Icon UCA replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eze5601, Aug 26, 2017.
  1. Aug 26, 2017 at 3:20 PM
    eze5601
    eze5601 [OP] Member
    Hey All - I'm looking to replace my Icon upper control arms. The constant squeeking is driving me nuts. I replaced the uniball about 6 months ago (have about 6k miles) and use the recommended teflon but, nothing seems to help. I am looking for a non-uniball set-up that for less than $500 AND will not rub on my tires (295's) approx 3" lift. Any thoughts?
    Also, selling my Icon UCA...:)
    Thanks in advance for the help-
    Edgar
  2. Aug 26, 2017 at 4:35 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Camburg ball joint uca or JBA. Also spc
  3. Aug 26, 2017 at 4:50 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    Stupid question, but have you tried to grease the bushings? I have TC UCAs and when they start to squeak/creak it means the bushings need grease. At least that's been the case for me. :notsure:
    bsp_taco likes this.
  4. Aug 26, 2017 at 6:27 PM
    eze5601
    eze5601 [OP] Member
    I have several times. It worked for a bit so I supposed it could also be the bushings. I did a little searching and it.looks like Icon now sells a delta joint retrofit, so I think I'll try that.
    Bogg and EDDO like this.
  5. Aug 26, 2017 at 8:33 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Did you use the DRY lube as instructed? I'm under the impression the other types will eat away at the joint.
  6. Aug 29, 2017 at 4:58 AM
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    check out Icon's new Delta joint. i was in the same boat as you and was ready to give up on the Icons than they came out with the Delta joints. had wheelers send me a set...swapped out my uniballs and these are butter. nice and smooth and absolutely no noise. they replacement kit is about $260 but its alot less than new arms. hope this helps. edit: just saw you mentioned them..lol. didnt read the whole thread.. anyways, you'll love them.
  7. Aug 29, 2017 at 6:26 AM
    ItalynStylion
    Steven
    DFW, Tx.
    How hard are those to retrofit? How do they install?
  8. Aug 29, 2017 at 6:30 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Per icon they said don't grease and keep them clean. My brothers icons loosened up drastically on 1 year. Tires all over the road.
    He is ordering the Delta's and hoping they last. I know at this moment I'll never recommend icon to any one again.
  9. Aug 29, 2017 at 12:47 PM
    TNTramair
    2015 TRD OR SPORT
    as easy as replacing the uni-balls. remove the retaining clip and press the old ones out....press the new ones in and reinstall the new retaining clip. if you have the press tool it can even be done without removing the control arms from the vehicle.
  10. Aug 29, 2017 at 12:50 PM
    TNTramair
    2015 TRD OR SPORT
    cant speak on the durability just yet but as far as maintenance and noises....he'll be very happy with it. it instantly felt like a new truck after i installed these. first set of uniballs lasted 2 years... the replacement uni-balls were noisey and binding from the day i replaced them (only put approx 3000 miles on the last set of uni-balls).
    these just need to be greased like a standard ball joint every oil change.
    JayRolla[QUOTED] likes this.
  11. Aug 31, 2017 at 10:21 AM
    SlashMTB10
    SlashMTB10 Well-Known Member
    Southeast, CT
    2006 Toyota Tacoma DBL LB
    ICON Stage 4 w/ Tubular Upper Control Arms, Old Man EMU leaf pack, pro comp wheels w/ Cooper STT Maxx's, Pelfreybilt steel plate bumper, RCI skids, 4xinnovations sliders, custom built bed rack, ROAM Adventure CO. RTT and awning.
    Any advice on removing the uniballs? I have icon tubular UCA's and purchased the delta joints because the uniballs are shot. I took the control arm off and removed the retaining ring and used a ball joint removal tool. I couldn't get them to budge. I'm wondering if they are seized in there. Any pointers would be greatly appreciated!
  12. Sep 1, 2017 at 5:50 AM
    TNTramair
    2015 TRD OR SPORT
    i soaked mine with penatrating oil for an hour or so before attempting to remove and they came out easy. if you tried that and it
    didnt work than you may need to get it on a press. if you dont have access, any machine shop should be able to remove them for you.
    SlashMTB10[QUOTED] likes this.
  13. Sep 3, 2017 at 10:34 PM
    Bogg
    Surrey, Canada
    07 TRD Sport 4x4
    I smashed mine with a hammer and they flew out. Used a 3lb sledge
    Mully likes this.
  14. Sep 3, 2017 at 10:49 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Do the delta joints replace any 1" uniball or are they Icon specific?
  15. Sep 4, 2017 at 8:19 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Found mine battered and bruised because (I'm guessing) the top bolt for the uniballs came loose allowing the bottom section to separate. From the looks of it, that gap was open allowing the bottom part to smash into the upper part long enough that it deformed. That being said, I have delta joints on the way as we speak. Ironic I posted in this thread a while back and now need them too!
  16. Sep 4, 2017 at 9:58 AM
    cabiczzz
    cabiczzz Active Member
    2014 tacoma trd offrd 6speed stick
    icon stage 4 pacer 16x10 mudd grapplers custom made apex style front bumper
    ya i have them icon tubulars, still goin on strong for 2 years but squeaky as hell they suck just ordered me a pair of total chaos ones no bad reviews i've heard
  17. Sep 12, 2017 at 4:33 PM
    ncoutu
    ncoutu Well-Known Member
    nic
    2017 Silver TRD Off Road Access Cab
    Icon stage 3 with tubular lift kit. American racing 17x8 inch wheels. BFG 275/70r17 tires. MBRP S5338P 3" Cat Back, Single Side Exit exhaust. Custom trdecals.com trd decals. Debadged.
    I am also having trouble with the noise coming from my icon UCAs, is this common?
  18. Sep 12, 2017 at 4:33 PM
    ncoutu
    nic
    also only have about 2500 miles on mine.
  19. Sep 12, 2017 at 4:38 PM
    SlashMTB10
    Southeast, CT
    I had only had mine for about a year and the teflon lining around the uniball deteriorated allowing crud in causing then to squeak. I live in New England so we get all fpur seasons. I've since purchased yhe delta joints but have yet to install them.
  20. Sep 12, 2017 at 4:39 PM
    ncoutu
    nic
    I have had mine for about 2500 miles and the squeaking started much before now. It is pretty unbearable when i turn at slow speeds.
