Icon Stage 4 Sweet looks Ehhh performance
Discussion in 'ICON Vehicle Dynamics' started by RDtres, May 24, 2012.
  1. Oct 14, 2013 at 1:33 PM
    #41
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/Washington
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    How many inches of thread are on the non extended front coil over?
  2. Oct 14, 2013 at 4:59 PM
    #42
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    No I would like to have #1 the measurement from the center of the hub to the fender well at ride height, and #2 the same measurement (center of hub to fender well) at full droop. To get this jack the truck up from a front center cross member until both front tires are off the ground and take your measurement.
    Sorry I should have explained better what to do.....
  3. Oct 14, 2013 at 6:37 PM
    #43
    SportyHeretic
    Jeremy
    Wyoming/Washington
    2010 Sport
    Just curious, Non related question.
  4. Oct 17, 2013 at 9:13 AM
    #44
    505YOTA
    505YOTA Member
    Nic
    Canadian, TX
    12 Tacoma DCSB TRD Off Road
    -Camburg UCA's 1.25 uniball -ICON 2.5 extended travel RR coilovers w/ CDC adjusters -ICON 2.5 extended travel shocks RR w/ CDC adjusters -King bump stops w/ total chaos bump stop kit -ICON three pack AAL
    So I got your measurements for my droop and standard ride height. So you know too I have the ICON 2.5 extended travel RR w/CDC!
    Driver side standard height: 24 1/2 inches
    Passenger side standard height: 24 3/4 inches
    Driver side droop: 25 1/2inches
    Passenger side droop: 26 inches
  5. Oct 21, 2013 at 10:32 AM
    #45
    RDtres
    RDtres [OP] Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Agreed! Icon CS is amazing and has be recommending Icon's to everyone I know.
  6. Oct 21, 2013 at 10:54 AM
    #46
    RIDDICK3
    RIDDICK3 nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    would putting a 14 inch 650# coil on soften up the ride? Im asking for my personal use was just up in the mountains riding around on some rocky roads couldn't go over 15 mph without feeling like the truck was going to fall apart the ride just sucked. there great at higher speeds though, I have icon ext travel non resi with almost 2 inches of thread showing and 1.5 on passenger. I have 2 inches of droop
  7. Oct 21, 2013 at 6:44 PM
    #47
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2015 Tundra Double Cab
    Kings:Camburg:BFG
    Whats your tire pressure at?
  8. Oct 22, 2013 at 9:47 PM
    #48
    RIDDICK3
    Stefan
    Orem, Utah
    it was at 30 load range E 285/75/16 fierce attitude tires
  9. Oct 23, 2013 at 6:16 AM
    #49
    icon_rep
    Riverside, CA
    So looking at this we want to see a min of 1.5" of droop travel and it appears that limit is being pushed. Do you feel like the clunk is coming from the vehicle topping out over large dips or speed bumps etc.? This is a likely scenario, but it may or may not be the issue. If you don't feel that is it and you think it is the actual shock you are welcome to send it in and we will take a look. One thing it might consider is having the nitrogen level checked as well.
    Let me know and we will get it resolved no matter what.
    Brad
  10. Oct 23, 2013 at 6:27 AM
    #50
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    looks like you have about 4.5" of lift... this is your problem?
  11. Oct 23, 2013 at 6:31 AM
    #51
    icon_rep
    Riverside, CA
    Tires as mentioned could be part of that, but also what model truck do you have? How is it equipped in general?
    A 14" coil vs our 13" in the same rate will not do anything. 13" coil is designed to get maximum travel with out binding at all. Depending on the 14" coil and how it is engineered it cod bind at full compression. A revalve could be the answer to get them working good in the area of concern, but you have to consider all situations you deal with as well before making to many changes. How often are you on these roads and how is it working the rest of the time would be another question?
    I think if we made some simple valving adjustments we could get them where you need them to be at the end of this. Everyone has a different measure of what they feel and need based on where you live, terrains, and how your vehicle is equipped. The great thing about our shocks is the tuning options are endless.
    Let us know buddy.
  12. Oct 23, 2013 at 2:55 PM
    #52
    RIDDICK3
    Stefan
    Orem, Utah
    where I am at all the roads mostly are real rocky and bumpy. and on the street if I am not flying when I hit bumps its kinda like a tank. but when I get up above 45 its smooth. I dont know what kind of valving I would need.
  13. Nov 3, 2013 at 3:19 PM
    #53
    icon_rep
    Riverside, CA
    Your best bet would be to call in and we can get on the phone with our shock lead Adrian who can make some valving suggestions to suit your needs. Be glad to help you out, and we can get them dialed in no problem.
  14. Nov 3, 2013 at 3:49 PM
    #54
    PLC721
    Patrick
    Chandler, Az
    Kings:Camburg:BFG
    Your having the same problem i had for about a year, i had my truck at like 4" front lift and it was not good at anything under 50, back off of the pre load and i guarantee it will ride better for you
  15. Nov 3, 2013 at 4:01 PM
    #55
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Clemson,South Carolina
    05 PreRunner
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    That Icon customer service tho.
    I just picked up some foxes from DSM and their Customer service was top notch. Good to see Icon does just as well.
    :thumbsup:
  16. Nov 3, 2013 at 9:54 PM
    #56
    RIDDICK3
    Stefan
    Orem, Utah
    Ya I love the height it gives but I mean damn, Im not over extending the shocks I still have a good amount of droop. Do I need to rebuild the shocks and give them a different kind of valving? I would like to know so that I can buy the shims and get these babies to where I like, I rode them at 1.5 on drivers and 1 on passenger for a while but it looked dumb with that much rake. and it didn't ride much smoother
  17. Nov 18, 2013 at 6:45 PM
    #57
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    Cali
    MGM 2012 4x4
    Icon stage 2 kit, LR UCA, SCS wheels wrapped in 33s,
    ICON FTW!
  18. Nov 18, 2013 at 6:47 PM
    #58
    BBtacosurfer
    Dave
    Cali
    MGM 2012 4x4
    Good info on here...I left the extended length coilovers at the stock setting when they were shipped. They feel super smooth over speed bumps and amazing on and off road. I'm gonna crank up the coilovers slightly to get more front fender clearance because I keep nailing my fenders with hard hits. Cranking em about 1/2" and new bumpstops should be the winning ticket for me.
