Icon Stage 1 vs Fox 2.5 Factory IFP on second gen 4x4
Discussion in 'Suspension' started by JBecker, Feb 23, 2015.
  1. Feb 23, 2015 at 10:57 PM
    JBecker
    JBecker [OP] Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Looking for pros and cons of these two setups, the Icon Stage 1 kit vs the Fox Factory 2.5 IFP 0-2" coil overs without piggy back reservoir. They are both priced about the same at $1500 for front and back. I don't plan on adding the block in the back with the Icon kit, and with the Fox I would just be installing the performance 2.0 shocks that are good for 0-1" of lift.
    I should also add I will only be using either kit to level the truck and not going for the full 2" of lift they offer.
    Thanks
  2. Feb 24, 2015 at 8:45 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I don't think the Icon Stage 1 kit comes with a block. That was probably the sway bar relocation piece.
    You'll probably get a bit more lift with the Icons if you want to go higher later on.
  3. Feb 24, 2015 at 9:14 AM
    SDHQJASON
    SDHQJASON Active Member
    Gilbert, Arizona
    2001 Prerunner Supercharged
    Icon Coilovers, Icon Tubular UCA's, Deaver Springs, Donahoe 2.0 RR Shocks, Machined Method Standards, 285/70R17 Toyo A/T 2's
    Icon kit does not include a block for the rear. Either one is good for up to 2.5" of lift. Fox rears are a 0-1" and the Icon rears are 0-1.5" of lift. The big difference between the two is going to be the valving. The Icon shocks will be set up with digressive valving so your everyday ride comfort on the street will be better with the Icon components.
  4. Feb 24, 2015 at 3:56 PM
    JBecker
    Virginia
    Ah ok, it was the sway bar link piece then.
    So the Icon kit will ride better? I'm mostly going to be street driving, but it will see plenty of trail use when I go camping.
  5. Feb 24, 2015 at 9:35 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Just drive faster to get there :)
    The whole digressive vs progressive valving thing is that digressive valving is stiffer with slower shaft speeds. As it speeds up, it'll soften up (to a point). Progressive is opposite; softer, then stiffer. I love my Icons.
