Icon shock side specific?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marvelousone, Jun 18, 2017.
  1. Jun 18, 2017 at 7:58 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    My icons were labeled driver and passenger in yellow markings
  2. Jun 18, 2017 at 11:38 PM
    Marvelousone
    Marvelousone [OP] Well-Known Member
    San Francisco CA
    2017 DCSB Sport
    got the fromt shocks on and went for a ride and i hear a clunking in the front. Sounds like metal hitting metal. I can see that the sway bar is hitting the larger coil. I didnt even think to install the sway bar relocation kit. Its getting late so ill deal with it tomorrow. Anyone have any clear instructions on how to install the sway bar relocation kit? Icons instructions suck.
  3. Jun 19, 2017 at 12:01 AM
    n0troublen0fuss
    n0troublen0fuss Well-Known Member
    Kevin
    Texas
    2013 DCSB 4x4 Base
    This. They are side specific, believe it's the contours of the tophat.
    I used this for the most part.
    and for adjustment.
    Also this.
    https://www.tacomaworld.com/threads/icon-stage-4-install-detailed-instructions.196192/
    Stage four shouldn't be much different as far as install except you are not mounting resi's obviously.
    My suggestion would be to read/watch all you can before adjusting or driving any more. Then re-read while you are working. Hope this helps, good luck and enjoy your investment. :thumbsup:
  4. Jun 19, 2017 at 3:37 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Damn, I thought the icon instructions worked great! Then again, I've installed quite a few coilovers on these trucks.
    rlx02 likes this.
  5. Jun 19, 2017 at 8:18 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    They are the same. They don't account for taco-lean. You have to crank one a few times around depending how bad your taco-lean is.
    Marvelousone[OP] likes this.
  6. Jun 19, 2017 at 8:53 AM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    They're not side specific. Just make sure side
    Of the top hat that has a notch in it faces outward. Underneath it has a plug for the hose for shocks with remote reservoir, just make sure that faces outward. The spacer on the bottom shock mount needs to face towards the front of the vehicle. But you can actually take the spacer out and the shocks are interchangeable. Someone mentioned that their shock has driver and passenger on it and is side specific and the reason for that is because it probably has a remote resevoir which my shocks doesnt have. For the top hat i dont think theres a specific countour. I think you just line the bolts up and youre good to go. But someone correct me on it if im wrong. And thank you to everyone that provided me with the info!
  7. Jun 19, 2017 at 8:54 AM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Yes theyre interchangeable. Just make sure the side of the top hat with the notch in it is facing outward and the spacer that sticks out on the bottom shock mount faces forward
  8. Jun 19, 2017 at 11:19 AM
    n0troublen0fuss
    Kevin
    Texas
    2013 DCSB 4x4 Base
    Probably right, I remember mine being labeled. Made it easy. :fistbump:
  9. Jun 19, 2017 at 12:41 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Jack the front end up. Remove front tires. Disconnect left and right sway bar end links (17mm). Remove 4 bolts (14mm?) securing sway bar to frame. Install sway bar relocation blocks with 2 Icon supplied bolts each side. Relocation block orientation will be whichever way that moves the sway bar forward towards the front of the truck. I think these are able to be installed backwards. Attach sway bar to relocation blocks with Icon supplied hardware (9/16?). Reconnect sway bar end like to spindle. Reinstall tires (lug nut torque 83ft/lbs). Lower to the ground and enjoy!
  10. Jun 19, 2017 at 12:51 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I know, I read the directions and installed them correctly.
  11. Jun 19, 2017 at 12:59 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    just take the swaybar out. much better
  12. Jun 19, 2017 at 1:02 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Im just stating it for whoever that runs into the same problem as me can review this thread.
  13. Jun 19, 2017 at 1:02 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Thanks!
  14. Jun 19, 2017 at 1:04 PM
    Phaze2Yogi
    Phaze2Yogi Well-Known Member
    Daniel
    Los Angeles, CA
    Inferno 2017 Tacoma TRD Off-Road
    What he said.
  15. Jun 19, 2017 at 1:16 PM
    #35
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
