Icon UCA Bushings leaking grease?
Discussion in 'Suspension' started by Noelbnetz, Dec 19, 2022.
  1. Dec 19, 2022 at 3:10 PM
    Noelbnetz
    Noelbnetz [OP] Active Member
    2022 White Tacoma TRD Off Road
    Recently noticed that the polyurethane bushings for my Icon Vehicle Dynamics upper control arms had minimal amounts of grease leaking/squishing out of it. I had installed them a year ago. According to the instructional manual, the only part that I have been giving strict maintenance to have been my delta ball joints, greasing them every 5k miles through the zirk fitting. For the initial install, I had liberally pre-greased the poly bushings as instructed. I've tried searching through this forum as much as I can but it seems from what I found is that many people don't grease their bushings or are unable to due to no port/fitting to fill grease into it. I was wondering if this is a sign of premature wear or if i had just overfilled them by alittle.
    All helpful info and advice is appreciated. Thanks!
  2. Dec 19, 2022 at 3:21 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The poly bushing will leak some grease. If they are greaseable and it bugs you give them another shot of grease.
  3. Dec 20, 2022 at 8:41 PM
    Relaxo
    Relaxo Well-Known Member
    Texas
    22 Army Green DCSB TRD OR
    ADS 2.5, Icon Deltajoint UCA's, Icon AAL
    I was under the impression you need to grease the bushings as well. I'm planning on doing mine about every 5000 miles when I grease the Delta joint. I think you have to loosen the through bolt first though to get any grease to flow.
  4. Dec 20, 2022 at 8:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Grease in/grease out. That's what the zerk is for
  5. Dec 21, 2022 at 9:21 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Bushings: Lift truck, support with no weight on suspension, remove tires, loosen pivot bolt nut, pump grease, reinstall tires, set back on ground, torque pivot bolt nut 85 ft lbs.
    Delta Joint: Grease at ride height... turn wheel left to right for full coverage.
    Every 3-5,000 miles (or every oil change.)
  6. Dec 21, 2022 at 9:44 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    A couple things...
    If you run poly bushings, no need to torque at ride height. Just torque in the air, with the wheels off.
    As you torque the UCA bolt, and after it's fully torqued, purge the zirc, by using a pick to push the zirc nipple. This will purge the excess grease and prevent blowing out your bushings.
    https://youtu.be/xvMdAX2uybs
  7. Dec 21, 2022 at 9:55 AM
    OffroadToy
  8. Dec 21, 2022 at 7:27 PM
    Relaxo
    Texas
  9. Dec 22, 2022 at 4:09 AM
    OffroadToy
    I think it's mainly for access for the grease gun and wrench... easier to clean & applyy Boeshield T-9 afterwards too. :thumbsup:
    Relaxo[QUOTED] likes this.
  10. Dec 24, 2022 at 8:56 PM
    Relaxo
    Texas
    Thanks for the response. Also thanks for mentioning the Boeshield T-9. I hadn’t heard of that before now but have been researching different rust proofing products. I have seen Fluid Film, Wool Wax, and Cosmoline but I haven’t seen this one. I do a lot of fishing and hunting on the coast and I’m looking for something that will protect against saltwater and sand. Do you know how the Boeshield compares to the others I mentioned?
  11. Dec 24, 2022 at 9:04 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I’ve got the Icons, you don’t have to remove the wheels to grease them, the delta joint and the bushings.
  12. Dec 25, 2022 at 9:37 AM
    OffroadToy
    The Boeshield T-9 is clear compared to the others and less tacky... doesn't seen to attract dirt as much. I mainly use it on the front/rear suspension parts... for everything else i use Fluid Film.
    https://www.youtube.com/watch?v=ZJRITgaJxYg
  13. Dec 25, 2022 at 8:51 PM
    Relaxo
    Texas
    Thanks for this. One of my main concerns about the coatings is sand sticking to them and harming the suspension. I previously had the Icon uniball UCA's and sand destroyed the lining the ball sits in. This was before they offered the cap. I know that’s less of a concern with the Delta joint but it's still a concern. It sounds like the Boeshield is the best option I've heard of so far.
  14. Dec 28, 2022 at 11:40 AM
    OffroadToy
    i'd still clean them on a regular basis and reapply as needed. I use the coil wraps up front and boots on the back... seems to help.
  15. Dec 28, 2022 at 8:43 PM
    Relaxo
    Texas
    I have one more dumb question. When greasing the UCA bushings where would be the best place for the jack stands? Just on the frame?
  16. Dec 29, 2022 at 8:02 AM
    OffroadToy
    that's where i put them... maybe throw the tires under there too just in case and remember to chock the rear tires. As DavesTaco68 mentioned above you might not even need to remove tires though... i haven't tried that yet.
