Icon RXT Squeaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mctechhweng, Sep 20, 2022.
  1. Sep 20, 2022 at 2:38 PM
    mctechhweng
    mctechhweng [OP] Well-Known Member
    Matthew
    2015 TRD Sport V6.
    Audio: Focal PC165, Focal KX2, JL VX800/8i, Pioneer AVIC-8200.
    Hi.
    Recently put some Icon RXT's on my 2015 double cab. When torquing I put the diff on the jack and then put them at ~89 ft lbs.
    Now I'm getting a lot of squeak-age. What should I do? Loosen the eye bolts a bit, drive over some speed-bumps and re-torque?
    Its very annoying.
  2. Sep 22, 2022 at 4:55 PM
    Clench
    Clench Well-Known Member
    2007 Toyota Tacoma Prerunner
    Am having the same issue,sprayed wd40 and it eased up
  3. Sep 22, 2022 at 5:03 PM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    Where was your squeak from? The leaf spacers, the eyes?
  4. Sep 22, 2022 at 5:05 PM
    Clench
    Was coming from the bushings
  5. Sep 22, 2022 at 5:22 PM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    So that's the rubber in the eye on the shackles or what?
  6. Sep 22, 2022 at 5:28 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Guys have been greasing the shackle bolts before installation to help with squeaking from those areas. I've been meaning to do it myself since I did not do this when I installed my RXT's earlier this year. I believe there are also greasable shackle bolts that one can buy, although pricey.
    I would spray mine with Liquid Wrench. Between the leafs and on the shackles and it would stop the squeaking for a couple days, then it would return. I've been using WD40's white lithium grease spray and the squeaking calmed down enough for me not to care much. It still squeaks, but not nearly as bad.
  7. Sep 22, 2022 at 6:04 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    My passenger side RXTs started squeaking after a trip on the Mojave Road. I disassembled the pack, cleaned the leafs and isolators then rubbed a light film of Super Grease between them. Also did the driver side, too. Been silent ever since.
  8. Sep 22, 2022 at 8:49 PM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    I wonder what the OEM does to keep them so quiet... They must be using some kind of Mexican Japanese polymers & metals that we don't have up here in America.
    SIK99Tacoma likes this.
  9. Sep 23, 2022 at 4:41 AM
    Clench
    Mine was coming from the bushings
  10. Jun 3, 2024 at 9:53 AM
    mctechhweng
    Matthew
    2015 TRD Sport V6.
    I’m probably going to go back to OEM springs with lift blocks and air bags because the squeaking on these is ridiculous…
    The Icon leaf springs are not very high quality imo… I live in San Jose CA area where cars never rust and my springs are bleeding rust for some reason… Add the noise which is coming from raw metal on metal rubbing… They did not put any interface material between the top two springs which is where my issues are coming from… Perhaps one spring has too much arch or wasn’t deburred idk.
  11. Jun 3, 2024 at 10:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^They all (OEM, OME, Icon...) squeak once dirt gets in between the leafs. Get two rolls of Speedway leaf liners P/N 91033038-BLK I have these in my RXTs and they've been quiet after 5 years of wheeling.
  12. Jun 3, 2024 at 10:20 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've had the rxt leaf's on for 2.5 years and haven't heard a squeak yet. Don't know if it makes a difference but i spray them twice a year with Boeshield T-9... doesn't attract dirt/dust as much as Fluid Film.
    https://boeshield.com/why-boeshield-2/
  13. Jun 3, 2024 at 10:24 AM
    Musubi3
    Big Island
    When I adjusted my Icon's from Option 2 to Option 1, I installed bicycle tubing between the leafs. I haven't heard squeaking since. That was a few months back and the longest so far I've gone without hearing squeaking. Hope it continues.
    When I took all the leafs apart, I was surprised to see where the rubbing was occurring. Definitely some hot spots here and there.
