Icon Stage 4 Install Detailed Instructions
Discussion in 'Suspension' started by DrSpaceman, Jan 2, 2012.
  1. Dec 26, 2015 at 8:53 PM
    #101
    Jonas111
    Jonas111 Well-Known Member
    Kelowna, BC, Canada
    I have a quick question and sorry in advance if it's a stupid question.
    Do I need to disconnect the tie rod or ball joint to change the coil over?
    I purchased some Icon Coil overs and my truck has light racing UCA's installed already.
    Thanks in advance.
  2. Dec 27, 2015 at 6:47 AM
    #102
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    It will make your job a lot easier if you do...
    samsung likes this.
  3. Dec 27, 2015 at 7:10 AM
    #103
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    i don't know why you have to disconnect the tie rod. Icon's instruction tells you to disconnect the tie rod as well. i just did an icon stage 5 on my runner basically was the same set up i was even able to reuse my dessert uca's from my 2011 tacoma on the 4 runner, just did a uca refurb with new bushings and uniball. and did not have to remove the tie rod. I can only guess that'll make it easier to take the coil over out. i was able to just get it on the right angle and move the coil over out of the housing. i also had my factory uca's out before i took out the coil over.
  4. Jan 3, 2016 at 7:13 PM
    #104
    Miyagi
    Miyagi Well-Known Member
    Seattle, WA
    2024 Windchill Pearl Land Cruiser 250 Prem.
    Greenlane Sliders + Leveling Kit, Rotiform STL, Falken Wildpeak AT4W
    Getting Icon 58635 ext. travel non-res coilovers put on my truck next weekend. It's a 2015 DCSB SR 4x4. What amount of lift are those coilovers pre-set to from Icon? Is it 2" or 2.5"?
  5. Jan 17, 2016 at 11:55 AM
    #105
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    What you net for lift depends on what you got going on with your rig--is it stock or have you added upgraded skids and a bumper? Straight stock will likely net you between 2 and 2.5 and naturally you can go from there using your spanner wrench. Icon specifies you maintain at least 1" difference between the fully loaded hub-to-fender measurement and the full droop hub to fender measurement to ensure optimal downtravel and ride quality
  6. Jan 17, 2016 at 1:43 PM
    #106
    Miyagi
    Seattle, WA
  7. Feb 3, 2016 at 6:29 AM
    #107
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Depending on the overall diameter of the new coilover assembly, maneuvering it out between the CV axle, tie rod and LCA can be very difficult. I found that pushing the spindle towards the front of the truck gives you more room, but it's still a squeeze. OP was doing this as a one-man job, so I can definitely see the benefit of disconnecting the TRE.
  8. Oct 17, 2016 at 12:28 PM
    #108
    farnorth01
    farnorth01 Member
    Ben
    British Columbia
    2011 SR5 4x4 ACLB
    Icon Stage 1, Dakars, Duratracs
    Does anyone know what size the 12pt cap bolt is for the UCA?
  9. Nov 29, 2016 at 9:03 AM
    #109
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Awesome write-up. Video made it much easier (unfortunately they used the "easy" side when it comes to the UCA bolt). Still a bit apprehensive about the UCA bolts issue... The whole bending/cutting the sheet metal to take them out in one piece makes me cringe...
    Thinking about just cutting them and replacing them with new ones, but I wonder if putting them in backwards has any side effects (vibrations loosening nut and bolt sliding down)... Or maybe I'm just worrying for no reason...
    Anyone that put them backwards use anything else on the nut end to secure it a bit more???
  10. Nov 29, 2016 at 12:48 PM
    #110
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Blue Loctite.
    Shikokaon[QUOTED] likes this.
  11. Nov 29, 2016 at 1:50 PM
    #111
    Bambino
    Bambino Well-Known Member
    Ben
    2014 metallic grey Tacoma TRD 4.0 6 speed access cab
    Just did mine last week, the bending isn't bad as long as you have a large set of channel lock pliers. In my option its a lot easier than cutting them out and having to purchase new ones. And I can hardly tell where the frame was bent.
  12. Nov 29, 2016 at 2:01 PM
    #112
    Shikokaon
    Portland, OR
    I guess I'll need to actually look at it (all I've been looking at are pictures and videos of people who have done it), I haven't crawled under truck yet as I just received lift kit today.
    Thank you all!
  13. Dec 7, 2016 at 6:22 PM
    #113
    farnorth01
    farnorth01 Member
    Ben
    British Columbia
    2011 SR5 4x4 ACLB
    Bending isn't so bad, just take your time and make sure your bends will be covered by the plastic flaps when you're done and you cant even tell.
    Put the passenger side in backwards but don't try and put the drivers side UCA bolt in backwards, it goes in much easier in the original direction. I tried to put in backwards the first time and got it half way in there and it all bound up on me and the head of bolt got stuck behind those hard lines that run just inside the wheel well. Took me 45 minutes or so to get it out, but it slips in perfect in the original direction.
  14. Dec 7, 2016 at 7:05 PM
    #114
    Shikokaon
    Portland, OR
    Awesome! Thank you for the tips! Haven't pulled the trigger on it yet, so I'll def write this down!
  15. Mar 30, 2017 at 11:40 AM
    #115
    st101
    st101 Well-Known Member
    I notice that this video states that you should not lubricate the outer part of the UCA bushing, yet the ICON installation instructions tell me to place lubricant on both sides:
    What's the right answer here?
    brucehutchinson likes this.
  16. Mar 30, 2017 at 11:59 AM
    #116
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I grease all surfaces of the bushings and they are still looking new after a long time.
  17. Mar 31, 2017 at 10:48 AM
    #117
    Bambino
    Ben
    ^^^ This. I did the same with my ICON UCA and no issues
  18. Apr 2, 2017 at 6:44 AM
    #118
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    That may be true for the tubular UCAs but don't do it to the billet ones
  19. Aug 10, 2018 at 2:31 AM
    #119
    _OC_TACO_
    _OC_TACO_ Active Member
    2018 Taco DB TRD OFF ROAD 4x4
    Stock 4 now.
    47F0672E-74B8-44A6-AE2F-02EB5EF92DC0.jpg 8F149C05-2A70-4347-A335-D4ABA648193D.jpg 3223E229-C5DA-4E40-993A-2629583499E6.jpg F7BF0953-193D-48CF-B55E-218315A17E61.jpg Also went with a stage 4, very happy with the results.
  20. Oct 1, 2018 at 11:47 PM
    #120
    MAC_Taco
    MAC_Taco Member
    Santa Cruz, CA
    2018 Tacoma TRD Off Road
    All good info. Late to the topic of this thread but you all have given me some willingness to give this a try. Looking at the ICON stage 4 setup. If I do, I will post info as I go.
