ICON Stage 2 What else do I need????
Discussion in 'Suspension' started by MikCad, Dec 1, 2011.
  1. Dec 1, 2011 at 6:41 PM
    MikCad
    MikCad [OP] Member
    CO
    2009 TRD Sport DC
    WeatherTec Liners SmittyBilt Bull Bar SmittyBilt Nerf Bars
    Hey TW,
    I recently purchased an ICON Stage 2 suspension system. I was originally leaning toward OME, but felt I got a pretty good deal on the Icon setup. Anyways, I'm curious if there is anything else I'll need before I have it installed? I did purchase some LR UCAs (I couldn't justify the additional expense of TCs).
    Any input is appreciated.
  2. Dec 1, 2011 at 6:46 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    TC uca's JK ;)
    Nice kit btw!
  3. Dec 1, 2011 at 6:54 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    bigger tires and aftermarket wheels. nice setup
  4. Dec 1, 2011 at 6:58 PM
    MikCad
    MikCad [OP] Member
    CO
    2009 TRD Sport DC
    I'm glad you brought up wheels/tires. Do I just need a wheel with 4.5/5" of BS -12mm offset?
  5. Dec 1, 2011 at 7:17 PM
    especk
    Erik
    Redding, CA
    that would work best. yes. 4.5" bs on an 8" wide wheel is most desirable.
  6. Dec 2, 2011 at 9:35 AM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    If your funds allow it, grab some uniball UCA...oh, and you can PM me for that. :)
  7. Dec 2, 2011 at 9:58 AM
    Sunner
    Sunner Well-Known Member
    Zat is a verrry nice set up yes. I plan on getting the same, with the other type of shocks though, the ones with the remote reservoir, And some dakars instead of the AAls. Good luck with the install man.
  8. Dec 2, 2011 at 9:58 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Readylift, Truxedo, Husky Liners, Carven
    You need to get another set for me!
  9. Dec 2, 2011 at 5:49 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    If theyre the ext travel Icons, you'll prob be OK but a uniball would prob give you a little more travel but I think those do the job too! Nice set up, you'll be very happy with those. Just don't pre load the crap out of them and they be perfect!
  10. Dec 2, 2011 at 6:10 PM
    MikCad
    MikCad [OP] Member
    CO
    2009 TRD Sport DC
    Aren't the LR UCAs uniball design??
  11. Dec 2, 2011 at 6:12 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
  12. Dec 2, 2011 at 9:07 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    No, they're ball joints and are for primarily alignment. My camburg ball joints aren't as strong as the uniballs but the ball is re-positioned for more travel.......I wonder if the LR's are too?
  13. Dec 2, 2011 at 9:13 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    I have the Icon Kit, but i skipped the AAL, and went with the Dakars.
    Here's what Else:
    Upper control arms really are a must for proper alignment.
    Longer rear brake lines. (I did the Fronts while i was at it)
    Carrier Bearing Drop.
    And 8 hours for install!! :D It was really easy.
  14. Dec 3, 2011 at 12:05 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    A good way to get better use out of ext Icons (if thats what you ordered) is to get the camburg ball joint ucas. Allow for more travel but less price than the uniball. Now if you beat the crap out of the truck, go with the stronger uniball
