Icon upper control arm torque
Discussion in 'Suspension' started by OffroadToy, Oct 1, 2021.
  1. Oct 1, 2021 at 10:56 AM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Can someone provide a link or know what the torque is for the through/pivot bolts on a Icon 58450 Delta Joint upper control arm? These are the nuts/bolts that get loosened in order to grease the zerks. The install instructions just say "torque to factory spec".
  2. Oct 1, 2021 at 2:21 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    85 ft/lbs
    boostedka and OffroadToy[OP] like this.
