Icon Stage 4 Install Detailed Instructions
Discussion in 'Suspension' started by DrSpaceman, Jan 2, 2012.
  1. Jan 17, 2013 at 7:44 AM
    #41
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    Thanks for the write up, much appreciated - is part 2 available? I am planning on installing my stage 3 this weekend in the garage. Should be fairly straight forward I hope.
    mntnbomber and Naveronski like this.
  2. Jan 17, 2013 at 8:13 AM
    #42
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    Nice step by step!! +1 rep
  3. Jan 17, 2013 at 5:16 PM
    #43
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    That's beautiful, exactly what I plan to do this year!
    Any higher res pic so I can make it my wallpaper for motivation? :)
  4. Jan 17, 2013 at 9:10 PM
    #44
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Totally straight forward. For the rear follow the directions that came with the Icon leafs.
  5. Jan 17, 2013 at 9:22 PM
    #45
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    We are here to help as well if you should have any additional questions or concerns....you should have also recieved resi stickers for the 2.0 rear shocks that get installed right before you mount the resi. This way you can line up the ICON properly.
  6. Jan 17, 2013 at 10:15 PM
    #46
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You're going to LOVE that setup! Chris 4x4 has a great sticky on the aal install too! Deff look into Icon's new bolt on bump system too if you plan on wheeling escepially higher speed scenarios.
    I'm waiting for a strike plate I can use of my ubolt flip kit, otherwise I'd have them already!
  7. Jan 21, 2013 at 6:33 AM
    #47
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    Again +reps to DrSpaceman for taking the time to take photos and put this write up together. It certainly helped out. I finished my install on Sunday (fronts Saturday afternoon). I cut my original UCA bolts off and installed new factory bolts and nuts. I only put the passenger side in backwards as it worked out the easiest way to do that (used loctite 271). Also, my passenger side Icon UCA was a PITA to install as it seemed impossible that the two inside washers would allow the UCA to fit in place. It was really tight and required a few step back and breathe moments but I got it in and got the long bolt through eventually without throwing anything. Sometimes it's the things that should be simple. On the rear springs I did have to use an angle grinder and crowbar (worked best) to cut off the 2nd to rear most factory spring clamp. Lot's of sparks for fun. Getting the centering pins through required taking off a few extra bolts holding brake lines and whatnot on the rear axle to lower enough, and lining everything up was a test of my patience, but again, it came out great and I am happy with the work I did myself. Also of note, I reused/kept on the factory overload springs. Regarding the hole to be drilled for the reservoir mount, it was the next size up from 1/4. 5/16 I believe.
    I still need to adjust my drivers side coil over about a turn or so to help even everything out. Might give the passenger side a half turn. Gained about 2" all around at the current settings and the rake is still nice. Next up an alignment. Thanks again.
  8. Jan 21, 2013 at 11:43 AM
    #48
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    Good job, KingKoda! Can't wait to see the pics and hear your impressions after driving it.
  9. Mar 22, 2013 at 5:26 AM
    #49
    ronny97
    ronny97 Taco Madre
    Ronny
    Dickinson, TX
    White TRD Sport
    Sorry to ask such a dumb question, but how much lift does this suspension package give you?
  10. Mar 22, 2013 at 6:50 AM
    #50
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    I love the way this package rides on and off road. Only regret is i should have got the extended length CO instead of standard. Also i went with Wheelers 3 leaf add a leaf which is the same exact thing as Icon's only a little cheaper $
  11. Mar 22, 2013 at 7:21 AM
    #51
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    I've got about 2 inches with AAL and you can crank the coil overs to 3.5 I believe. I set mine at just about 2.25-.5 or so.
    I developed quite the "creaking" noise in my AAL's and ended up having to take the u clamps off, loosen everything up by lowering the axle (basically almost taking them off) and then blowing them clean with compressed air and spraying some Teflon lube generously in between the leafs. It took the squeak/creak away. I'll see how long that lasts. If it doesn't I'd say I wish I'd gone with a full leaf pack. But overall I am satisfied. Thinking of disconnecting my sway bar to see if I like the way that rides.
  12. Mar 22, 2013 at 7:42 AM
    #52
    Mitch
    Mitch
    Spokane, WA
    I have developed the squeak as well. But only when the truck moves for the first time of the day
  13. Apr 1, 2013 at 12:11 AM
    #53
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Hi David--great writeup! I was wondering why you routed the remote reservoir tubing under the UCA? In the pictures I've seen on this setup it is routed above. :notsure:
    EDIT: Nevermind--duh! Ignore my ignorance, I self educated...
  14. Apr 3, 2013 at 10:02 PM
    #54
    firefly335i
    firefly335i Member
    Brandon
    St George, UT
    2013 Tacoma Sport
    Icon Stage 1 kit w/Add a Leafs, TRD Catback Exaust
    Wow! Super detailed thank you! :) It's awesome you took the time to make it so professional :)
  15. Apr 7, 2013 at 2:32 AM
    #55
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    I think, based on what I've read about everyone making hacks to the fender to remove the UCA bolt, I'm just going to order 2 bolts and nuts and cut the existing ones off for expediency. Then i can just route the fresh hardware from the reverse angle as it should have been.
  16. Apr 7, 2013 at 6:13 AM
    #56
    09Tacomania
    Scott
    Little Rhody
    Didn't hack mine up. Had a new set of bolts on hand also. Never used them. Easier than it looks. Take your time. I'll sell you the bolt's if you want. $20. Collecting dust on top of my tool box
  17. Apr 7, 2013 at 7:43 PM
    #57
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    Hey coooool I may just take you up on that :thumbsup:
  18. Jan 22, 2014 at 3:51 PM
    #58
    Brock19
    Brock19 Well-Known Member
    brock
    southern utah
    Trail gear bolt-on sliders. BLHM, AUX relayed fuse block, Plastiderp, Diff breather mod, Paracord handles, Trex eyelids, Spacer lift (for now), Magnaflow offroad series cat-back exhaust. sound system, limo tint on all windows excluding windshield. all pro rear bumper with side plates
    the upper control arm in the kit he has is not the billet one correct? that is the tubular from the looks of it. from kingkoda's picture
  19. Jan 22, 2014 at 7:14 PM
    #59
    icon_rep
    Riverside, CA
    That's is correct.....the tubular are powder coated black and the billet are bright silver.
  20. Feb 22, 2014 at 3:54 PM
    #60
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Can you tell me the difference between the tubular versus the billet version UCA's? I know there's a significant price difference, but I'm wondering Pro's/Con's of each (adjustibility, etc.) I'm ready to buy, just not sure which one.
    Thanks!:confused:
