Icon stage 2 is bouncy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marvelousone, Jul 15, 2017.
  1. Jul 15, 2017 at 5:18 PM
    Marvelousone
    Marvelousone [OP] Well-Known Member
    San Francisco CA
    2017 DCSB Sport
    Ive had my stage 2 installed for a couple weeks now and man this thing feels bouncy. I can feel every bump in the road. Anyone experiencing the same thing on their stage 2?
  2. Jul 15, 2017 at 5:19 PM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    how much do you have the front cranked up?
  3. Jul 15, 2017 at 5:27 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    I didnt touch the settings. I left it the way it came from Icon. I read the reviews before I bought them. Only complaints was that it was a little stiff and the ride is suppose to be firm. Its not that stiff but it feels bouncy amd sloppy.
  4. Jul 15, 2017 at 5:30 PM
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    all I can tell you is Icon uses digressive valving. That can make it bouncy and firm at lower speeds. Unfortunately thats all I can contribute
    t.hornstra likes this.
  5. Jul 15, 2017 at 5:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    Threaded shock bodies that achieve lift by preloading the supplied springs, correct?
    Where is the collar in the thread run? Did you get a lot of lift?
    You can tinker with adjusting the collar to reduce spring tension (lower lift, increase travel) and see if that helps. I'd start with no more than 1/2" of adjustment at a time.
    There's no actual adjustment for the shock action itself is there? IE it's an adjustable coilover, but not an adjustable shock?
  6. Jul 15, 2017 at 5:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That is the nature of the stage 2 kit. It is geared for go fast offroading shenanigans. There is nothing wrong with the kit, that's just how it is. It needs to be stiffer to absorb bumps while wheeling.
  7. Jul 15, 2017 at 7:19 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    "Bouncy", if you mean you hit one bump and it feals like you hit 2, then you need more rebound damping.
    "Feel every bump in the road" , if you mean too harsh, then back off the pre-load.
    Do you have adjustable rebound damping on the stage 2? If so increase it. If I remember correctly (probably not) King has a bypass adjustment that will achieve similar results. But you may want to reduce it rather than increase it.
    As for pre-load, people get too concerned with inches of lift that ride quality / correctly working suspension. Back off the pre load on the spring if you feel it's too stiff.
    ShemRahBuck likes this.
  8. Jul 15, 2017 at 9:10 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    How long have you had them on? Mine were pretty bouncy for the first couple hundred miles. They're a lot better now. And I cranked mine up about to about a 2.25" lift.
  9. Jul 15, 2017 at 9:55 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    I thought it was the opposite and what youre explaining is digressive valving.
  10. Jul 15, 2017 at 9:58 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Its adjustable coilvers. Theres no adjustments for dampening if thats what youre asking. I left everything the way it came from icon. Its a very moderate lift and nothing too aggressive.
  11. Jul 15, 2017 at 9:59 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    My issue isnt that its stiff. It just very bouncy. Every little bump it bounces around
  12. Jul 15, 2017 at 10:03 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Im not concerned with inches of lift. I bought the kit and left it the way it came from icon. Theres no dampening adjustments on the stage 2. The height itself is fine and its not an aggressive lift at all. I feel like if i backed off the preload and lowered it a bit my tires will definitely rub.
  13. Jul 15, 2017 at 10:05 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    Ive had them on for a couple hundred miles, not long at all. You think should crank them up? I like the way it sits now.
  14. Jul 15, 2017 at 10:11 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    ICON overrated.
  15. Jul 15, 2017 at 10:31 PM
    Marvelousone
    San Francisco CA
    2017 DCSB Sport
    I kind of agree. The ride isnt that great.
  16. Jul 15, 2017 at 10:51 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Tire pressure? Think about running at <30#
  17. Jul 15, 2017 at 11:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I know. Stiff equals bouncy, however.
  18. Jul 16, 2017 at 1:09 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I only cranked them to level out a little and to compensate for taco lean. As for the stiffness, I really think it takes a little bit for the coils to break-in. They were super stiff at first but now they're a lot more compliant. Taking bigger bumps is a lot more fun with these than stock TRDOR suspension. Not to mention it drives much better on the road with less body roll and what not.
    Also, did you get your new wheels/tires on at the same time? The bumpiness might be from your stiffer tires too.
    bako19 likes this.
  19. Jul 16, 2017 at 4:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Seems stiff springs equal bouncy when not properly dampened.
    If, as you describe
    then it would seem this might not be a good product choice for street use?
    I've run 4x stiffer than OE suspension, properly dampened, on other marquees, that were never bouncy. Of course that was in a very different set of conditions than you describe above. It was go fast shenanigans, just not off road :D
  20. Jul 16, 2017 at 4:20 AM
    iBoosted
    iBoosted It's go to be the king
    Niko
    Mesa, Arizona
    2017 BBP Tacoma TRD Off-Road 4x4
    TRD PRO Front Grille Icons stage 3 lift Icons Billet Upper Control Arms Method Roost's Toyo Tires Caliraised Ditch Lights Caliraised Rear facing amber lights Caliraised Fog Lights Interior: Many Patches Greyman Tactical Rigid Insert Molle Panel
    Don't notice that on mine. Might be cause i have the stage 3 though.
