ICON setting question
Discussion in 'Suspension' started by RacerP, Nov 2, 2011.
  1. Nov 2, 2011 at 3:52 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I just got my ICON's back from having them rebuilt, first time putting them on. I took the springs off to ship them, trying to save weight in shipping.
    I reinstalled the springs, installed the coil overs, only to realize, when I reinstalled the springs that I did not crank them down enough to give me enough lift, and now the upper control arm is in the way of adjusting them.
    So, now I gotta go and rent spring compressors again, take the c/o's out and crank them down. How far down does the adjustment collar have to be to get 2.5" of lift?
  2. Nov 2, 2011 at 5:19 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    1.25" It's a 2/1 ratio.
    Disconnect the uca,lift it up out of the way,make your adjustment.
  3. Nov 2, 2011 at 5:51 AM
    RacerP
    Chicago
    2003 4x4
    Do you just unbolt the crown nut on the upper? and then I should be able to lift it?
  4. Nov 2, 2011 at 9:04 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    How much was the rebuild?
  5. Nov 2, 2011 at 11:09 AM
    RacerP
    Chicago
    2003 4x4
    Mine got a little more expensive than I expected...
    The adjustment collars were frozen in one place, and the set screws were stripped. They had to cut those off and replace. Also my shafts were pitted and needed replacement as well.
    All done...around $450
