Icon Stage 1 - how to adjust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skootx, Nov 2, 2014.
  1. Nov 2, 2014 at 12:22 PM
    skootx
    skootx [OP] Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Just got my kit and am thinking about installation. Is it possible to adjust the front shocks after installation? If not, what's the best way to be sure the truck will sit level?
  2. Nov 2, 2014 at 12:27 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Did you get a spanner wrench with your coil overs? You will have to install and adjust on the vehicle by turning the top collar to adjust height
  3. Nov 2, 2014 at 4:47 PM
    smd3
    smd3 Well-Known Member
    Jack the truck up first, maybe oil the theads a bit.
    You'll need to use the spanner. There's also an Allen bolt that locks the collar. You'll need to loosen that.
  4. Nov 3, 2014 at 8:59 AM
    skootx
    Erie, CO
    Yes, I did get the spanner, but I was wondering if I will be able to adjust the height once they (and the new UCA's) are installed. Is there enough clearance to adjust with the UCA's in place?
  5. Nov 3, 2014 at 9:07 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    its tough.. but yes you can. just jack up the truck, droop the suspension to realease as much tension as possible. loosen the allen bolt that tightens the collar, then get to crankin with the spanner..
    i suggest finding an allen key that fits and cutting it down as well to get in those tricky spots while you are turning it.. as well as using WD40 on the threads.
  6. Nov 4, 2014 at 3:34 AM
    smd3
    Count the turns, and keep track of it. That's the easiest way to keep the truck level.
  7. Mar 6, 2015 at 5:14 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    question... where do you measure and find out how much inch did u adjust? do you measure the thread above the collar?
  8. Mar 6, 2015 at 5:29 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    I would measure the thread above the collar, but count and record turns. Height adjustments won't be 1:1 at the coil. I would plan on adjusting the threaded collar 1/2 the height that you want to gain to start. Tighten the collar down, lower the truck, drive to let it settle and re-measure.
  9. Mar 7, 2015 at 5:37 PM
    skootx
    Erie, CO
    Yeah. I installed them as they came from Toytec, then raised them both, drove a bit, then readjusted. Took 4 or 5 of these to get them perfect. It's not hard at all to adjust them once installed, just jack it up and keep twisting, and spray WD40 on the threads. I'd agree that 1:2 is a good ratio as well.
    I ended up with 37.5" from ground to fender in the front, and 38" in the rear. Since I installed it the Deavers have settled and each corner measures 37.5" with a half tank of gas.
  10. Mar 8, 2015 at 8:29 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    I'm running with nitro trail grappler 285/70/17 and my coilover are set to 1:2 it's still rubbed a little bit specially when it bottoms out.. Front still look lower than the back (stock look) but I add a leaf so I thought it's just normal. Would anyone suggest to adjust to 1.5 in the front? Would it solve the rubbing issue? By the way minor trimming already done.
  11. Mar 9, 2015 at 8:41 AM
    skootx
    Erie, CO
    I have my fronts set to very close to 3" but I don't have my tires yet. If you're at 1.5" and the front is still lower, I'd go up.
