Icon Stage 4 Install Detailed Instructions
Discussion in 'Suspension' started by DrSpaceman, Jan 2, 2012.
  1. Aug 26, 2014 at 5:10 PM
    #81
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I have a few dumb questions:
    Is it necessary to pull off the tie rods?
    Is there enough clearance to remove the shock if you already have the UCA out?
  2. Aug 26, 2014 at 9:05 PM
    #82
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    I had to pull my tie rod. It helps move stuff around. Just be careful and support the spindle. If it not supported you can damage the ABS sensor line.
  3. Sep 19, 2014 at 4:35 AM
    #83
    terrieb
    terrieb New Member
    Terrie
    Grand Bend Ontario Canada
    05 stage 4 icon
    I have had a stage 4 ICON in my truck for 4 years now. Long story short not really happy the way they last. I paid the extra money to have them coated for salt and shit to help them last longer... My truck is a daily driver and I don't do any major off roading. I live in souther western Ontario Canada so not around any salt water.
    2 years ago I blew a line on a rear remote ressie driving down the road . I was ( WTF) I paid all this money and this happened
    I notice 2 weeks ago that the seals were leaking alittle bit. So I ordered a rebuild kit for them from shockseals.com ( $14.00 per side and had them in 2 days, they are great to deal with) , I pulled the shocks to rebuild them. Then I noticed the chrome is off the shafts and rusting.. ( WTF after just 4 years) So I had to order a set of shafts (Kurt Youngs suspension is the man he got them out to me over night)
    Here is were the fun began, I have rebuild my race quad shocks time after time and my race bike the same.. Well I couldn't get the retainer cap off of one of them..wouldn't move. ( heat and a SST ) . got it off with a lot of work... ok next step the piston and shaft wouldn't come next so I heated the body and got the good old slide hammer out... got it out. Well lets just say I wasn't a happy camper when it came out... the bore is rusty ( WTF after sending all this money ) I am leaving on vaca next weekend and I have to take my truck so I honed the bore and got it back together. ( the one with the cap that wouldn't come off I had to machine it and put 2 set screws in it to hold it on.
    The pass side was worst then the driver side.. The alum is just messed on the inside of the shock. I will post pictures tonight when I get home. I just got them back together late last night 2 am
    And for pulling them out I did it in 30 mins a side from start to stop. That is upper control arm and shock with remote ressie.
    Bottom line is when you pay all the money we do , you would think they would last more then 4 years as a daily driver and not off roading every day.
    My buddy that builds shocks for 30 years has never seen shock this bad in his life from a daily driver. Said he never seen race shocks that are in mud and sand all the time this bad.
    And to get ahold of icon it is a pain , Icon will be hearing from me. and I will post what they are going to do for me.
    Terrie B
  4. Sep 24, 2014 at 10:00 AM
    #84
    hybrid12micah
    hybrid12micah Well-Known Member
    norcal
    -Installed TRD ShortShifter kit -Installed ICON Tubular UCA, 2.5 Ext. Front Coilovers, rear 2.0 (no resis), rear AAL pack -Installed SS Lines front/rear -Installed Black TRD beadlock wheels -Installed Wet Okole Seat Covers -Purchased stage 4 EBC Brake kit
    I just put together a custom ~stage3 kit (UCA + ext-travel coilovers and rear shocks + AAL but no resis) from them and im waiting on the IVD coating (we're in the 2nd wk of turnaround now).
    Definitely interested to see what transpires with your situation. Are you planning on contacting them about this with picture documentation?
    Obviously im still excited for my kit but i would say if thats the life expect ency it definitely needs some addressing.
  5. Nov 10, 2014 at 8:25 AM
    #85
    Nostunknivek
    Nostunknivek Well-Known Member
    Kevin
    Victoria, BC
    '09 TRD OR partially debadged
    Seat belt chime mod, weathertech floor liners, secondary air filter removal,
    If you jack up on the lower control arm when removing the tapered ball joint, doesn't that release the tension? Then once it's been released can't you just lower the jack to lower the whole assembly so you can get the balljoint bolt out?
  6. Nov 17, 2014 at 10:37 AM
    #86
    Biznitch15
    Biznitch15 Well-Known Member
    José
    Los Angeles/San Diego
    13 DCLB TRD Sport
    None Yet
    Could it be that you didn't perform scheduled maintenance on the Coilovers?
  7. Dec 10, 2014 at 9:51 PM
    #87
    Fonzi25
    Fonzi25 Well-Known Member
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Hey I'm a lot better at seeing and learning rather than just reading instructions awesome write up but this video helped me understand it a lot better as well (it uses Fox shocks but the step by step is exactly the same) and you can use it to relate to these instructions
    http://youtu.be/bbsTJgb6S_c
    :cheers:
    JHEAL77 and brucehutchinson like this.
  8. Dec 15, 2014 at 12:41 AM
    #88
    Biznitch15
    José
    13 DCLB TRD Sport
    None Yet
    Jaime. Dude. I seen this video a few days ago. They make it look so easy. I'll definitely have my iPad next to me watching the video when installing my suspension. That's if I ever get it from TAP.
  9. Dec 15, 2014 at 4:41 AM
    #89
    willee51
    willee51 Well-Known Member
    Bill
    Forest, VA
    2015 TRD-Sport 6-cyl DCLB MGM
    Weathertech window vents, bed mat, Nerf Bars, Husky mats, sPOD, Marathon seat covers, Michelin LTX AT2's
    Thanks Terrie, Icon is now OFF my list for a future build:mad:
  10. Dec 15, 2014 at 7:49 AM
    #90
    Fonzi25
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    It's actually not that hard I helped a friend take out his a couple months back but the video does help a ton man. I'll be doing the same just to be sure I'm doing it right.
  11. Dec 15, 2014 at 11:26 AM
    #91
    Fonzi25
    Jaime
    Sparks, NV
    2011 Tacoma TRD
    Don't base your decision off 1 person there are tons of people who happily run Icon lifts without a single bad thing to say just my 2 cents
  12. Apr 12, 2015 at 1:27 PM
    #92
    mattsowell
    mattsowell Ridiculously lazy member
    kamloops, bc
    2010 Tacoma TRD DC SB sport debadged
    no seatbelt chime, stubby antenna, 5100's front and back with AAL, offset rims with Dura-Trac rubber, weathertec mats, Image Dynamic sub with 5 channel Amp and Kenwood Deck with steering wheel control, PIA bulbs, K&N air filter, ARB Delux front bumper
    So how did it pan out? Interested in a stage 3 but even if there is a flaw I would like the company to back their products.
  13. Apr 17, 2015 at 6:58 AM
    #93
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    We more than stand behind our products, and here on TW as well. I'm sure plenty can express their experience and the additional effort we put out to make sure people are happy. Obviously we are a business so there has to be line at some point. We service shocks 10 years old with out issue and shocks that are "less than maintained" that come in destroyed. You as the consumer have to maintain your investment like anything. If you live in brutal climates / conditions and never do a thing to them, well they are probably going to treat you the same way! .
  14. Apr 21, 2015 at 2:29 PM
    #94
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Denver Area
    2008 TRD Sport
    Wouldn't You Like To Know! The stuff I "think" I need!! ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall Modified bed extender
    So what are some things you would suggest to maintain and help them last.... I live in Colorado ...FWIW .I love my ICONS..The ride is awesome..
  15. Apr 22, 2015 at 9:01 AM
    #95
    icon_rep
    Riverside, CA
    First and foremost keeping them clean, it is crucial to keep them from having debris stuck to the shocks. Being you reside in Colorado as mentioned and can face conditions that leave lots of things on the ground you may want to pick up a set of the coilover shock covers we sell for the winter. They velcro on for easy installation and removal but offer quite a bit of extra protection to the shaft and seals. Part number is 191003.
  16. Apr 22, 2015 at 10:58 AM
    #96
    mattsowell
    kamloops, bc
    Thanks for getting back on this. I live in Canada and see a lot of snow and road debris. I clean by truck regularly so I don't anticipate anything related to that maintenance part. Is there anything else besides cleaning you recommend? Certain lubrication on certain parts? Anything I should definitely not spray into/on?
  17. Apr 22, 2015 at 3:56 PM
    #97
    icon_rep
    Riverside, CA
    Look into those covers as that is huge......grease upper arm bushings regularly and clean uniballs if you have them is pretty much it. Some use the Tri-flo dry teflon based lube on the uniballs and bearings, anything moist can attract dirt so grease is not the best idea.
  18. Apr 23, 2015 at 3:15 PM
    #98
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    do you make plastic dust caps for the tubular upper arms with uniballs? that would really help me keep them clean. i noticed the beefier uppers came with caps, just not my tubular ones.
    oh, also... the grease fittings dont exactly seat in a position that i can get a grease gun on them easily. is a crush washer appropriate for permanent installation to get the fitting pointing at an angle i can easily get to? so far ive had to just loosen the fitting, grease up and then tighten the fitting back down.
  19. Apr 24, 2015 at 10:53 AM
    #99
    icon_rep
    Riverside, CA
    Here is the link to the:
    ICON Tubular Uniball Upper Control Arm Billet Cover Caps
    http://iconvehicledynamics.com/shop/503-tubular-uniball-upper-control-arm-uca-cover-cap.html
    The grease fittings do not have to be heavily torqued so you should be able to rotate them to the usable area and leave them.
  20. Apr 24, 2015 at 2:40 PM
    #100
    transplant
    theo
    Crestline, Ca
    are these a new thing? it would have been helpful to include in the stage 4 kit i bought last year.
    im looking at 1/4 to 1/3 turn.. i honestly dont trust that the fittings wont come loose from on-road and off-road vibration if i set them and leave them
