Icon vs. OME
Discussion in 'ICON Vehicle Dynamics' started by Griff 99 TRD, Jan 13, 2013.
  1. Jan 13, 2013 at 9:28 PM
    Griff 99 TRD
    Griff 99 TRD [OP] Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp Hybrid Audio Speakers Pioneer Head Unit ARB bumper Eagle 15x10 wheels Odyssey battery
    Any opinions on which suspension lift kit is better: OME or Icon? I'm looking to install a 3" suspension lift on my 1999 Tacoma TRD. I've saved up $1,800 and want the best kit that will allow me to not only drive everyday, but go off-roading. Thoughts?
    Just a quick sub-note, I'm a novice when it comes to all things automotive...so please bear with me. I joined this forum to learn from all of you experts out there.
    Stay Safe!
  2. Jan 13, 2013 at 9:30 PM
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    i went with the Icon. More expensive but ive heard alot of good things, and so far im loving it
  3. Jan 13, 2013 at 9:32 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Depends on what you want to do. I've heard the OME is good for slower woods stuff. The ICONs are great for some desert running. They soak up whoops nice. ICON is valved in a digressive format vs KING or Fox that are progressive.
  4. Jan 13, 2013 at 9:48 PM
    Griff 99 TRD
    Sporty heretic,
    Yea, I've heard good things about both brands so I'm in jam now. Icon is definitely more expensive (appx. $700 difference). What kind of off-roading do you do?
  5. Jan 13, 2013 at 9:50 PM
    Griff 99 TRD
    ntilehman,
    At this point, I don't really know what kind of off road adventures I'll be doing...I just want a suspension that will promote any and all kinds of adventures; however, that being written, I don't foresee me in the desert in the near future since I'm in GA. lol
  6. Jan 13, 2013 at 9:52 PM
    SportyHeretic
    Jeremy
    2010 Sport
    Its my DD, mostly paved roads. Ive taken it up to Tahoe to play in the snow a few times and took it on a few dirt trails. Just got it installed in Nov12, haven't had a chance really to test its capabilities.
    And i love watching Elmo thanks to you ntilehman.
  7. Jan 13, 2013 at 10:00 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I went through the same decision and decided on Icon.
    1. Its rebuildable where OME is not
    2. Its a true coil over
    3. Its adjustable, OME is not
    4. Talked to a Sonny at DSM, he sold me.
    Its been well worth it. Very easy to install, feels good on road. And worked perfectly this past weekend offroad
  8. Jan 13, 2013 at 10:22 PM
    Griff 99 TRD
    Mitch,
    Does the Icon come in a Heavy Duty version that will allow me to add a winch and bumper?
    What do you mean by re-buildable?
  9. Jan 13, 2013 at 10:23 PM
    Griff 99 TRD
    Sporty,
    Sounds good, man! Thanks again for your time!
  10. Jan 13, 2013 at 10:23 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    You can run whatever spring rate your heart desires. When the shock is old worn and faded you can tear it apart and rebuild it
  11. Jan 13, 2013 at 10:29 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    OME suspension and a full race coilover like Icon is no comparison.
    The OME stuff is just a higher performance replacement type option. Coilovers like Icon, sway away, king, fox, etc...are high end performance coilovers designed to soak up the rough stuff and perform great off road.
    The ome kits are great, and perform great, but nothing like a full coilover.
    Coilovers are also adjustable and you can get a lot of heights out of them, while with the OME you pick a coil and are stuck with that height.
    It depends on what you do with your truck, and your budget.
    Plus like other said, Icons and most other coilovers are rebuild-able. When OME wears out, you throw it away and get more. Coilovers can have seals, bearings, shafts, coils, etc.. replaced and run them season after season.
  12. Jan 13, 2013 at 10:29 PM
    Griff 99 TRD
    Gotcha!! How long does it usually take before a shock becomes old and worn?
  13. Jan 13, 2013 at 10:31 PM
    DSYLEXC
    DSYLEXC Well-Known Member
    Icon FTMFW!!
  14. Jan 13, 2013 at 10:32 PM
    TRON_
    TRON_ The Game Has Changed
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    IG: st3f3ns OverlandBound1235 R.I.P. Rinzler
  15. Jan 13, 2013 at 10:32 PM
    Mitch
    Mitch
    Spokane, WA
    That depends on how you drive it. Icon told me about 20-50k miles before a rebuild
    And everyone above this beat me to the answer for your question
  16. Jan 13, 2013 at 10:34 PM
    Mitch
    Mitch
    Spokane, WA
    Honestly, its should come down to what you want/what you plan on doing with your truck. And your spending limit. If its under 1200 go OME (thats with rear Dakars for springs), if its under 2000, go Icon (thats RR from and rears on the Icons)
  17. Jan 13, 2013 at 10:37 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Icon here, works great on road and great off-road. I live in the desert, but like mild off-roading. the Icon extended travel is very nice for me. BUT you don't want to crank them as high as you can as they will top-out and ride horrible. I am running the standard 650 lb springd with a front plate bumper, winch, steel skid plate, ang sliders. Ride heigth is perfect for me as set up bt DownSouth Motorsports.I am at 2" lift over stock suspension wth Icon mini pack in rear.
  18. Jan 13, 2013 at 10:43 PM
    Mitch
    Mitch
    Spokane, WA
    Put your numbers here please
    http://www.tacomaworld.com/forum/suspension/248975-2nd-gen-icon-lift-heights.html
  19. Jan 13, 2013 at 10:49 PM
    Griff 99 TRD
    So, I would need to get Heavy Duty front springs? In other words, how would I alter the spring rate?
    Just checked out your build...NICE TRUCK, MAN!!!
  20. Jan 13, 2013 at 10:51 PM
    Mitch
    Mitch
    Spokane, WA
    You can substute the stock 650lbs 13.5" spring on the Icons with a King 14" 700lbs 14" spring which will allow you to have less preload at the same height
