Icon tie rods
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SilverYotaGuy85, Apr 26, 2025.
  1. Apr 26, 2025 at 4:56 AM
    SilverYotaGuy85
    SilverYotaGuy85 [OP] New Member
    Ross
    21 Silver Tacoma SR5
    Fox 2.5s, icon rxt, eibach springs, dorkel, 35s & lots of custom scratches and dents.
    What’s everyone doing for tie rod replacements? I need inners and seems like the icons could be a good option although not to much info to go on.
  2. Apr 26, 2025 at 5:07 AM
    (°▽°) Active Member
    Bone stock
  3. Apr 26, 2025 at 7:25 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Just a word of caution here. If you upgrade your tie rod strength that's great, but know that you're making the steering rack the weak link. Personally I'd rather stick to OEM and keep the inner tie rod as the fuse in the system rather than transferring that load to the rack which is much costlier to replace.
    Chew and majpooper like this.
  4. Apr 26, 2025 at 6:56 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    ^^ what he said ^^
    The advice I got from folks who do serious off roading was exactly that. If you to beef up a little for going off road get spindle gussets.
    BabyBilly[QUOTED] likes this.
