Icon Stage 1 Question?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thunderhope, Dec 21, 2018.
  1. Dec 21, 2018 at 4:11 PM
    thunderhope
    thunderhope [OP] Well-Known Member
    2019 Tacoma OffRoad 4x4
    The height of the truck in this video is what I want https://www.youtube.com/watch?v=f0oS7gGE5F0
    Looks like its achieved with the Rough Country's 3-inch Suspension Lift Kit
    I dont want a spacer lift, would I be able to achieve this with the
    ICON STAGE 1 SUSPENSION KIT - K53001
    https://www.headstrongoffroad.com/store/p281/ICON_Stage_1_Suspension_Kit_-_K53001.html
    And if yes, would all thats needed is just front coilovers and rear shocks?
    Also dont want any front rake, what should the front coilovers be set to when installed?
  2. Dec 21, 2018 at 5:33 PM
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    There is a whole sub-forum dedicated to 3rd gen lifts.. but in a short answer the icon stage 1 (not extended travel) on a 3rd gen should net about 1.5-2”. And it’s a much better option than a spacer lift..
    Good luck!
  3. Jan 2, 2019 at 10:19 PM
    thunderhope
  4. Jan 2, 2019 at 10:32 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    No, you won't be able to. Icon stage 1s come set at 1.5" from the factory. I believe the max you can adjust your coilovers is either 2.5"-2.75". I am currently a little above 2" myself. The rear shocks do not provide any lift. You will need an add-a-leaf or a leaf-pack to achieve lift along with the rear shocks. If you don't want any rake, just install the stage 1 and leave the settings alone.
    This is an older picture, but here is my set up with the Stage 1/Icon leaf pack + SPC UCAs+285/70/17s to give you an idea what it will look like. I currently have an aluminum bumper and have not had to adjust the coils to compensate for the additional weight.
    29662794_10211292085553726_1758626407735_3b548b944f0f9358c64e9d4c0e42f440ebaa5d4d.jpg
  5. Jan 2, 2019 at 11:07 PM
    thunderhope
    So i wouldnt be able to lift the front end by adjusting the coilovers higher to make my truck sit as high as those spacers do on that video?
  6. Jan 2, 2019 at 11:33 PM
    thunderhope
    If the coilovers come set at 1.5 of lift and with the factory 3rd gen 1 inch lift that would make the front a total of 2.5 lift correct?
  7. Jan 3, 2019 at 7:09 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I guess you can say that, only when comparing it to a 2nd gen tacoma. But if you're comparing it to a 3rd gen tacoma, it's set at 1.5" from the factory.
