ICON Vehicle Dynamics 05+ Tacoma Rear Hydraulic Air Bump Stop
Discussion in 'ICON Vehicle Dynamics' started by icon_rep, Feb 14, 2013.
  1. Feb 14, 2013 at 11:32 PM
    icon_rep
    icon_rep [OP] ICON Vehicle Dynamics Vendor
    Riverside, CA
    New little something for you to add on to your rig.......and it's tuned right out of the box for you.
    2005 - Current Toyota Tacoma Rear Hydraulic Air Bump Stop System
    Overview:
    Bolt on a set of ICON Vehicle Dynamics Rear Hydraulic Air Bump Stops to improve the on or off road capabilities of your 2005+ Toyota Tacoma when using maximum suspension travel. ICON’s race proven hydraulic air bump stops are tested, tried and true, from Cabo to Canada in all conditions. This vehicle specific tuned hydraulic air bump stop system offers both smooth engagement, maximum bottom resistance, and smooth controlled return while being used in extreme conditions. The true value to using a compression and rebound tuned bumpstop is the exponentially increasing force is smooth, not abrupt or harsh like the OEM bumpstop.
    As part of the kit, ICON includes an industry first selectable install height for the hydraulic air bumpstop so up travel is not limited with use of an aftermarket thicker leaf pack. This allows you to upgrade your leaf springs down the road, and retain maximum up travel without having to purchase a new bump stop bracket kit.
    Key Features:
    • Bolt-on design using existing holes in frame for clean install with no cutting or welding
    • Industry only Toyota Tacoma specific tune to maximize bottom out resistance while having smooth engagement as well as return
    • Absorbs additional impact energy over the OEM rubber bump stop and returns the axle in a more controlled manner
    • Industry only kit allowing adjustment for leaf pack height changes so uptravel is not lost
    • Can be returned to stock
    Bumpstop Features:
    • Linear-digressive piston which compliment a bumpstop over the industry standard linear-linear piston. Infinite tuning options with valve stack, oil volume, and nitrogen pressure adjustments
    • Anodized billet top cap, o-ring sealed back up cap, seal head and striker
    • CAD Plated body for corrosion free service
    • Urethane rod seal and wiper for long service life
    • User serviceable
    Tech Info:
    • Factory rivet removal required
    • Configurable design to maximize up travel with OEM or aftermarket spring pack thicknesses
    • Includes bump stop strike pad that uses factory u-bolts to secure in place
    • Install time 2 hours
    System Components Included:
    • (Qty - 2) 2.5" travel 2.0 hydraulic air bump stops
    • (Qty - 2) Vehicle specific 2.0 bump stop mounts
    • (Qty - 2) Lower standard spring configuration strike plates
    • (Qty - 2) Bump stop spacer rings
    • Necessary hardware
    • Installation instructions
    Options:
    • 56105 - U-bolt flip striker plates
  2. Feb 14, 2013 at 11:38 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    What is the name of the shock pictured above?
  3. Feb 14, 2013 at 11:46 PM
    icon_rep
    Riverside, CA
    That is our 2.5" Omega Bypass Part#59905
  4. Feb 15, 2013 at 12:05 AM
    Maximus
    North Bay
    Looks bitchin. What would be the advantages of the Omega bypass over a 2.0" or 2.5"?
  5. Feb 17, 2013 at 7:21 AM
    icon_rep
    Riverside, CA
    The 2.5" Omega Bypass shock gives you the ability to fine tune the shocks compression and rebound valving. With the high resolution valve we engineered, you get up to 32 adjustments by simply turning a knob.
  6. Feb 25, 2013 at 7:43 PM
    stephen11ty7
    stephen11ty7 Well-Known Member
    Stephen
    Villa Park
    07 white taco
    Total Chaos 2" LT, Icon coilovers
    So much sexy!!! Can't wait to get mine
  7. Feb 25, 2013 at 7:48 PM
    dcvt16
    dcvt16 Well-Known Member
    Ehren
    SCV, CA
    SOLD =( MGM Supercharged long travel 5lug
    Total Chaos 5 lug long travel kit, Fox coilovers. Mcneil fiberglass. Defined engineering sua, 14 in kings, Defined shock hoops rear. Weathertech digital liners and vent visors. Paint match grille and added fogs. 4.56 gears, detriot truetrac LSD (gear type), LCE header, URD 2TR supercharger.
    5 lug application?
  8. Feb 25, 2013 at 7:55 PM
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    Looks Hot, Why weren't you present at the Truck and jeep Expo in San Mateo this past weekend? Would have loved to see some of your products in person.
  9. Feb 28, 2013 at 6:48 PM
    icon_rep
    Riverside, CA
    It's in the plans....finishing FJ now and few others. I will make sure TW is in the loop as it happens
  10. Feb 28, 2013 at 6:51 PM
    icon_rep
    Riverside, CA
    Wish we were, heard it was a great show. Unfortunately we have an array of others already slated for 2013 and have to stick to the plan....Maybe next year we will get up there!
  11. Mar 7, 2013 at 10:12 AM
    dcvt16
    Ehren
    SCV, CA
    awesome. 5 lugs need more love.
  12. Mar 7, 2013 at 10:19 AM
    prerantaco
    prerantaco Well-Known Member
    mesa, az
    prerunner
    is this the only length bump you guys carry? nothing in the 4 inch range? price?
  13. Mar 7, 2013 at 10:19 AM
    icon_rep
    Riverside, CA
    Noted my friend....
  14. Mar 7, 2013 at 10:25 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Very nice guys! I feel like this should have been done years ago.
    My Donahoes were the best and now even better with Icon.
  15. Mar 7, 2013 at 11:03 AM
    icon_rep
    Riverside, CA
    Here are the sizes we have currently
    1.75" / 1.9" / 2.5" / 4.0"
    We have the mount cans as well if you need.
  16. Mar 7, 2013 at 11:06 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Will be picking up these bumps soon. Looking forward to a complete Modular S2 setup :thumbsup:
    Any link to the 2.5" bypasses? I couldn't find them on your website. Looking for pricing, mainly.
  17. Mar 7, 2013 at 11:14 AM
    icon_rep
    Riverside, CA
    You will see all the 3 of the S2 shock options up next week on the site.
    The Omega Bypass secondary shocks for the pair are $1819.12
  18. Mar 30, 2013 at 9:28 AM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    Anything for a 1st gen?!? I've gotta get something on mine soon since 6" FabTech lift and rear shock relocation... I have no bump-stop on there. :(
  19. Mar 30, 2013 at 9:37 AM
    Manwithoutaplan
    ID
    Just wondering op what is the best way to remove the stock bolts for the strike plate. Have buddy with these?
  20. Mar 30, 2013 at 10:23 AM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    Use a dremel and cut the bolts with an "x" pattern and then just hit them out
