Icon Stage 1 w/ Dakars
Discussion in 'Suspension' started by slcnbldr, Aug 7, 2013.
  1. Aug 24, 2013 at 7:35 PM
    #41
    _exped_
    _exped_ Active Member
    Paul
    Northern CA
    Nice! I live in mountain view and hit the trinity about the same number. usually for steelhead in November ams December. You should pm me if you ever wanna go up.
  2. Aug 26, 2013 at 9:55 AM
    #42
    slcnbldr
    slcnbldr [OP] Well-Known Member
    Anthony
    Northern California
    DCLB TRD Sport
    20% tint on the front windows. 8-15-13 Installed Icons front and rear with Dakars. 2012 4Runner wheels with 275/70/17 BFG T/A KO2's. Weather Tech mats front and back. Leer shell with Leer Locker and roof racks.
    Ok so just took the truck on a run to fish up north. The truck drove great but had one surprise problem arise that scared the shit out of me and I'll try and describe it as best as possible.
    I first experienced it while exiting the freeway and the off ramp veered to the right gently. So as I exited and began to brake at about 45mph the vehicle felt like it locked up for a brief second and I had no control plus it made a chatter or shudder noise that I could feel up through the pedal. Perhaps the ABS, Auto LSD, TRAC OFF or VSC engaged?? Go easy I'm not good with vehicle mechanics myself. But I did read in my manual that any suspension mods or increase in wheel size could affect any of these systems. So as I continued on it was mostly flat highway driving until I reached the mountain pass I had to go over and then I experieced the same problem when decending and turning right with an occasional left turn. I'd say it happened about 5 times on the trip up then would occasionally do it through the weekend.
    I am taking back in shortly but was wondering if anyone has any experience with this or can advise me of what the hell is going wrong. I don't think it is the Icons at all but maybe a result of the lift that could be causing a problem for one or more operating systems in the vehicle. But flat and straight she is perfect.
    Thanks for the help in advance.
  3. Aug 26, 2013 at 10:31 AM
    #43
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    I think some guys are having to have the VSC computer recalibrated(if I remember correctly) after lifting and or going bigger on tires. Seems hit or miss. Also there is a very delicate data wire that is supposedly easy to damage during the install process that I've heard some chatter about on here. I couldn't find the specific threads I read but they are pretty easy to find I believe. I'm about to lift and am not excited about this happening. Let us know what you find out. Good luck.
  4. Aug 26, 2013 at 1:36 PM
    #44
    slcnbldr
    Anthony
    Northern California
    DCLB TRD Sport
    Thanks I found some old posts and believe the VSC just need to be recalibrated. Really caught me by surprise though to say the least.
  5. Aug 27, 2013 at 12:46 PM
    #45
    _exped_
    Paul
    Northern CA
    Is that something that can be done with realignment?
  6. Aug 27, 2013 at 1:00 PM
    #46
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    ^^^^^ Thats correct right there, not sure why anyone would sell the standard ones so they could use their shocks as limit straps.
    Just saying if your going to spend the money on good shocks and after market leaf packs you might as well pull the trigger on the correct length shocks to maximize travel.
    Would bumps even have to be modified????
  7. Aug 27, 2013 at 1:15 PM
    #47
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    I am not sure that the bump needs any modifications, but I am sure it all depends on the pack.
    Here are the measurements to the shock in question
    27 3/4 Extended, 16 7/8 collapsed
  8. Aug 27, 2013 at 2:06 PM
    #48
    Mr Salty
    Hermmy
    Lots of chrome
    :rolleyes: Possibly 0.5" on the long side (just pulled this out of my butt from random measurements taken is the past so don't quote me folks).
    Yep I would have totally went with the longer shocks and just screwed with the strike plate up top for an easy fix to prevent full collapes. Down the road figure out the proper bumps, stockers are garbage anyways.
    Oh well
  9. Aug 27, 2013 at 2:16 PM
    #49
    Mr Salty
    Hermmy
    Lots of chrome
    The coilovers are bit more stiff then your factor struts, as a result with the smaller bumps your front end might not be as planted to ground as it was before. This can cause a small degree of slip in which case the ABS system is triggered, this is the vibration/sound you experienced.
  10. Aug 27, 2013 at 2:32 PM
    #50
    slcnbldr
    Anthony
    Northern California
    DCLB TRD Sport
    Not sure why I'd experiecne slip on a dry highway road surface. I felt this problem while driving on the highway through a couple mountain passing and as the road would veer right I was doing no more than 40 mph when the problem would occur. I have searched VSC on here the last couple days and it seems to be a common problem for many unfortunately. Some re-wiring fixes have been posted one good one in fact by BensonX which I believe over rides the VSC completely shutting it off. I will try the re-cal tomorrow and see if it helps. I hope so.
  11. Oct 14, 2013 at 4:40 PM
    #51
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    I am running the bilstein 5100 rears with my dakars that come with the rcd lift. They have pretty much the same working measurements. they were more affordable than the icon rears made for the 3-4" rear lift.
