ICON Tubular Unibal UCAs Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROGU3 PR3DATOR, Jan 21, 2012.
  1. Jan 21, 2012 at 2:58 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR [OP] Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I've got an ICON stage 2 on my truck right now,and would like to not mix and match suspension parts. That said I was looking into getting Light Racing UCA's because of the adjustment options they allow for camber/castor. Anyone know if the ICON Tubular UCAs are adjustable in a similar fashion? Or are they closer to Total Chaos UCAs? I PMd a guy that is supposed to be a vendor for them on here but got no response.
  2. Jan 21, 2012 at 2:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They are like the TC UCA's
  3. Jan 21, 2012 at 5:13 PM
    ROGU3 PR3DATOR
    Jake
    Niceville, Florida
    Thanks. Bummer though. Back to the Light Racing I guess. Anyone running the ICONs?
  4. Jan 21, 2012 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No "Bummer" about it. UCA's either get teh alignment right, or dont. TC's get the alignment spot on. Yes, the LR's give more adjustments, but you dont need them. Get the 2* + of Caster, and .2* Camber, and you never have to adjust the ball joint again.
  5. Jan 21, 2012 at 7:12 PM
    ROGU3 PR3DATOR
    Jake
    Niceville, Florida
    So with the TCs you adjust the ball joint during install or something which allows for proper alignment? I'm not too familiar with suspensions in general.
  6. Jan 21, 2012 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With the TC's, you just install them, and get it aligned. No messing with the uniball. Same with teh Icons.
  7. Jan 21, 2012 at 8:58 PM
    ROGU3 PR3DATOR
    Jake
    Niceville, Florida
    So whats the point of adjustables if the uniball ones are just install and align?
  8. Jan 21, 2012 at 8:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The LR's are less expensive, and "can" be adjusted more precisely if desired.
  9. Jan 21, 2012 at 9:50 PM
    ROGU3 PR3DATOR
    Jake
    Niceville, Florida
    by "can be adjusted" do you mean, Sure you can adjust them, but its not really necessary?
  10. Jan 22, 2012 at 11:27 PM
    ROGU3 PR3DATOR
    Jake
    Niceville, Florida
    Bump for more info
  11. Jan 23, 2012 at 6:16 AM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    I have the ICON/Donohoe billet UCA on a 4WD 2008.
    The truck holds alignment very well, and we have beaten it pretty hard a number of times in Baja.
    Have no experience with the tubular - the billets do look good, also.
  12. Jan 29, 2013 at 3:35 PM
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    Bump more info on the icon uca's!
