Icon Stage 4 Install Detailed Instructions
Discussion in 'Suspension' started by DrSpaceman, Jan 2, 2012.
  1. Nov 14, 2018 at 7:07 AM
    #121
    Knapz
    Knapz Well-Known Member
    El Paso, TX
    2019 DCSB TRDOR / Dual-motor CyberTruck pre-order
    FOX 2.5/2.0 resi & DSC, OVTUNED, Archive Garage hangers,
    Same here! Just got a '19 a couple of weeks ago. Went from wanting spacers and blocks, to 5100/OME, to Icon stage 4 in a matter of days. My only other experience has been Z71 bodylift and shocks. Thanks TW!!!!
  2. Apr 20, 2019 at 9:54 AM
    #122
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    OP, great write up! How was the rear install and how is the kit holding up? Any issues?
  3. Sep 2, 2019 at 1:22 PM
    #123
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Trimming the rear upper shock mount cup...
    What do you guys recommend for the best and easiest way to do this. Tools n such. Then I'm going to sand it down and paint so it doesn't rust
  4. Sep 2, 2019 at 7:37 PM
    #124
    romafern
    Rob
    80918 Let's meet!
    angle grinder. What stage did you get? I love my stage 4.
    TheMailman521 likes this.
  5. Sep 3, 2019 at 12:15 AM
    #125
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    Yeah I'm going to angle grinder it. Seems like the best option. Then sand and paint it to prevent rust.
    I'm pretty much a stage 4. icon front and rear with reservoirs, a full icon leaf pack, and icon DJ UCA.
  6. Feb 10, 2020 at 9:04 PM
    #126
    TheMailman521
    TheMailman521 Well-Known Member
    Josh
    SLO-CAL
    2013 Tacoma 4dr 4x4 Long Bed
    Icon stage 4, Dakar Leaf packs
    I love this, just bought my stage 4, what do you think so far?
  7. Feb 10, 2020 at 9:31 PM
    #127
    TheMailman521
    Josh
    SLO-CAL
    That video could be very helpful.
  8. Feb 20, 2020 at 5:29 PM
    #128
    TheMailman521
    Josh
    SLO-CAL
    Did you ever do a 2nd write up on the rears? I just did the Icon stage 4 on my 2013, thanks for the awesome write up on the fronts. I saw a post on TW from a guy who had issues and Icon wouldn't waranty due to incorrect install. I am no mechanic, and am looking for validation on my install. Can you message me a pic of your rear scocks installed?
  9. Mar 10, 2020 at 8:04 AM
    #129
    sfcacique
    sfcacique Well-Known Member
    Florida
    4WD TRD Access Cab
    Thule Racks with Hullavator, Pioneer Stereo/Nav
    We are installing your 58735 coilovers with reservoir and 58450DJ tubular UCA Delta Joint in a 2018 Tacoma. A couple of questions;
    1. The provided nyloc bolts don't seem to have the same thread cut as the Toyota Hinge bolt (UCA). Is this a regular problem? I didn't try to force the ICON nut onto the OEM hinge bolt. I assume it should be okay to use the OEM bolt on the OEM bolt
    2. The UCA part kit included two small ( one each with the hinge bolt nut package) zirc fittings but it appears we need two each UCA?
    3. I assume we should grease the UCA upper bushings through the zirc fittings. We manually lubed the bushings as described on the instruction set.
    4. Does the Delta Joint need to be greased before use, or was it factory greased.
    5. What are the ICON service intervals and procedures for this (as well as the AAL, and rear shocks)?
  10. Mar 11, 2020 at 7:04 AM
    #130
    TheMailman521
    Josh
    SLO-CAL
    I got my stage 4 installed and reached out to Icon. I sent them pictures and they validated my install as done correctly. I love the ride! I kept the factory adjustment on the coilovers for now. I've only put a few thousand miles on them but so far so good!
  11. Mar 12, 2020 at 3:47 PM
    #131
    sfcacique
    Florida
    4WD TRD Access Cab
    My reply post was meamt more fir the Icon vendor rep, but appreciate your input. The OP posted an excellent how to that helped a lot. Big differemce was he used the adjustable UCA and we used the tubular UCS.
    1. The nyloc but turned out to be for the tubular UCA to spindle bolt.
    2. There were four other zirc fitting that did actually thread on correctly, although that was not immediately obvious. The two small zirc fittings seem to be for later greasing of the delta joint.
    3. Greased the upper hing bolt fittings with the provided zirc fittings ( one for each arm of the UCA.
    4. We did not grease the delta joint as it appeared to be sealed at factory. The two smaller zirc fittings apear to be for later servicing, but we want @icon6669 to confirm.
  12. Mar 12, 2020 at 5:25 PM
    #132
    t2ch
    t2ch Well-Known Member
    Travis
    Va.
    2015 TRD OR
    Grease the Delta joint. The directions that came with mine states this.
    The zirc that came installed in the DJ uses a needle fitting for your grease gun and allows the dust cover to fit. The other is a normal zirc and will not allow the dust cover to seat. The dust cover is an optional item and does not come with the UCA's.
    sfcacique and TheMailman521 like this.
  13. Apr 11, 2021 at 7:51 PM
    #133
    Shmo40
    Shmo40 Member
    Josh
    Snohomish WA
    2017 TRD OR DC SB
    Icon Stage 3 - 2.75" lift 285/75/16 MAXXIS RAZR MT on KMC Grenades Softtopper RRW sliders UpTop softtopper compatible bed rack
    Hey are folks who have the extended travel front coil-overs plus the AAL in the back running the front coils on the maximum 2.13" of preload on the shock? When the coilovers arrived they were sitting at 1.25." I've since increased it 2.125." the reason i'm asking is if anyone has noticed what this does with the AAL to the over-all level of the truck. It appears as though 2.125" preload + the AAL (and removal of the stock overload spring) causes the truck to be just about level. Is that what others have found? Curious what level of shock adjustment folks are running. Cheers.
