.5 Icons extended travel remote reservoir CDCV, JBA Offroad High caster Arms, Wheelers super bumps Rear: Bilstien 5125, 1.5” AAL, Other: Front tube bumper, FJ T-Case, 285/75/16 BFG KO2s, Black Rhino Chamber wheels -10 offset with 1.25”wheel spacers, Nilight Ditch lights and LED Fogs. Upcoming Mods: Hammer Hangers, Icon RXT leaf pack, Icon 2.0 VS Series Remote Reservoirs.
    what what length shock you go with? I’m wanting to do 2.5x14” but idk if rxt can handle it or if the leafs will be the limiting factor
  11. May 26, 2024 at 9:17 PM
    #91
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    14s
  12. May 26, 2024 at 9:24 PM
    #92
    ToyoRideBFG23
    So-Cal
    nice! Thanks for info. Ima go with locked Offroad 2.5x 14” smooth body this year and probably gonna go with the archive shock relocation or make a upper tube shock mount since I have a pair of total chaos lower shock mounts. Big project lays ahead
