ICON RXT orientation help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Mar 12, 2022.
  1. Mar 12, 2022 at 5:51 PM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Nowhere in the instructions is there information on which is the front and back end of the leaf springs.
    Can anyone shed light on this?
  2. Mar 12, 2022 at 6:05 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Where is the centering pinhole is that offset
    In the springs themselves
  3. Mar 12, 2022 at 6:27 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    It seemed to be centered.
  4. Mar 12, 2022 at 6:27 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Awesome thanks!
  5. Mar 12, 2022 at 9:40 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Diamonds cuts towards the back.
    TnShooter likes this.
  6. Mar 12, 2022 at 10:14 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    This is called a military wrap:
    It goes towards the front of the vehicle.
    The rear won’t have that double wrap on the bushing hole.
    huckyourmeat likes this.
  7. Apr 4, 2024 at 9:36 PM
    TacoTuesday1
    FL
    gonna double check orientation per above posts
    I imagine even with military wrap forward, diamond cut rear, 2 brackets at front, 1 bracket rear
    they may still be swappable left to right
    has anyone ever had to mess with it such as evening left to wide ride height?
    mine are installed with the little clamps bolts from the inside going out
    Which in some parts looks more necessary to clear
    Nuts and studs on outside
    noticed this is an issue as one of them is rubbing into the e brake cable sheathing.
    Thinking about flipping that one the other way, rather than shorten stud with grinder.
    mine are like this pic
    Except sticker deteriorated
    But opposite of this pic…
    (regarding c shaped clamp hardware facing direction)
    I wonder if the left to right potential swappability even matters…
    DavesTaco68 likes this.
  8. Apr 4, 2024 at 10:24 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Icon sells the leaf packs as singles. They are the same P/N left and right.
    On the driver side leaf pack, flip the retainer bolts so the bolt head, not bolt tip, faces the fuel tank.
  9. Apr 4, 2024 at 10:30 PM
    TacoTuesday1
    FL
    they're all like that; bolt heads on the inside
    stud protrudes at outside
    it's just one of them, pass side, that stud rubs the e-brake sheathing
    might just flip that single one since there's no fuel tank to worry about there
