Icon Stage 2 Creaking Squeaking front
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cparkphoto, Apr 6, 2016.
  1. Jun 20, 2016 at 8:44 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Google huh?
    That's a big "fuck you" in my book.
  2. Jun 20, 2016 at 8:48 AM
    Str8Dmass18
    Str8Dmass18 Well-Known Member
    2016 Magnetic Gray Tacoma SR5
    Adjustable King Coilovers and shocks, Camburg UCA’s, Deaver add-a-leaf, BAMF Grill, Method NV's, 285/70R17 FALKEN WILDPEAKS
    Yeah, but I won't judge the company's reputation on one employee's comments/suggestions. It's a nice kit and quality. I'll figure the squeak out eventually and get it fixed
  3. Jun 20, 2016 at 8:51 AM
    splitbolt
    NW Arkansas
    You're a better man than me; not enough consequence in this world...
    ZachMX likes this.
  4. Jun 20, 2016 at 9:45 AM
    cparkphoto
    cparkphoto [OP] Well-Known Member
    2016 ORDCLB
    Definitely avoid WD-40 down there. TriFlo is your best option because it is a dry teflon lubricant. It won't attract dirt the way a grease or other wet lubricant will. Might be that the shop cranked your lift up too high for the stock UCA's? I am running my stock UCA's but I only had the shop lift me about 1.5 inches.
    Definitely avoid WD-40 down there. TriFlo is your best option because it is a dry teflon lubricant. It won't attract dirt the way a grease or other wet lubricant will. Might be that the shop cranked your lift up too high for the stock UCA's? I am running my stock UCA's but I only had the shop lift me about 1.5 inches. Any clue how much they cranked you up in the front?
  5. Jun 20, 2016 at 10:29 AM
    Str8Dmass18
    Was able to get a can of Tri-Flow not long ago. I sprayed the bushings and no more squeak. We'll see how long thins lasts though. Hope this helps everyone else with the same issue. As far as the lift, the coilovers were left at the factory setting.
    ZachMX likes this.
  6. Jun 20, 2016 at 10:32 AM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    [/QUOTE]
    That's pretty lame on icons part. Wd40 is far from the best solution. I believe in supporting companies that support customers. Sad.
  7. Jun 28, 2017 at 4:33 PM
    Marvelousone
    Marvelousone Well-Known Member
    San Francisco CA
    2017 DCSB Sport
    Were you ever able to figure out the problem? Im having the same issues with a loud squeaking on my stage 2. I spoke to icon and they suggested spraying wd40 on the shaft to see if it helps. I did that and it did nothing. Now they think it might be a bearing on the top hat. Now they are sending me a new bearing but it sucks to have to pay a shop install the bearing and reinstall the shocks after its already been installed.
  8. Jun 28, 2017 at 8:07 PM
    Str8Dmass18
    The squeaking eventually came back after several applications of tri-flow. What fixed the problem was getting aftermarket UCA's. I got the Icon tubular ones and I've never heard a squeak since. Problem is that now I hear a squeak in the rear springs. It's pissing me off
  9. Jun 28, 2017 at 8:52 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Why would the stock uca squeak if you didnt even touch them? That doesnt make sense. Yea the squeaking is so bad I can't even drive my truck.
  10. Jun 29, 2017 at 7:35 AM
    cparkphoto
    2016 ORDCLB
    Triflo solved it for me but honestly I think it was a break in thing cause I haven't had to reapply triflo all year. I shot triflo where the shock met the lower control arm. Good luck
  11. Nov 3, 2018 at 12:35 PM
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - ICON Stg 1 Adjustable Coil Overs ~3" lift, UCWMS, Airbags
    UCWMS; ICON Stg 1 Adjustable Coil Overs ~3" lift/shocks; Diff drop Spacers; Light Racing UCAs, Firestone Airbags
    I have the stage one, and it does pop and creak. And tri flow is the recommended solution, every few weeks you will need to spray a little on the lower mounts .
    It sort of sucks , but I think the ride quality and general performance of this setup outweighs the squeek in issue.
  12. Dec 27, 2021 at 9:34 AM
    Bee Finn
    Bee Finn Well-Known Member
    Brandon
    Wentzville, MO
    2021 White Tacoma TRD Off-Road
    The extra travel in the shocks could cause that ball joint to flex out more and squeak, happened to me on my Icon 2.5 Ext travel and my factory UCA's only had like 10k on them lol. Threw on Icon Delta's and it went completely away.
  13. Apr 26, 2022 at 8:45 AM
    akabahnz
    akabahnz New Member
    2019 MT TRD OR
    Reviving this thread again. Stage 3 Icon kit on a 2019 Tacoma with Delta UCAs up front.
    (265/70R17 tire setup with about 2" of lift all around from the kit)
    I'm getting serious squeaking at low speeds and some crackle and pop at sharp angles (backing into parking spaces, etc.) Sounds like replacing with the Delta UCA worked for some, but since I've already slapped that in that's not an option. What else should I check out?
    About 1500 miles on the new setup already and it's still a thing.
  14. Aug 15, 2024 at 6:17 PM
    Crimson_t4r
    Crimson_t4r New Member
    Joe
    T4R ORP
    Icon stage 2, prinsu pro
    I know this is an old thread but recently had this issue. Installed less than a year ago and about 10k miles put on the stage 2 kit with elevate UCA. Insanely loud squeak low speeds and when manually rocking the truck back and fourth. Had a small squeak straight away but in the last month has been intense. Took it to a new shop which is a reputable Toyota off road specific shop. it was the lower ball joint bushing where the shock connects to the lower control arm. Installed FRK bushings and solved the issue. 60 bucks in parts. If your a do it yourself type of person cheap fix. But about $500 after labor parts and alignment. Was told icon sold a while back and started using cheap parts and that piece wears very fast.
  15. Jun 24, 2025 at 7:18 PM
    #35
    astonb86
    astonb86 Well-Known Member
    Aston
    2011 Tacoma TRD Off-Road
    I recently bought stage 2 front coil-overs from Icon. While in there I did a complete rebuild of my front suspension. My LCAs were ceased so I cut out the camber bolts and replaced them with new LCAs, gusseted the spindles, replaced the wheel bearings, rotors, calipers, and installed the coil-overs. After a recent road trip I began to hear the same squeak everyone else is experiencing. I read through this chat and did as some said, I got the triflow lubricant and applied it to the heim, where the coil-over meets the LCAs. I let it sit but no change. I applied it again, note I did not take it apart and remove the bolt, but I did apply to the face, front and back and both sides. Still no change. So I tried to replicate the sound by having my kids rock the truck back and forth while I pinpointed the source. Its my UCA bushings. They are squeaking up a storm. I have Ironman UCAs recently replaced with the new zerkible upper ball joints. Not ideal for the Icon conversion but currently what I have. I was reading the notes for the install of the Icon coil-overs and it does mention you should install these with their UCAs. Not sure if there's some kind of angle or degree that coincides with their UCAs but that could be what some of us are experiencing.
  16. Jun 27, 2025 at 1:20 PM
    #36
    astonb86
    Aston
    Update to my last post. I have greased and lubricated every part possible. The noise still remains, I have narrowed it down to the piston shaft on the coil overs. I found on a conversation on a Jeep forum that states this is a common issue due to Icon's coil over design. There is an internal metal to metal contact that makes this noise. Not positive if that's true but it makes sense. I was theorizing that maybe dirt builds up on the piston shaft and then is pulled internally with compression. Internal build up might be the culprit for the squeak. If so this is a massive design flaw. Either way I personally am looking into alternative coil overs and a possible refund.
