ICON Vehicle Dynamics Delta Joint Retrofit Kits for 1” Uniball Applications
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, May 8, 2018.
  1. Jul 15, 2019 at 1:45 PM
    TacoBessy
    TacoBessy Well-Known Member
    Tom
    Creswell O.R.
    00 tacoma
    2wd to ifs manual hubs, Arb front locker, supercharger.
    Everyone seems to forget about us 1st gen guys. You know the guys with the most BasAss of trucks. Any plans on making something like this for us?
  2. Jul 18, 2019 at 1:32 PM
    Icon_Adrian
    Icon_Adrian [OP] Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    @TacoBessy
    Stand by my friend. We are in the final stages of the 1K Mile Testing for 1st Gens. :thumbsup:
  3. Aug 21, 2019 at 4:26 AM
    dark vader trd pro
    dark vader trd pro Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
    @Icon_Adrian
    do you know if the delta joint fit total choas lower control arm?
    My upper control arm have retro fit delta joint need constant re-lube otherwise it make noise? Is it normal?
  4. Aug 21, 2019 at 10:55 AM
    Icon_Adrian
    Adrian
    Riverside CA
    @dark vader trd pro
    The Icon DELTA JOINT will not work on the TC lower arm. The DELTA JOINTS have grease groove that go around the ball joint. If the grease groove is in a odd position relative the tire it may not get grease in the spots needed. I've personally loosened the a-arm nut and rotated the ball joint 90° to re-position the ball.
  5. Sep 6, 2019 at 10:23 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Hey - i've tried greasing my DJ's with the proper needle fitting and it does not seem like grease is going in at all. Would rotating the BJ help with this too?
  6. Oct 19, 2019 at 2:05 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    When will the DJ retrofit for Gen 1 UCAs be available?
  7. Feb 20, 2020 at 11:50 AM
    FishTacoTruck
    FishTacoTruck Well-Known Member
    2012 Tacoma TRD Off-Road Spruce Mica
  8. Jun 8, 2020 at 9:06 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    How long have these been lasting for people?
    Are they worth it (@ $300) over my regular uniballs (@ $100/pr)?
  9. Jun 15, 2020 at 4:16 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Anyone know part # for rebuild kit for 2.5 extended travel front shocks Part# 58635?
    Thanks
  10. Jun 15, 2020 at 6:39 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Contact @Icon_Adrian and give him the serial numbers off the shocks to get the correct parts.
  11. Jun 15, 2020 at 6:58 PM
    TWTaco
    Dave
    :thumbsup:
  12. Jun 17, 2020 at 10:45 AM
    Icon_Adrian
    Adrian
    Riverside CA
  13. Jun 17, 2020 at 1:31 PM
    TWTaco
    Dave
  14. Jun 23, 2020 at 12:51 PM
    SparkyTaco11
    SparkyTaco11 Member
    Carson, CA
    2017 Tacoma TRD Sport
    Would 614560 work on ICON uniball upper control arms ?
  15. Jun 23, 2020 at 2:16 PM
    #35
    Icon_Adrian
    Adrian
    Riverside CA
    No, the 614560 is the NON-ICON UCA Delta Joint kit.
  16. Sep 1, 2020 at 10:29 AM
    #36
    Rat_Bastard
    Rat_Bastard Well-Known Member
    Brian
    Tucson AZ
    2016 OR
    Can anyone provide an update on their experience with the DJs? I'm mostly interested in if the install is fairly standard as I will be installing them in my Total Chaos arms. I hope to hear far less squeaking, less maintenance and more longevity compared to uniballs.
    FishTacoTruck likes this.
  17. Sep 1, 2020 at 11:27 AM
    #37
    FishTacoTruck
    @Icon_Adrian
  18. Sep 1, 2020 at 4:54 PM
    #38
    Icon_Adrian
    Adrian
    Riverside CA
  19. Mar 18, 2021 at 9:36 AM
    #39
    18tacotues
    18tacotues Active Member
    North Carolina
    2018 White TRD OR 6mt
    Do you have the number for the delta joint retrofit on icon uniball tubular control arms?
    And does a normal ball joint press work or do I need special adapter
  20. Apr 17, 2021 at 7:42 AM
    #40
    climbnow_worklater
    climbnow_worklater Well-Known Member
    Sean
    2019 Tacoma DCLB
    F: ADS 2.5" extended travel #700, Camburg UCAs, DuroBumps, CMC, TC Alignment Tabs R: ADS 2.5" extended travel, Deaver U402 Stage II, BAMF Hammer Hangers, Timbrem U-bolt flip and Bumpstops, extended brake lines, extended diff breather Armor: Full RCI Aluminum Skids minus Fuel, (rerouted exhaust cross-over), RCI Rear Bumper, Victory Offroad Aluminum Strike Bumper, RCI Sliders Recovery: Smittybilt X20 10k winch (synthetic line, Factor 55 1" Fairlead and Flatlink Splicer) Wheels: 255/85R16, AlphaEquipt Command 16x8 +0, .75" BORA Spacers Misc: AlphaEquipt Snorkel, TRP Low Profile Sharkfin, Vagabond Drifter 159 (someday)
    Hello! Was there any movement on a lower Uniball Delta joint option? I was considering the ability to swap them in for the Uniballs on my TC lower control arms. Thanks!!
